Page 38 of 39 FirstFirst ... 2836373839 LastLast
Results 1,481 to 1,520 of 1558
  1. #1481
    Feb 24 2013
    CA
    Quote Originally Posted by Phil.Lmbrt View Post
    Hi !
    Here's my s4 on Airlift Performance 3H and an ENDO CT tank !
    Anyone else uses an ENDO?
    That thing is literally silent
    Beautiful ride and good to know it’s silent AF. My dual 444c are louder than my exhaust lmao
  2. #1482
    Senior Member Three Rings Phil.Lmbrt's Avatar
    Apr 12 2017
    La Sarre, Quebec
    Quote Originally Posted by Slick_B8 View Post
    I have it mounted to an inch thick hardwood floor, basically directly next to the backseat and I would describe the noise in the cabin as a light hum. To hear it properly I have to close all windows, shut the radio and ventilation
    2012 S4
    Phantom Black | 6MT | Sports Diff | B&O
    IE Dual Pulley W/ TB | 57/187 Pulleys | Rabbit Hole Motorsport | CTS | USP | 034 | JHM | PLM | BFI | P3cars | Rotiform | CR-15 | Macan Calipers | StopTech | Hawk Performance| SPEC Clutches | Snow Performance | Airlift Performance | Accuair | Kühl Rennsport
    IG : Phil.lmbrt
  3. #1483
    Active Member One Ring ALRAUDI's Avatar
    Dec 09 2019
    1995 Mitsubishi Eclipse 550hp/460trq
    Port Saint Lucie, FL
    I am currently in process of wiring airlift 3p/h and instead of running pink wire for ignition source all the way to the front of the car, have any of you used rear fuses in the right luggage compartment? for example FUSE PANEL C, fuse #2 12-volt socket, cigarette lighter, or maybe FUSE PANEL B, fuse #11 vehicle electrical system module? Both are at 20amps.
    Thank you in advance.
  4. #1484
    Senior Member Two Rings RLwantsS5's Avatar
    Jul 11 2014
    2022 Lexus Ux200 (wife)
    Bonita Springs, FL
    Hi !
    These have to be some of the sickest wheels i ever seen.
    Sent from my SM-N950U using Audizine mobile app
  5. #1485
    Jan 15 2019
    Minnesota
    Anyone here bagged and running an aftermarket rear sway bar? And if so, did you have any clearance issues? I just installed the 034 rear sway bar today with moog end links but its hitting against the lower control arm when I lower the car. I've tried looking at options like adjustable rear end links but only see adjustable fronts. Anyone have the same experience? If so, please share. Thanks!
    Sent from my SM-G960U using Audizine mobile app
  6. #1486
    Established Member Two Rings S4b8.5black's Avatar
    Apr 20 2019
    Hamiton
    I have that exact same set up and never notice anything when lowering my car I will have to take a look.
  7. #1487
    Jan 15 2019
    Minnesota
    Yes, that would be greatly appreciated!! I had a shop install my sway bar for me and then when I aired down to ride height on Accuair e level, it was giving an error that there wasn't enough travel on the height sensors. So they put the car back on the lift to check and it's from the bar scraping against the lower control arms. I would hate to go back to stock sway bar
    Quote Originally Posted by S4b8.5black View Post
  8. #1488
    Veteran Member Three Rings Wagoon's Avatar
    Jan 31 2010
    Stock parts
    Orlando
    Quote Originally Posted by Nguyenmn55127 View Post
    I have the rear ST Swaybar and Moog End Links with no issues.
    wagoons || corey
    thewagoons.com
    2016 allroad quattro // rsfauxroad // 3p // stg2 e85
    airlift.akebono.apr.bbs.cr..ecs.eurocode.forge.inn o.st
    the wagoons - build thread - instagram
  9. #1489
    Feb 27 2020
    Sables d'Olonne / France
    Hello everybody, i just got my S5 B8.5 bagged and have a EDC error, i did have the adaptive dampers. I would like to know how you got rid of this. I do have vagcom so that would be best for me as i know KW does a set of EDC delete kit but 350...
    Thanks
  10. #1490
    Established Member Two Rings planekiller1's Avatar
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    Quote Originally Posted by ALRAUDI View Post
    I used the rear cigarette lighter, but there is a relay you can use that is only when the engine is running, luckily I didn't care enough because I hop in my car and throw the engine on anyway.
    -Kurt
    |2012|A4|Avant|S-Line|Glacier White Metallic|2.0TFSI|Quattro|ZF-8Trans|Custom CAI|P3 Gauge V1|Luft-Tecknik Intercooler|
    |Exhaust Cutout|LED Tails|HPA Intake Manifold|HPA Stage 2+ Tune|Catless|Custom Shift Knob|Bagged Airlift V2|
    IG:RS4M8
    Blog Here
    *Vag-Com available to use locally or rent pm for details*
  11. #1491
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    Here's a pic of my Avant. Running custom bags on ST Coil over struts, Alzor 084. I had to change the front ride height because I was running 140 in the front bags and I knew that was going to blow a bag sooner or later. So this is the last pic of the front end matching fender to lip. Got the whole kit 2x 444C, 5 gal, 4 bags and shocks, with V2 management for $600 so I'm ok working out some kinks.
    -Kurt
    IG:RS4M8
    Blog Here
  12. #1492
    Feb 29 2020
    Null
    2011 Audi B4 B8
    Accuair E-level, I-level complete package
  13. #1493
    Dec 09 2019
    Finished the install last week.
    Airlift 3H/P (height sensors not installed yet)
    2.5 gallon tank
    1 444cc Viair compressor
    So far so good. Love how the car handles and ability to go up and down at the press of a button 😈
    The idea behind install is to make it as Clean and Stealthy as possible without sacrificing full trunk space.
    P.s. nylon nuts for rear bags suck big time, it’s been 1 week and left side nylon nut already stripped.
    Anyone tried making custom aluminum nuts to replace nylon?
    2013 Audi Allroad Premium, Monsoon Grey
    1995 Eclipse GST converted to GSX 550hp /460trq
  14. #1494
    Senior Member Two Rings justinss4's Avatar
    Aug 11 2019
    2007 b7 a4 (sold) 2006 GMC Sierra 2500HD Duramax LBZ
    clyde ny
    Hi I installed airlift 3h and am trying to calibrate the system so when I lower the car all the way and go in the settings it says range low and when I raise it all the way it still says range low ...does it need to make a bigger sweep or do I just have to move my sensors up a little
    Sent from my SM-G930V using Audizine mobile app
  15. #1495
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    2.5 gallon tank
    Damn nice job!
    Very clean install, ... custom air tank inside the rear bumper? Cool! Also really nice job flushing the controller inside the ashtray area in the centre console!
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
  16. #1496
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    Anyone selling a 3p/3h system? Back in the market for another.
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
  17. #1497
    Junior Member One Ring young_euroB7's Avatar
    Sep 30 2010
    NY, NY
    Anyone selling a 3P full kit plus management? PM me ASAP
  18. #1498
    Jun 13 2017
    Washington
    Just installed my 3p setup the other day. Found this 645 relay in right rear of the trunk to add 12v ign on power (pink wire).
    I don’t care for the flex lines so far. What are you guys using for hardline setups?
  19. #1499
    Senior Member Two Rings Joey9's Avatar
    Mar 16 2015
    2009 Audi A4 Avant & Matching Trailer // 2009 Audi A4 Sedan APR Ko4, FBO, APR Stage 3+
    Rochester, MI
    Absolutely love the exterior mounted tank! Great idea!
    Bagged B8.5 Swapped A4 Avant & Matching Trailer
    B8 A4 Sedan APR Ko4, FBO, APR Stage 3+
    Instagram // TiktTok // YouTube: @joeyjacobss
  20. #1500
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    I run the accessory to the 12v outlet but I'm an avant works wonders there is a relay that's only on when the car is turned on but I just fire the car up since I know the tank will be low as it's not a full proof leak proof system I have it has some small leaks at the tank, but I'm not that worried as its only after a day or two it's lower than 100psi.
    -Kurt
    IG:RS4M8
    Blog Here
  21. #1501
    Dec 14 2018
    MN
    alrighty, just joined the airlift club got everything installed and working, but i have a few questions. what is everyone's driving air height at so that you guys dont rub your tires. i am currently running 19x9.5 and when i turn or go up or down a cloverleaf on the freeway im rubbing (tires).
    driving air height is 73 all around (fender is about 1 finger from tire), front struts are adjust to stock strut height, dampening is 2 clicks from hard.
    here is what im looking for in the airlift: comfort and track ability.
    How would i get this 3p set up to track ability without rubbing my tires and not ruin the smooth cruising ability.
  22. #1502
    Jul 20 2016
    Has anyone shifted the frame after maxing out the camber? I've maxed camber and pulled my rears but the driver side sticks out a few mm more than the passenger side making it so I can't air out. I'm on basic 19x10 +35 with 245/35 and wanted to avoid stretching more, plus I'm ocd about one side poking out further.
  23. #1503
    Mar 16 2015
    Rochester, MI
    Instagram & YouTube: @joeyjacobss
  24. #1504
    Established Member Two Rings JD.RS5's Avatar
    Apr 01 2020
    Washington
    Anyone got photos of an empty spare tire/battery area before compressors and tank got set up? I wanna know what size tank fits there before i order my kit.
    2014 RS5 Black Optics... i tried to keep it stock
  25. #1505
    Jun 28 2009
    Gaithersburg
    Car: 2017 Allroad Prestige with most of the options
    I bought Accuair Endo VT tank before Accuair went out of business .
    now I am trying to use it and I am not sure how or if that,the Endo VT tank will work with Air lift Performance 3H.
    Anyone here if this or similar experience with this setup?
    I have sent emails to Airlift and yet to get a response
    any information will be greatly appreciated
  26. #1506
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    If you have the input harness into the Endo you should be ok to splice, you'll have to figure out what to splice in order to get each function working however.
    Might be simpler to sell what you have and start fresh sadly.
    Currently working on the design of my air management once I sort it out and get some movement it'll be in crowd funding phase. Trying to be in the 500 region on pressure management and 800 w/ ride height sensors some ideas in my mind about using optical sensors since the plastic arm ones are very prone to breaking. There needs to be more companies in the market or one will skyrocket prices.
    -Kurt
    IG:RS4M8
    Blog Here
  27. #1507
    Sep 27 2017
    Curious if anyone else is having issues with their Endo CVT system. I had it installed on my SQ5 when the system first came out and had a ton of issues with it randomly airing out or not airing up when starting the car. They had to replace pretty much every Accuair piece on the car. Of course the week when Accuair said they were out of business the car would not air up and the controller was flashing at me with error codes. Then two days later it started working again and I haven't had an issue since. Just seems like not all of the bugs were worked out to begin with and it works great for a while then will throw a random issue here and there
  28. #1508
    Sep 27 2017
    I have been searching for quite some time and cannot find one, does anyone know if they made this for the Accuair E-level controller?
    I know they used to make a mount that would fit in the coin slot on the shifter but I cannot find those either.
  29. #1509
    Nov 25 2018
    Italy
    Hello everyone, I'm just installing Airlift 3p system on my Audi A4 B8.5 right now. Just wondering do I really have to cut a hole for the rear bags just to tight that nylon nut? Is it possible to not use it or cutting?
    Thanks for the advice.
  30. #1510
    Mar 16 2015
    Rochester, MI
    Quote Originally Posted by s4vage_b8 View Post
    Yes you really do have to cut a hole to tighten the nut...
  31. #1511
    Junior Member One Ring mini64's Avatar
    Nov 01 2016
    B8.5 S4, Lotus 7, Elan, 64 Mini and E46 M3 (wife's dd)
    Bryan, TX
    I'm looking into bags for a different reason. Please dont tell me to go buy a truck, but I was the guy that used to have a lifted WRX with the right tires to go play around Big Bend state park and the like. It came time to get a more civilized car and now i have a beautiful Audi. If I wanted to bag it only so that a few times a year I could give it a few more inches of ground clearance would just a manual control be ok? Or would i eventually want an electronic controller as between trips down a dirt road i'd find myself needing to make adjustments due to leaks or temperature changes or other reasons.
  32. #1512
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    *Official B8 Air Ride thread*
    Scrolled through all 76 pages figuring out which way to go. Posting the kit I’m planning to order from bagriders for my 14 allroad. Let me know what you guys think and if I should have any issues with fitting everything in the spare wheel area or any suggestions.
    Air lift 3p, airlift performance front/rear struts, 3/8 lines, dual 444c compressors, seamless 4 gal tank, airlift second compressor harness.
    As for the tank, I would prefer the 4 gal but because of fit if I decide on the 2.5 gal, how will that affect operation? Also, could I fit (2) 2.5 gal tanks?
    Outside of that I would like to get the because bags bracket and the ash tray delete for the controller.
    Currently running VMR 710 19x9.5 et 33 with 275/35/19 tires.
    Thanks to everyone that’s posted already. Been a huge help in figuring this all out.
  33. #1513
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    Quote Originally Posted by Gusman1 View Post
    More camber or trimming the plastic fender lip with a dremel.
    Has anyone actually trimmed the allroad fender flares with a dremel? That's what I'm thinking about doing.
    Sent from my motorola razr (2020) using Tapatalk
  34. #1514
    Sep 06 2017
    05 Subaru LGT (HTA71)
    MA
    Quote Originally Posted by djnuge View Post
    The shop that installed my air lift kit did. I know more than a few others who have had it done on theirs as well
    > S4 Swapped B8 Avant <
    > 2015 Glacier White allroad P+ (RIP) <
  35. #1515
    May 15 2015
    Quote Originally Posted by Allthea View Post
    Do you have any or can you take some pictures of what it looks like?
  36. #1516
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Almost done with the install... should have some nice rainy pics this afternoon
  37. #1517
    Sep 06 2014
    Ottawa, Canada
    Has anyone heard anything about ACCUAIR coming back? Someone buying their tech out and getting it on the market again? I really wished I had bought their CVT solution ... :(
  38. #1518
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Quote Originally Posted by cybernet99 View Post
    They were picked up by some company. I’ve never heard of them but I think they make oem air applications. There’s an article posted on bagriders
  39. #1519
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Can someone post a pic of their rear bags? My installer said they didn’t need to cut a hole but everywhere I’m reading it’s needed
  40. #1520
    Sep 25 2018
    Farmington Valley CT
    What is everyone running for PSI at ride height? I ride at basically 0 finger gap, 80 PSI in the fronts 74 in the rears. Damping in the middle
    Back when my Jetta was bagged, i ran at 40/45 psi all around. While the ride in my allroad isn't awful, I feel like i should be running a lower psi and take away the bit of bounciness. Basically raise the struts, to run less PSI and maintain ride height.
    2022 RS5 Sportback
    Navarra Blue Metallic
    Dynamic & RS Design Package | KW HAS | 20x10.5 BC Forged HCS04S
    instagram | @rs.k9ine
