I've noticed that not many people have adopted using these yet, and since I have, I thought I'd offer my opinion. I was recently having some excessive engine movement, enough so that with hard left turns, such as during autocross, the driveline was misaligned enough so that I couldn't get in 2nd gear. I got a bunch of great suggestions from folks on here, and since I'd been wanting to do all of the mounts anyway, I started with that. Because I've used ECS and been happy in the past, I figured I've give the motor mounts a shot.
I ordered the kit with both motor mounts and snub mount, all from ECS. Ordered the transmission mount from 034 motorsports. I'll say that visually they look great, although this is obviously not going to be a part that you see very readily. I was quite worried about increased NVH, because although I do enjoy autocrossing, I'm not a fan of lots of driveline vibration in a car that I drive daily. That's part of what made me consider ECS's mounts, with their advertisement of little to no increase in NVH.
Install was pretty straightforward, although it did require jacking the engine up a little bit higher than it was sitting before, I'm assuming because the stock motor mounts were pretty worn. It was actually beneficial to have to jack it up, as it enabled me to center the snub mount in the bracket.
Impressions: There was definitely a (slight) increase in engine vibration transmitted to the cabin when first installed. However, it was not enough that my wife, even when asked, could notice a difference. I've now got a couple of thousand miles on the mounts and I think that this has softened up a bit. I would say that now, as compared to stock, there is maybe a 10% increase in vibration, not enough for me to notice it, except right around 1K RPM, it's a little more prominent. All of that to say, I'm not unhappy at all with NVH levels. I would say that shifting is somewhat more "positive," but I cannot say that I've experienced the "amazing" improvement that some have after just the snub mount. I'm trying to be realistic about it, because when reading about all of the installs, I had a hard time believing that one mount could totally transform the car. It 100% does make a difference though. No trouble with CEL, utilizing the included resistors.
Most importantly, the shifting issue was fixed. I don't doubt that mounts from any of the other well-tested manufacturers would have worked as well, but I wanted to give my positive opinion of the ECS mounts, just because there's not a lot of information out there about them. And because, despite sometimes hard to swallow shipping prices, ECS is always my go to website when searching for parts by part number or category, has incredibly detailed pictures, and in my experience has been a great company all around.
