Hi SwankPeRFection, from my short time on this board I respect you and the input you provide but I don't like the term "insinuating" as it implies I am trying to be underhand or derogatory in some way. I assure you that I am not and the moment readers think that is the case I no longer wish to contribute.
I am just trying to give some insight without putting all cards on the table as I also have a reputation and career to think off.
Did I get it wrong with the M1 comment? Possibly. This is my dilemma:
The ingredients and in particular, the base stocks vary considerably between regions due to varying market demands and conditions. Add this to the fact that manufacturers continue to move the goal posts so anything I say or recommend may not only leave me open to litigation but in 6 month’s time when someone else reads what I wrote, there is a good chance that it is no longer factual. Also, there are so many brands that it is impossible to keep up to date with who is using what. Then there is the issue of most ingredients being non-haz and therefore do not have to be declared on MSDS, so obtaining formulations is very difficult. The key is matching the correct oil to the engine type, engine demands, climate, driving styles etc. against your requirements with regards to price, performance and level of protection. Sometimes this can be achieved with off-the-shelf oils and sometimes it requires a custom blend or use of oils plus additives.
My initial response to the use of M1 was based on the UK market in general. I am not sure what you pay in the US? It also depends on what M1 product you are using or have used? If you can provide a link to what you use I can take a look and possibly provide a more informed view.
I would like to put the carbon issue back into context for the S4 and S5 models. Firstly, being of FI design the build-up is generally not that bad. Secondly, being FI means the effect of the carbon on performance is minimal. Therefore, significant running problems or warning lights are likely to be very rare except for abused and/or high mileage examples. You are not aware or inconvenienced by the issue to the degree it is actually not an issue.
Contrast this to the RS4 where the build-up is much more prolific and being NA the impact on performance much more severe. It’s a double whammy.
Originally Posted by
SwankPeRFection
Are you insinuating that M1 is expensive? Because in our country, it's the easiest to find and least expensive of them all. Perhaps it's different in the UK. Look, I know you don't want to get in a oil pissing match here and hopefully people will avoid that, but I do want to know if some of your logic on this is also region based? I ask this because like you not wanting to put M1 in your car, Castrol won't be put in mine. The same thing would go with other off-brand ones because they are harder to get and if for some reason the specification ins't on the bottle (even though it's a better oil), the manufacturer WILL GET in a pissing match should something happen. While I can't speak for carbon buildup (even on my B7 A4), I will say that I've always used M1 in all my cars and they've all survived until 100k+ miles with no issues. It just seems to work and it sure is easier to find than the Redline oils I used to use years ago.
