Results 1 to 40 of 51
    Jan 28 2014
    Fargo, ND
    Help! 20x10 et35 245/35 R20 WILL NOT FIT!
    Talk about a real downer...my car is all complete with Euro-Roc Intake, Borla Exhasut and KW V2 Coilovers and my dealer is confident the AG M590 20x10 et35 R245/35 R20 will not fit. My dealer and Avant Gardem and Need4Speed were on the phone yesterday and dealer says no way and AG/Need4Speed says it should work. Does anyone have a 2014 installed with 20x10 et35 wrapped with 245/35 R20's?
    I am leaving to go talk to my dealer this morning to see for myself. I have a lot of confiencence in both parties involved, but would like to know if anyone has had success with this setup.
    Oct 20 2008
    Denver
    what exactly isn't fitting? is the offset too low for a 10" wide wheel and hitting the fenders? is the bolt pattern wrong?
    Apr 30 2010
    San Diego
    I have that exact figment from ag with 245/35 and no issues. Running m510s 20x10
    2011 Audi S4 | 6MT | Ibis/Black Silk Nappa | Nav l B&O | Sport Diff | Carbon Inlays | H&R l Strat Intake l Strat SS l Alu Kreuz l AWE Exhaust l AG M510 20x10 et35 l GIAC Stg II l DTM Lip l Eurocode Diff Mounts l SS Clutch Line
    Oct 14 2012
    Empty...for now...
    SE PA
    10" wide at +35 offset sounds pretty aggressive, but the 245 tire width will help a bit with fender clearance. Should be no issue with suspension clearance.
    SOLD 2015 Daytona Gray S4
    Dec 22 2013
    Arizona
    tons of s4's are running 20x10 et35 AG's. AG has to be the most popular wheel choice on the S4 from what i've seen lol.
    Jan 28 2014
    Fargo, ND
    Quote Originally Posted by Wavz View Post
    The comment being made is the wheel (not the tire) will hit the metal lip of my fender. Currently, the dealer is saying the wheel (again not tire) is sticking out 1/2" - 3/4" past the fender as the when the car is sitting on the ground.
    Jan 28 2014
    Fargo, ND
    My dealer is looking to see if there is a difference in suspension components between 2012 and 2014. I am concerned something changed on the 2014 that is causing a problem with fitment.
    FYI the offset on the wheels have been verified that they are truely et35.
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    as you already know et35 on a 10" is aggressive.. so yes, it might poke (especially up front) depending on camber and ride height. isn't that why you stretched a 245 vs. a 255?
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Oct 20 2008
    Denver
    Quote Originally Posted by staticuxo View Post
    right?
    and since you're on V2s, why not just raise it?
    Sep 16 2008
    Quote Originally Posted by AudiTFSI3o3 View Post
    right?
    or go lower and the negative camber will help it tuck.. lol. -2.5 camber all around ftw!
    seriously though, i'm not sure how some people are saying (in other threads) they can run 20x10 et35 or even et40 with 255s as some have mentioned.. and 'not rub'.
    i've ran two different 20x10 setups, both with 255s and had rubbing issues. 20x10 et42 (current HRE P44SC setup) rubs up front with michelin ps2 and my previous vossen CV2 rubbed with hankook ventus v12. i rolled the fenders on my previous B8 which resolved it, but i also took out the spacers to run et45 up front. i also rubbed et40 in the rear and had to grind down the nub at the rear fender/bump.. after this, i was rub free.
    PREVIOUS:
    Jan 28 2014
    Fargo, ND
    There is no difference in componets between the 2012 and 2014.
    Jan 28 2014
    Fargo, ND
    right?
    I can raise it but for two reasons I would not do this.
    1. Looks
    2. At some point I will hit a bump and get full travel on the suspension and cause a problem.
    Apr 30 2010
    San Diego
    Here is mine on lowered on OE's with a 245/35 tire. No rubbing on except on a major dip and only then barely.
    Veteran Member Three Rings chuthis's Avatar
    Nov 30 2012
    socal
    Yeah this setup has been done a handful of times on the B8 at different suspension heights. I'm on OE's and it def pokes up front, but it never rubs (up front). If you're slammed, you'd just want to dial in some more camber to make sure it clears the fender under suspension compression. Like staticuxo said, as you lower it, it'll naturally have more neg camber anyway but adjustable control arms wouldn't hurt either.... :)
    Mine on OE's and 255/30's with some ahi poke
    10' S4 | 14' SQ5
    May 17 2012
    Houston, TX
    are you sure they provided the right offset? can you measure it to verify? I've been considering 20x10's and it always seemed like so many people have not had problems running them or were able to do so with minimal rubbing.
    Sep 16 2008
    Quote Originally Posted by AKPS4 View Post
    IMHO, they're all lying.. lol. as mentioned above, i've run 2 different 20x10 setups on 2 different S4s. let me know if you want to meet up and i'll show you my current specs in person. when i met you at the diner with pete, i still had my b8 with winters on if i recall?
    actually, i might be going to captree sunday morning then the elite motorsports open house.. let me know!
    PREVIOUS:
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Yeah 20's just look too big on this car in my humble opinion.
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Jan 28 2014
    Fargo, ND
    Quote Originally Posted by RavinJetta View Post
    Do you know how much negative camber you have on the rear end? I was at my dealer a couple of hours and we are rubbing on the rear end.
    Apr 30 2010
    San Diego
    I don't off hand but when I orginally got it aligned when I got the springs they tried to get it as close to spec. I was running the peelers for a while before these.
    Feb 15 2012
    Montreal/Quebec/Canada
    Quote Originally Posted by Usa View Post
    Depends on the wheel. A wheel with more spokes will look smaller.
    2011 S4 Premium \\ Phantom Black \\ Lunar Silver leather \\ Carbon Trim \\ Sports Diff \\ Alufelgen SF71 19x9.5
    Registered User Four Rings Need4Speed's Avatar
    Jul 25 2013
    Glendale/CA
    Here is a quick update for everyone on this.
    After speaking to the dealership and addressing Mr. Wavra's concerns on the fitment, and answering all his questions for him.
    We concluded the following.
    The fitment of the wheels and tires was exact and proper for the vehicle in question.
    After verifying every possible detail for the wheels that was provided to Mr. Wavra (20x10 ET 35 wrapped in 245/35/20 tires) which is spot on for the fitment being achieved.
    We received images from Mr. Wavra and concluded that the concern was the dealership had not adjusted the height of the vehicle and provided the camber so that it provides the identical fitment to the famous S4 here on the forum.
    This fitment does work on the B8 S4 all that is needed and the largest factor is just proper adjustment of the ride height and adjustments to achieve the proper amount of negative camber for the setup.
    Jan 28 2014
    Fargo, ND
    Quote Originally Posted by Need4Speed View Post
    You beat me to the punch on this. Paul is correct and did an amazing job helping me and my dealership with the setup. My dealer is completing the work on Monday so I can finally have my car.
    I want to thank Paul and Need4Speed for their customer service. Paul actually worked his tail off yesterday on his day off to help me out. He had staff back in the office helping out as well as Avant Garde. Superior customer survive and that being said does not do it justice.
    The fitment will clear with the setup but in my opinion you cannot go any more aggressive (i.e. less than an et35). It is an amazing look but it takes a special individual to accept it.
    Thanks making me feel like I was your only customer. Amazing!!
    Established Member Two Rings Antsa4's Avatar
    Sep 08 2013
    The 20x10 et35 setup should fit. I am running 255/30/20 with that setup and have no rubbing up front with mild fender roll and a very slight rub when I have a full back seat over big dips. Here are a couple pics to see how far I am dropped.
    [IMG][/IMG]
    [IMG][/IMG]
    2013 A4 Sport Package, 35% Madico Tint, Hoen Yellow Fogs, Avant Garde M510's 20x10 et 35, Hankook Ventus 255/30/20, H&R Coilovers
    Senior Member Three Rings DEEZ's Avatar
    Dec 11 2008
    Utah
    That fitment is dialed! Thanks for the pics. I've got the same setup coming in the grigio 590s with the same size, brand tires- Running OE's right now but will probably pull the trigger
    on the H&R coils after seeing this setup.
    Quote Originally Posted by Antsa4 View Post
    [IMG][/IMG]
    [IMG][/IMG]
    11' S4 Ibis White | Prestige | DSG | APR Stage II+ V3.0 | APR DSG Tune | Stage II APR Carbonio Intake | AWE Exhaust w/Diamond Black Tips | Deval Diffuser | JHM Slotted Rotors F&R | 20x10 ET35 AG M590 | H&R Coilovers | Eurocode Adjustable Rear Sway | RS4 Grill
    18' Q7 Glacier White | S-Line | Prestige | Black Optics | Adaptive Air | Adaptive Cruise | Thule Aeroblade
    Apr 11 2012
    [IMG][/IMG]
    [IMG][/IMG]
    one of the better looking S4s!
    Dec 22 2013
    Arizona
    this is really an et35? I figured it would poke out more then that...while watching tag motorsports accuair s4 they had an et36 and it looked like at ride height the rims were poking out a decent amount...
    are you running some camber? the top portion of the rim doesn't poke out compared to the fender as much as I thought it would
    [IMG][/IMG]
    [IMG][/IMG]
    May 17 2012
    Houston, TX
    i agree, it certainly doesnt look like it sticks out as far as the other photos shown above.
    How is everyone doing on tire wear with these camber adjustments? I want to consider getting the M510's in matte black and in 20x10's but dont want to run through tires every year or two due to uneven wear.
    Oct 27 2008
    I bet the magic for Antsa's car is camber and fender roll - without the roll, i'll bet it would rub fairly significantly.
    That said, it looks excellent - in fact it looks a lot like those cars with 20x10 et 40 - 43 without rolling.
    2011 Ibis A4 Avant - stock, but not for long...
    2010 Ibis Q5 3.2 - Premium | Tech | B&O | Navigation - kid mobile
    2011 Sprint Blue Premium DSG - Navigation | Sport Differential | Carbon | B&O | Black Optic | BFI Spacers - Stolen
    Veteran Member Four Rings d.p's Avatar
    Nov 08 2006
    F80 M3
    Annapolis MD
    Quote Originally Posted by typer100 View Post
    Yeah and a wheel with a lip will look smaller as well.
    Feb 28 2012
    Hopes and Dreams
    Miami, FL
    Quote Originally Posted by Esoteric View Post
    im runninf 19x10 ET36 with 255 and i haven't rolled anything or added camber past what is added with the drop and i drive it every day without any issues aside from the occasional canyon in the road
    '14 S4 DSG (Ibis White)
    BC Racing Type BR Coilovers | Vossen VFS1 19x10 ET36 | Zeus Flash ECU & TCU Flash | Corsa Performance RSC Exhaust
    Freelance Photographer
    State of Stance | Brand Director
    [email protected]
    Nov 21 2013
    United Kingdom
    UOTE=EGPhoto;9762412]im runninf 19x10 ET36 with 255 and i haven't rolled anything or added camber past what is added with the drop and i drive it every day without any issues aside from the occasional canyon in the road[/QUOTE]
    FWIW the easiest set ups on 20's are 255x30x9 ET 40 this would give a nice flush look wheel to fender and also allow some drop without rubbing and a very close rolling radius to OE.
    The other I've been informed is 265x30x9 more suitable for folk who do not intend to lower but fill the arches a little more.
    All depends on what you want to do and what look you're after really. These are just fuss free applications from speaking to wheel companies
    2014 S4 Black Edition.
    Nav High 7.5"
    B&O dsp surround
    Sports Diff
    Full Audi Drive Select
    Interior ambient lighting
    Euro Piano Black Trim.
    Oct 27 2008
    Well then I don't know what to say :).
    I've seen a few cars running 20x10 ET 42 and it didn't look like they had any room, but your setup is working, so clearly there must be room. What I would love is 265 on a 10 inch wheel, but up until recently, I thought this wasn't possible with even a fairly aggressive drop. Good to see there are setups that appear to make this possible. Then again, I don't even have my car anymore (stolen), so what do I know...
    I will be checking out pics of your car though - sounds nice. Congrats.
    Quote Originally Posted by EGPhoto View Post
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Tire selection sucks at 265 but I am in a similiar delimna, I am looking at a 20x10 setup and my retailer is suggesting et45 which is pretty tight to the suspension although i did say I didnt want to poke. So paranoid that I will get everything here and mounted and they wont fit !
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Jan 28 2014
    Fargo, ND
    Knowing what I do now the only change I would make is to go to a et40 instead of an et35. When I was purchasing my wheels Paul and I discussed this, but ultimately we decided to go with the et35.
    I was looking for the look of Jeremy's car on Need4Speeds website. Being a conservative Mid-westerner I found with my setup there is no margin for error. My position may change the longer I drive the car with the current setup without any problems. Time will tell.
    Jan 28 2014
    Fargo, ND
    Ok I might show my ignorance here.....
    I understand as the car is lowered you will get negative camber on the wheels to clear the fender. The part I can't figure out is in my opinion it shouldn't matter what ride height set my coilovers to produce this needed negative camber since as the suspension compresses the same effect will happen, is this correct?
    I like the look of a slammed car, but I would rather have the bottom of my fender be inline with the top of my tire. I am being told I need to keep my ride height pretty low to get the camber adjustment I need to provide proper clearance. Thought?
    Senior Member Four Rings riseabv's Avatar
    Sep 04 2013
    2010 Mercedes C350
    Southwest
    They can raise your car up and need to adjust the toe and camber to run the desired look you need and require. If I was you I would take my car to a performance shop and have them maneuver everything necessary in order to achieve the desired look. Your Audi dealership is honestly capable of only handling so much and most have a hard enough time installing an aftermarket exhaust from my experiences. They don't need to fully compress your springs to achieve the camber you need to clear properly if that is your question.
    14 s4 glacier white | b&o | carbon atlas | h&r OE | SPC uca's | 19x9.5 Stance SC6 | Hoen fogs | 15% Pinnacle Tint | Roc-Euro | Magnaflow exhaust | Special Goodies ...
    Sep 16 2008
    You will need adjustable control arms then as there is no adjustment up front.
    PREVIOUS:
    Veteran Member Three Rings Pworld's Avatar
    Dec 19 2008
    L.A. Palm Tree's and Beaches
    Dealer? as in Dealership? The LAST PLACE i would take my car to for "fitment" advice. Especially on anything aggressive or cool.
    The set up your talking about is not by the book. Im more amazed your trusting a dealership about aggressive fitment.
    Previous: 2007 A4, 2012 B8 S4 Bril Red, 2015 S4 Sepang Blue
    Function & Form Autolife / TAG Motorsports / AWE-Tuning / Injen / HRE / Falken
    Sep 04 2013
    2010 Mercedes C350
    Southwest
    Thought he had uca's in his build thread? He's right tho...
    Jul 25 2013
    Glendale/CA
    Just another update.
    the dealership was able to adjust accordingly as I advised them how to properly do the adjustments needed to make this unique setup work in their minds.
    Zach was a champ and I am happy that they were able to adjust this setup accordingly to achieve Mr. Wavras desired setup.
    After all said and done there were a few more adjustments needed such as the rebound on the KW V2 system as we opted to use a 245/35/20 instead of a 255/30/20 to provide a little more beef of a tire.
    you do not need adjustable control arms for this setup.
    as once you lower the car.
    the front cambers naturally to achieve the setup
    and the rear comes with camber bolts factory.
