Anyway, here are a few pictures where you can see the polished side compared to one of the worn side. I took a few pictures of both sides using different exposures for a better image of the marks.
For this I was going to use fine emery cloth but couldn't find any around here. I ended up using 800 grit sandpaper with WD40. At the and I'll use finer sandpaper to give it a smoother polish. Anyway so far the marks went out really easy, probably 10 min taking my time. If this fix doesn't hold long I'll just get a new camshaft and replace then. Anyway I though this would be a nice experiment, if this holds ok it could be a relatively easy fix with the camshaft in place, you'd only need to remove the cam chain housing cover at the back of the engine.
I'll keep this thread updated!
One of the worn sides
The marks you see are deep enough that I can feel them when sliding my nail over. There's a few spots where actually my nail almost gets stuck or I should better say it stops for a fraction of a second. All three sides of the lobe showed the same wear.
Click this yellow bar (not the image) to see the original resolution image
Polished side
The imperfections you see are nothing but light reflections except for the circled spot. I'll probably try to completely get rid of that spot too when I do the other sides even though I don't feel anything with my nail.
