7k miles @ 1.24 quarts burned. More than my last maintenance period, stage-2 might have something to do with that.
Manual seems to imply the updated oil level should be reflected the next time the car is started, I didn't see any change after two off/on cycles about 20 minutes apart. Dip stick looks mostly good, maybe I need to add that last 1/4 quart, though for some reason the message says 1 quart max (I hit the max already). Confusing. That is a weird message, max 1 quart, I usually just add oil until its to the max line. What do you guys think? Drive for a little longer to see if the message goes away, if not, add the last 1/4 quart? That's what I'm thinking of doing. Never heard of mixing too much new oil between oil changes causing a problem if its all the same brand and weight, I'm using the OEM Castrol stuff, maybe they are worried about mixing other types of weights and brands?
