Results 1 to 17 of 17
    Established Member Two Rings merlinq21's Avatar
    Sep 03 2013
    2011 S4, 2015 VW Tiguan, 2012 Subaru WRX,
    2011 S4 - How to Use Keyless entry
    Hi Folks, I did some searching and could not find any real information about the keyless entry feature for my car.
    Anyone out there have some easy to follow steps on how to use this feature?
    Thanks in advance
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    Grab handle to unlock. Touch the little square on any handle to lock
    2016 M3 Mineral White
    2014 S4 Ibis White - Sold
    Mar 21 2014
    denver
    I was recently at a conference. The speaker at the podium finally got his powerpoint slides on the screen and says "what do I do now?" I yelled out: "start talking".
    2011 B8 S4 | APR Stage II | H&R Sport Springs | 19" VMR 710 (summer) | 19" peelers (winter) |
    Sep 03 2013
    Very good
    Sep 03 2013
    I will see if this solves it- thanks
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by merlinq21 View Post
    Thanks in advance
    I presume you are referring to the Advanced Key feature, and not use of the buttons on the remote key fob.
    The door is unlocked by putting your hand between the door handle and the door, as if you are going to grab the handle to pull the door open. There is a sensor on the back side of the door handle that detects the proximity of your hand and triggers the door to unlock. Sometimes mine takes half a second to activate. Note, you do not have to actually touch the handle to trigger the unlock action.
    To lock the door, hold your hand in front of the small rectangular contour on the outward-facing surface of the door handle which will trigger the door to unlock. Again, the sensor works on proximity so you do not have to actually touch the rectangular section to trigger it.
    NOTE: In order for the above actions to work, the key fob must be near the car. I'm not sure what the actual range is....typically mine is in my pocket. But I know that if I have it sitting ~6 feet away from the car and spray it with a hose (like when I am washing my car at home), the contact of the hose water on to the rectangular "lock" sensor will cause the car doors to lock repeatedly.
    SOLD 2015 Daytona Gray S4
    Sep 03 2013
    Thanks for the detailed and quick answer
    Sent from my HTC One using Tapatalk
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Only cars with push button start have that feature, kind of silly imo
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    Quote Originally Posted by SteveYem View Post
    Yeah you have to be within like 3 feet of the door that you want to open. If i'm standing by the drivers door and my wife grabs her handle the car won't unlock. It's not just a generic distance from the car, it's from the actual door your trying to open.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by 13S4 View Post
    Good point!
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by saxon View Post
    Curious...
    On my S4, I have all the physical components there like the black square etc on the door handle...not sure on the other triggers...
    IS this something I can unlock with VAG COM?
    Realistically it's not a major concern because I need the key regardless to start the car.
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by RudyH View Post
    Curious...
    I do not believe so. The The square on the door handle is there because they standardized on one plastic mold across the entire product line of B8 A4/S4, regardless of whether the car is equipped with the Advanced Key guts.
    Mar 19 2014
    Central, NJ
    +1 here too. Very interested in this.
    Curious...
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Go to this link:
    http://www.audiusa.com/help/video-tu...eTutorial/all/
    Then scroll down to the video for Audi Advanced Key. The image looks like this:
    Click on the "> View Video link"
    There are lots of other tutorials at this site as well.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by LYKUNO View Post
    Go to this link:
    Ah ok - looks like it needs that extra radio for the FOB -> kinda like NFC but up to 5'
    It was one of those options when I was buying where it was nice to have but not a game breaker.
    Past
    Sep 03 2013
    Thanks for the feed back
    Sent from my GT-P5113 using Tapatalk
    Oct 02 2015
    Chicago
    Just bought a 2010 s4 and can't get mine to work. The pass aged side locks and unlocks fine but the drivers side only unlocks. Any idea why it won't lock from the drivers side?
    2010 S4 Prestige/ S-Tronic/ Ibis White/ APR Stage 2/ APR SC pulley upgrade/ AWE exhaust W/high flow resonated down-pipes & black quad tips/ Roc Euro cold air intake/ H&R full Street coilovers
