Results 1 to 40 of 51
Thread: Rhino Ramps
    Apr 04 2012
    MSP
    Rhino Ramps
    I'm about to order a set... the 12k rated ones...
    http://www.amazon.com/dp/B006EGAIII/...75M8S0EW&psc=1
    Just want to make sure the front lower lip will clear them... I'm on OE's.
    Anyone lowered (on OE's or similar) use these to get the front end up? I know the rear will be no issue.
    Thanks gents... (and ladies...)
    Veteran Member Four Rings svander's Avatar
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    I bought the 16K lb capacity ones just to be sure and they work just fine. I've only backed into them but they would definitely clear the front end on my car, which is lowered on KWV2s.
    Apr 04 2012
    MSP
    Thanks - that's all I need to know... :)
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    I realize I have a different set: http://www.amazon.com/each-Rhino-Ram...ds=rhino+ramps
    But, they both say 17 degree incline. I'm lowered on OE's and I do NOT clear to pull forward onto them and I haven't even installed my front lip yet.
    2022 SQ7: P+, Daytona Gray Pearl/Black, Alu Optics, Ambient Lighting Package, Extended Leather Package
    Audi All-Season Floormats/Trunkliner, Llumar CTX 35%
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by VR2V8 View Post
    i have these and have never been able to pull any of my cars up on them, was a waste of money for me. I do use them after i jack my car up, i place them backwards under the wheel then lower the car back on them to hold it up. If you must have a set of ramps, invest in some race ramps.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Aug 27 2008
    Houston Area
    Quote Originally Posted by MrFunk View Post
    With OE's I hightly doubt it ... even my 4x4'ish stock 2013 S5 w/ADS dampers ride hight requires a 3/4 piece of plywood in front of my rhino ramps to keep the front bumper from hitting. Any amount of lowering and I'd hit...
    Feb 25 2013
    MI
    I'll check which rhino ramps I have. I'm able to drive up them without problem. Very useful tool!
    Sent from my SCH-I535 using Tapatalk
    Apr 04 2012
    MSP
    Hmmmmm ok... might be worth it for the rear only to get to the rear diff mnt and exhaust work...
    I'll look into race ramps...
    Oct 14 2012
    Empty...for now...
    SE PA
    I have a set of Rhino ramps with a sticker saying "Do not exceed 3000 lbs each, or 6000 lbs per pair, or 12000 lbs gross vehicle weight", so I'm not sure which "rating" they areas far as what is advertised on the packaging, but I can easily say that on H&R OE springs and 255/35/19 front tires my stock front bumper will hit the ramps before my tires get onto them. It's not by much, but it'll definitely hit.
    SOLD 2015 Daytona Gray S4
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    I have the HD Rhino Ramps and they work ok. I use them for everything from my S4 to my Excursion. The only issue is they slide on my wood floor and need to screw a block of wood to keep them still.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by MerkurRS View Post
    Good point, mine slide on my driveway surface as well. When I am backing onto them they tend to slide a bit when the tires first hit them. Then when you get to the top and hit the built in wheel chock at the back end, it slides again (but that's probably a good thing).
    Sep 23 2009
    '12 Audi S4, '13 Infiniti JX
    Houston
    I just put a 2x6 in front of them for extra clearance.
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    They work just fine.
    May 13 2011
    2015 BMW F30
    Yes they do the job.
    | Autospeed | JHM | Pure MS
    Veteran Member Four Rings PsYkHoTiK's Avatar
    Aug 23 2010
    Redmond, WA
    The 16k ones don't clear a stock RS5... :( It was close though. A piece of wood before the ramps helped. But once I lower the car on coilovers, no dice.
    Current: 2022 Audi RS6 | Ultra Blue | 034 Lowering Links | 034 Resonator Delete
    Old: 2017 Chevrolet Corvette Z06 (Z07) | Blade Silver
    Older: 2013 Audi RS5 | Sepang Blue | Eurocode Alu Kreuz | 034 Transmission & Rear Diff Mount | Apikol Diff Mount | Girodisc 380mm Rotors | H&R RSS+ | SPC Upper Control Arms | H&R sways | AWE Track Extreme exhaust
    Olderer: 2011 Audi B8 S4 | Ice Silver | DSG | Sport Diff | APR 93 stage II+ V2
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    tried to pull up onto these at my buddy's.. not even close, but my cars are pretty low. i needed a few blocks of wood to extend the length of the ramp.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Apr 04 2012
    MSP
    LOL... I guess I'll just have to see then... seems there's a mixed bag here.
    Veteran Member Four Rings mattchat's Avatar
    Feb 12 2012
    2014 Honda Odyssey - Touring Elite
    Calgary
    Our car has a pretty short front end, even with my OEs I can get on them just fine. My Accord Coupe's nose was really long and lowered on Honda Factory Sport suspension and I couldn't get to the wheels from the front. Love this car for even the simple things!
    2013 S4 - Monsoon Grey - 6spd - ADS - Carbon Atlas - Magma/Black Int.
    Mods: RS5 Red GT front and rear brakes, VMR v710 19x8.5 w/ Mich PSS (S), Audi Ti 19x8.5 w/ Pirelli Sottozero (W)
    AWE + RES DP exhaust, AWE Carbon S-FLO, P3, Eurocode Meisterwerk ASTS, eCode headlights w/ ZKW clear lense swap + Philips Xtreme
    KW HAS, Eurocode USS, Alu Kreuz, DEVAL C/F rear Valence, Black Op Front Grill w/ Chrome Combo, Folding Mirrors
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    If you are in no hurry put the ramps in your wishlist and keep an eye on the price. A few weeks ago the price was in the mid 30's with free shipping and just went up almost $10 over night. I am waiting till the price goes back down to purchase.
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
    Veteran Member Four Rings achilleas101's Avatar
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    man, you have so little room for error with those ramps. i have a set of the 8000s, and not only is the sliding a problem, but they're not wide enough to hold the entire 255 tire (which you can see on svander's pic). You have to be absolutely perfect going on them. The final straw for me was when a buddy of mine came by and we tried to get his Camaro on there. one of the ramps kicked out, which scared the crap out of both of us. Luckily no damage was done to the car.
    I ended up building my own. Pretty straight forward if you have any wood working skills at all.
    Gone but not forgotten:
    2013 S4 Imola Yellow | Black leather/Silver Alcantara | 6MT | B&O | Sport Diff | Silver 19x8.5 Avant Garde m550 | XPel Ultimate full hood/fenders | Eurocode SS
    2003 A4 3.0 6MT;
    1998 Acura Integra GSR 5spd
    Gone and most likely in a junk yard somewhere: 1990 Toyota Tercel
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    Quote Originally Posted by achilleas101 View Post
    They hold the whole width of the wheel just fine. I just was a little off on that side. These are also 10" wide wheels for what it's worth.
    The ramps come with a rubber insert at the beginning of the ramp that makes it have good traction once the weight of the car is on them.
    I do recommend them. I'm decently low on KWV2s and the car went in with almost no clearance on the lip, but went in just fine.
    Apr 04 2012
    MSP
    Nice home built ramp! I don't have the space to store such wide large ramps. I like the Rhino's cause they slide in on top of the other... (no dirty jokes!).
    I've got them in my WishList and will grab em when they drop back down... not that it matters all that much... I won't need them for a while as I'm still traveling for work...
    Apr 28 2014
    austin/tx
    I bought these from O'Reilly's for about the same price. No clearance or slippage issues.
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    thanks.. but they don't take that much space. i store them standing up. They're about 18" wide and 7" tall, so they take up less than 2' x 2' area of floor space.
    2003 A4 3.0 6MT;
    Established Member Two Rings COLO S4's Avatar
    Sep 20 2013
    Colorado
    Advance auto parts has them for $35 with promo TRT30.
    2010 Sprint Blue S4 l DSG l Sports diff l Black nappa l Nav MMI l AG M368 19x9.5 ET40 w/Mich PSS l Stasis tune/exhaust l RS4 grill l Injen intake l Alu Kreuz l LED interior/plate/reverse l Ziza platinum fogs l JL sub/amp l 8.5 pedals/shift knob l 20% tint/vinyl wrap l SOLD
    Oct 04 2012
    Berthoud, CO
    For those folks needing ramps with lowered cars, try http://www.reverselogic.us for ramps. They're designed specifically for cars that are lowered. It's an excellent product!
    In addition, he has the lug insert tools to aide in wheel installation for easier fitment
    If enough people are interested (in either), I might be able to ask him for a group buy? (I know him well)
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    420$ for a piece of reinforced plastic? No thanks lol
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Apr 04 2012
    MSP
    I got the Rhino Ramps - found them for $30 new on Craigslist.
    Rear was no issue.
    Front was very tight... Prob would have worked fine... My garage has a 1 inch lip at the threashold which worked out perfectly. I put the ramp ouside up against the lip (with the car in the garage) and I rolled out onto the ramp... presto!
    These will be my next ramp purchase for sure:
    http://www.bridjit.com/home
    Apr 11 2012
    the bridjit is awesome, couldn't have lowered my car without it! got mine from amazon, free shipping with prime
    After reading all the reviews on Amazon about Rhino Ramps slipping and cracking, that was enough for my paranoid ass to pass on them.
    Veteran Member Three Rings vwong's Avatar
    Apr 03 2006
    '10 S4, '09 335i, '98 Prelude
    That looks like a big ramp.
    I built a set probably over 10 years ago, and I'm still using them now.
    2010 Audi S4 6MT
    2009 BMW 335i Coupe 6MT
    YouTube Channel
    May 13 2011
    2015 BMW F30
    who needs ramps?
    But seriously if your car is slammed you can make a short ramp that then transitions to the Rhino ramps for less than $400.
    sent using samsung w/ quattro
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by oascom View Post
    $228 on Amazon. Still not cheap but they are very high quality and the two piece design provides a little more side access to the underside of the car. They are not injection molded but made of a very dense foam.
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    Quote Originally Posted by vwong View Post
    yeah, i'm a little paranoid. wanted to make sure i had plenty of f*ck up room.
    2003 A4 3.0 6MT;
    Senior Member Three Rings migo1980's Avatar
    Sep 05 2007
    Raleigh, NC
    Heres mine... also have the extended race ramps which work great.
    Apr 11 2012
    Quote Originally Posted by migo1980 View Post
    Heres mine...
    Winner!
    Mar 16 2011
    '11 S4
    Seattle Metro Area
    I should add, with the Deval carbon fiber lip, I can no longer get the car up on these. :(
    Veteran Member Three Rings Francois's Avatar
    Mar 26 2007
    Montreal, Canada
    [IMG][/IMG]
    No space on floor, just hang...
    MontrealAudiClub membre #3
    S4 Premium 2011, 19", Meteor Grey, 7 speed dual clutch S-Tronic, black Napa, MMI, black optic, advance key, advance parking system with camera, side assist and more.
    Previous: TT S-Line 2012, Mag Ride / A4 Sport Package 2003.
    Apr 04 2012
    MSP
    I see you value your S4 more than the Vette!
    Sep 05 2007
    Raleigh, NC
    Vette was leaving that day for its new owner. Depends on what day you asked me as to which I liked more.
    Sent from my VS980 4G using Tapatalk
    Oct 02 2013
    Redstone, CO
    You guys are using these ramps for what purpose? Can you do MX on the car with that little ground clearance?
    2014 S4 Estoril Blue, Black Opt, 19" Rotor, Side Assist, Carbon Inlay, B&O Sound, MMI/NAV, Rear Camera, Advanced Key, Supercharged badges, H&R OE, Track+ Spacers, 10/15mm, otherwise stock.
