Page 39 of 39 FirstFirst ... 29373839
Results 1,521 to 1,558 of 1558
  1. #1521
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Quote Originally Posted by Brofessur View Post
    What is everyone running for PSI at ride height? I ride at basically 0 finger gap, 80 PSI in the fronts 74 in the rears. Damping in the middle
    Back when my Jetta was bagged, i ran at 40/45 psi all around. While the ride in my allroad isn't awful, I feel like i should be running a lower psi and take away the bit of bounciness. Basically raise the struts, to run less PSI and maintain ride height.
    I’m at 90/75 with about 1” clearance all the way around. I have the bilstein b8’s and it’s slightly bouncy at this height. 75/60 was almost perfect but a little too low for my local roads
  2. #1522
    Jul 20 2016
    Has anyone had their Endo-Ct fail on them yet? Mine was good for 1.5 years and finally got the "compressor freeze" message. I'm wondering if anyone has connected a regular viair compressor to an endo tank
  3. #1523
    May 02 2018
    Fort Myers/Florida/USA
    *Official B8 Air Ride thread*
    Quote Originally Posted by 08ISF View Post
    Did you winterize your system at all? Not sure if you can with the CT as I have the standard compressor and tank separate, but cover it with a blanket for a while while the car is running. Turn the compressor off in your settings then enable it in 5/10 minutes or so. Happened to me with my compressor last winter but it’s just cold.
  4. #1524
    May 02 2018
    Never posted in here, but I’ve been bagged for 2.5 years now and loving it. Drive height is 75/62 with ALP rear struts. I have it a touch firmer with dampening, but that’s NY for ya. Wheel setup is 19x8.5 +35 running the 17.5mm flush kit from ECS both front and rear with a 235/35/19 tire. image.jpg IMG_5023.jpg
  5. #1525
    Active Member One Ring ALRAUDI's Avatar
    Dec 09 2019
    1995 Mitsubishi Eclipse 550hp/460trq
    Port Saint Lucie, FL
    I have middle setting set at 75psi all around and lowest on the smooth roads 65psi front, 60psi rear
    2013 Audi Allroad Premium, Monsoon Grey
    1995 Eclipse GST converted to GSX 550hp /460trq
  6. #1526
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Added a second tank to the set up for a little more capacity, I’m thinking about replacing the 2.5 gal with a 4 gal seamless and re-running the lines for a cleaner look
  7. #1527
    Junior Member Two Rings
    Apr 11 2020
    Boulder, CO
    Wrapped my install up on my B8.5 allroad. Had a fabricator friend make me a custom bracket to mount everything. Running Airlift 3P, dual 444c comps & a Seamless 4 Gal tank with 45° ports.
    Pics by @fault.kode on IG.
  8. #1528
    Jun 27 2021
    England uk
    has anyone out of all these post fitted coilovers and then fitted bags over the coilovers instead and coverted it to a bag over coilover set up
  9. #1529
    Jun 27 2021
    England uk
    looking to fit bags over my coilovers but not really seen much
  10. #1530
    Established Member Two Rings Rook518's Avatar
    Apr 18 2016
    NY 518
    Wondering what tire sizes you guys are running with your air set up. Installing my 3P and i have 255/35/19 on a 19x8.5 wheel.. Wondering if its to “tall” of a tire and its gonna rub. Not allowing me to go lower. Or am i fine.. Thanks
  11. #1531
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Quote Originally Posted by Rook518 View Post
    I currently run a 19x9.5 with 275/35/19 at 75psi in each bag and don’t have any rubbing or anything, actually still have quite a bit of room left. I’ve used a 20x10 with 305/30/20 before and that rubbed at 70psi but was good to go at 80.
  12. #1532
    Junior Member One Ring young_euroB7's Avatar
    Sep 30 2010
    NY, NY
    Haven't Posted in awhile and decided to share my love
  13. #1533
    May 20 2021
    Hello!
    I hope someone could help answer my questions. Pretty new at this so...bare with me.
    I have a 2015 b8.5 s4. I'm thinking about bagging my car with the Air lift 3P. I looked through all the pages to find the setup I need but I don't think it was mentioned here since most of the postings were about the allroad. Not sure if the wheel well is the same as mine.
    I want to save my trunk space bc I golf(I carpool with a friend so 2 bags are in the trunk) and ski/snowboard so I need the trunk space. I read on the s4 pg, that someone mentioned I can install the compressors x2 (444c) and the management in the side pocket of the trunk with the tanks in the spare tire well; 2, 2.5 gallon tanks. Is it possible to fit 2, 2.5g tanks in there? If not what size tank can I fit in there?
    What other parts do I need for installation besides, the compressors x2, tanks x2, 3P management, Front/Rear Bags, 1/4" lines, push to connect ports, and the compressor harnesses. Do I need an air compressor isolation kit?
    Also I'll be ordering new wheels, AG M580R 20x10. What's the best tire size and offset? I've been reading that 20x10 +40 or +35 is good and getting 245/30/20 for tires. Looking minimal rubbing, hopefully no fender rolling and being able to do a full turn. I'm looking to get a flush look at ride height, (rim/fender)
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Quote Originally Posted by Jdobs View Post
    Hello!
    I fit (2) 444c compressors, (2) tanks-4 and 1 gallon tanks, isolators for both, and the management in the spare tire area. It’s a tight fit but works perfectly. Isolators aren’t necessary but quiet it down. If you use seamless tanks you’ll need some extra fittings, I needed to resize from 1/4 to 3/8. I wasn’t able to fit anything bigger than a 1 gallon tank with the 4 gallon filling the rear most trunk area. To my knowledge the spare tire area is the same size for all b8 models?
  15. #1535
    May 20 2021
    Quote Originally Posted by Peter.dupuis View Post
    Is 4 gallons enough? Or would it better to have a total of 5.
  16. #1536
    Jun 28 2015
    2018 Atlas
    Bend, OR
    4 is good enough. I have the extra tank mainly for accessories but it hooks up perfect with the 4 gallon
  17. #1537
    May 20 2021
    Would I need to use a seamless tank or can I use a 4 gallon end port tank to fit in the wheel well?
    Do you also have the measurements for the tank you have?
    Is it the same size as this one:
    https://www.bagriders.com/seamless-t...6.html#reviews
  18. #1538
    Jun 28 2015
    2018 Atlas
    Bend, OR
    I’m pretty sure the seamless is the only 4 gallon that will fit and yes that’s the one I have.
  19. #1539
    May 20 2021
    Oh really? I was just comparing that seamless tank to the 4g end port tank on that site and the measurements are almost the same...only difference is the height...
    Seamless- Length: 32.00" Diameter: 6.625" Height: 7.50" (with brackets)
    Air Lift Aluminum 4 Gallon Face Port Air Tank- Length: 30.00" Height: 7.50" Diameter: 6.00"
    Air Lift Aluminum 4 Gallon End Port Air Tank- Length: 30.00" Height: 7.50" Diameter: 6.00"
    Maybe its bc of the stands under the tank that makes it not fit? Does anyone have any input on this? Have you used a face/end port in the wheel well?
    Also has anyone had any experience with Slammedenuff? Their Slammedenuff airstruts? Might get a full kit from them instead of Air Lift Performance.
  20. #1540
    Jun 28 2015
    2018 Atlas
    Bend, OR
    The face ports may not work because of space but the end ports on that tank should fit. I’ll measure my set up when I get home.
    No experience with slammedenuff but I wouldn’t use anything else after the beating I’ve given my air lift bags and they’re still solid
  21. #1541
    May 20 2021
    were you able to get the measurements?
  22. #1542
    Jun 28 2015
    2018 Atlas
    Bend, OR
    I’m not sure if Seamless adjusted their products or tanks capacity. But the one I have is 24” long and was listed as 4 gallons. That exact size tank is now listed as a 3 gallon tank. I assume mine was originally mis-labeled, but that size fits perfect and the capacity, assuming it’s actually 3 gallons, still works perfect for this platform. Based on my measurements, anything longer than 27-28” won’t fit in the spare tire area with connections.
  23. #1543
    Oct 27 2005
    Central Texas
    I wanted to share my experience with obtaining additional ride height on my Allroad. I ran the 20” RS5 wheels w/ 275's in which the size prevented the car from a full air out. When running the Airlift calibration the system could not calibrate due to the limited rear travel. Between resting on the wheels and the max height of the double bellow I was obtaining the following max height.
    The standard spacers on the Airlift double bellow bags are 1.5”. I then had a local machine shop manufacture a set of 2" and a set of 3" spacers to replace my 1.5". I first had purchased another set of the spacers to double stack them but a friend put me in contact with a shop to have them made and therefore went that route.
    The 2" obviously increase the height by .5" but if paired with the stock spacer would total 3.5" of total spacer. I ran the 3" and this allowed me to obtain a rear ride height of near stock Allroad height yet also still allowed me to fully bag out. This was nice for when inclement weather was an issue i had the height I needed and the wife preferred the taller ride height. Here they are installed, unfortunately we dont have images of it at full ride height but imagine a stock Allroad.
    I still have the 2" risers and two sets of the Airlift 1.5" spacers that can be double stacked with your existing 1.5" spacer to get the 3" rear obtained. Obviously you will need new bolts which I picked up from a local hardware store. Plan on posting spacers in classifieds now that the car is sold.
  24. #1544
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Making some progress on my air install on my B8 A4.
    It will be completely hidden. Won’t be able to see the tank, pumps, or management.
    ACCU-AIR management with Air Lift Performance struts.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
  25. #1545
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    Hey eg, still have the spacers? I'll take both sets. Shoot me a text as I'm never on AZ anymore.
    -Brandon
    (703)9seven558four8
  26. #1546
    Oct 27 2005
    Central Texas
    Quote Originally Posted by MMMB00ST_A4 View Post
    -Brandon
    (703)9seven558four8
    If anyone is interested here is the ad for the spacers.
    https://www.audizine.com/forum/showt...Risers-Spacers
  27. #1547
    Sep 06 2014
    Ottawa, Canada
    Finished installing the tank, manifold, pumps, controller, and ECU. All wired up. No leaks.
    Now to install the struts, lines to the struts, height sensors and lines to the height sensors.
    Almost there. Pumps run great, no leaks so far.
  28. #1548
    Feb 22 2023
    UK,Wales
    here is a video on the Pillow Ball Mount Type
  29. #1549
    Sep 06 2014
    Ottawa, Canada
    I'm looking for recommendations on how to "straighten" the vinyl hose to run and install all of the lines underneath the car. I will also want to put some bends in here and there to have it follow the underside well. Those I'm not as concerned about, thinking I will be able to manage those well with a heat gun and a tubing bender since it is a very small section that I will be able to apply concentrated heat to while bending it. (I'll be extra careful not to apply too much heat and damage the tubing)
    From what I can see, most recommend putting the coiled up roll of tubing into a sink of hot water ... letting it sit for about 10 minutes, then pulling it out and trying to uncoil it.
  30. #1550
    Jun 27 2021
    England uk
    front air ride strut
    sorry guys to bring up an old thread but ive managed to get every thing installed on my air ride but ive now just got to fit the front struts can anyone tell me do i need some spacer or rubber mount on this or is it i just sit the top hat on top do i need any thing or am i missing owt
  31. #1551
    Jun 27 2021
    England uk
    bump anyone 39 pages tons of post not one answer to what i am missing
  32. #1552
    Jul 20 2016
    How long are your compressors lasting? After trying to troubleshoot a fault pressure sensor I'm being told the compressor needs to be replaced. I've only had this viair 444c for about 2.5 years and have driven about 10k in that time
  33. #1553
    Sep 06 2017
    05 Subaru LGT (HTA71)
    MA
    I think it's very dependent on how often they run. I stayed at drive height most of the time so they rarely kicked in and my lasted 5+ years. Aired out on occasion.
    > S4 Swapped B8 Avant <
    > 2015 Glacier White allroad P+ (RIP) <
  34. #1554
    Veteran Member Three Rings A42007's Avatar
    Jan 12 2011
    2018 Audi A4 B9, 2012 B8 Avant
    Phoenix, AZ
    Back from the shop. We added lock nuts on both ends of the arm links on all 4 corners. We meant to do it during the main install, but got so tied up in just trying to get the sensors to work that we just forgot.
    New manifold should arrive tomorrow, so hopefully I'll have a fully functional 3H kit by the end of the day. Now if only I could get an Airlift controller, because I'm finding that I have to re-pair to the manifold every time I open the 3H app. Anyone else experience that?
    Are those custom brackets or did you pick them up somewhere?
    EDIT - Accuair brackets that are no longer made.
    2007 B7 A4 FWD - APR Stage II / Magna Flow Cat Back / 2.5" TP / ST Coilovers / 19x8.5 ET 32 RS6 Reps / Aftermarket Navigation / 235/35 Hankook Ventus V12 Evo's. - http://www.audizine.com/forum/showth...di-07-A4-Build.
    2012 B8 A4 Avant Premium Plus Quattro (S4 Conversion In-Progress) - ECS Hi-Flow Cat / 3" Down-pipe / Air Lift Performance 3H Air Ride / 10.25" RSNAV Series 4 / Rohana RC7 20x9 ET25 / Ohtsu FP8000 255/30R20
  35. #1555
    Jan 12 2011
    Phoenix, AZ
    - 2012 B8 Avant Premium Plus
    - Air Lift Performance 3H / 3P Management
    - Raceland Front & Rear Bags
    - BecauseBags Stealth Trunk Bracket
    - Dual Viair 400C Compressors
    - 2 Gallon Seamless Tank
  36. #1556
    Oct 07 2015
    McDonough, GA
    How's the ride quality? Specifically wanted to know as I'm thinking about putting my 2015 RS5 on air. I hear horror stories about the super bounciness...
  37. #1557
    Sep 06 2014
    Ottawa, Canada
    For me driving around town or on the highway it is fine. But i am also running the air lift performance struts, with accu air height adjustable controller ands sensors.
    Where i find it bouncy is when pushing it in corners and hitting a bump. I think this is where i needed to spend some time getting the height and pressure dialed in just right by adjusting the height is the struts so that when they are at the desired ride height, it is also at the optimal pressure for handling.
    I’d certainly like to hear from others as well if they have used that approach to optimize.
  38. #1558
    Oct 07 2015
    McDonough, GA
    Thank you! Are there any other suspension items I should beef up before the install?
