Results 1 to 23 of 23
    Dec 30 2013
    Australia
    How many miles / km can you get out of a 1.8T before you start running into problems?
    I bought mine at 130,000kms and had the timing belt, water pump, thermostat, cam and crank seals replaced. Also had a new clutch put in.
    Just wondering how many km's you can get out of these engines before you start running into trouble.
    I know with Ford Falcon's (here in Australia), you can get 1,000,000kms out of some of the engines without the head ever having to come off. Timing Chain also lasts the life of the engine. Ancillary components like Alternator's and Starter Motor's go but the engine itself is good a 1,000,000kms properly maintained of course.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    somewhere between 50,000 kms and 500,000 kms
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Dec 30 2013
    Australia
    Quote Originally Posted by Avant Nate View Post
    That is a great input
    Senior Member Two Rings kingDL's Avatar
    Mar 17 2011
    Sweden
    The answer on your question is: It depends.
    It depends on how you use the car, how often you use it and where you use it. Say a taxicab for instance, it will see loads of miles and may not require any major repairs even after 400.000 km or more, especially if it is run 24/7.
    1000 miles on the highway at constant speed vs. 1000 miles in the city is also two different stories.
    So you could propably find an 1.8T engine with 50000 km's on it that is in a worse state than a 1.8T with 300000 km.
    2009 A6 Avant 3.0T
    Apr 01 2011
    B5 on jack stands
    charlotte
    I know of a member on here who has over 250k on his
    Pers like a kitten.
    As far as the ford falcon...it better be able to get 1,000,000,000km on it..
    That's mad max's ride! And that's with out changing the oil!
    Mar 17 2014
    2000 gmc sierra
    Ontario Canada
    I got 338758km runs mint no leaks no ticks no lights but the previous owner bought it with 20000km and sold it with 306000 and had it less then 3 years
    Jun 30 2008
    Erie, Pennsylvania
    I will say that most normal "non-enthusiast" owners cannot get a 1.8T to 200k miles without having the oil pickup screen clog up. So at some point before 200k, either they grenade the engine due to lack of oil pressure, or they shut it off in time and need to have the pan dropped and the pickup cleaned out.
    Mar 17 2014
    2000 gmc sierra
    Ontario Canada
    I wanna do my screen before she clogs on me I change my oil so much to try to keep it clean
    Senior Member Two Rings g3no's Avatar
    Oct 14 2013
    2001 Audi B5 A4 1.8TQ
    Santa Barbara, CA
    Was not aware of that.. I will definitely get that taken care of my next major maintenance round.
    2001 Audi A4 Quattro 1.8TQ: LED Interior Swap - Kenwood DDX470 Headunit - 12" JBL Sub - JBL Amp - 5000k HID Fog Lights - 034 Street Density Motor Mounts - LED Taillights - H&R Sport Springs - Bilstein Shocks - 6000k HID Headlights
    Dec 12 2012
    Niagara Falls
    g3no, that's pretty major service to do just that. Read the how to threads on that job.
    2000 B5 ATW 1.8T Quattro Manual
    Oct 14 2013
    Santa Barbara, CA
    Quote Originally Posted by Wraith600 View Post
    My car is just about to the 100k mile mark. Do you think it would be a good idea to get it done ASAP? I was thinking the 125k mark, but I did buy it at 84k so it would be nice to have a clear mind about that. Who knows how well the previous owner was as far as oil type and frequency of changes....
    Jun 30 2008
    Erie, Pennsylvania
    It is a little involved to clean it. I really wish Audi had made the oil pan a 2-piece affair so dropping the bottom would be super easy, like the 2.8's. Then you could just clean the screen every 50k and never have problems. But that makes too much sense.
    Anyway, due to the involved nature and the high cost of labor, I would rather suggest you just check your oil pressure. It is pretty easy to spot a partially clogged screen just by looking at the pressure behavior.
    If you are really in it for the long haul with a 1.8T, I'd recommend just putting an oil pressure gauge on the dashboard.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Walky, is hot idle oil pressure the key number? I'm seeing 20psi at hot idle, I know RenoxDeception is only seeing about 12psi. My concern is that I've never seen more than ~80psi at 5k RPMs while hot, I remember you saying you could peg your 100psi gauge.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Oct 14 2013
    Santa Barbara, CA
    That would be good to give me some piece of mind, but it sounds like it is going to clog eventually so wouldn't it be a good idea to get it taken care before it starts showing real symptoms?
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    At hot idle I have 25-27psi, I peg the gauge (or get close) at 5k when hot.
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Mar 17 2014
    2000 gmc sierra
    Ontario Canada
    Wats ur gauge read tho pbcrazy
    Feb 06 2013
    VA
    Quote Originally Posted by Drifter420 View Post
    I'm not sure I understand the question but I'm guessing your asking how high it goes? If so then 100psi
    Jul 27 2011
    IN
    I will say that most normal "non-enthusiast" owners cannot get a 1.8T to 200k miles without having the oil pickup screen clog up. .
    This is new info to me. I thought if we do regular oil changes with VW recommended oil+ big filter, chances of sludge buildup can be avoided.
    Sounds like this can happen anytime with my car which is at 250K even though I'm changing oil every 3k miles..
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    How many miles / km can you get out of a 1.8T before you start running into p...
    Quote Originally Posted by lm0812 View Post
    Since I bled my coolant system I've been seeing 14 and getting no CCT ticking, I'm still going to pull the pan soon. Interested in Walky's response.
    Mine peaks at 92 probably while it's cold though :-/
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
    Jun 30 2008
    Erie, Pennsylvania
    Idle pressure is important, but it is somewhat variable depending on your pump and bearings, etc. Here is a post I made a while back on pressure testing and detecting a clogged screen:
    This is how I test oil pressure on a 1.8T:
    - Make sure it has correct 5W-40 oil.
    - Get the oil screaming hot. 200F+ (warmup then drive aggressively for several minutes)
    - Throw a pressure gauge on it.
    - Take readings at idle, 1500, 2k, 3k, 4k, 5k, 6k.
    - Take those readings again.
    - Pressure should go up with revs, never down.
    - Peak pressure should be near 100 psi as you approach redline.
    - If pressure dives with revs = clogged screen
    - If pressure doesn't get past 60psi when hot = clogged screen.
    - If pressure is lower than 20psi at hot idle = clogged screen. (15psi is borderline, should really be 20+)
    - If pressure is lower on the second set of readings than the first = clogged screen.
    - If peak pressure keeps getting lower each time you rev it out = clogged screen.
    - If pressure falls when held at a specific RPM for some time = clogged screen.
    80psi peak is plenty of pressure for operation, but it ought to be a bit higher. I probably wouldn't drop the pan unless the peak lowered, or if there were other symptoms as described above. Unless the engine was out for another reason.
    Veteran Member Three Rings Toolaa's Avatar
    Aug 03 2013
    2004 A4 Quattro 1.8T
    Ellicott City, MD
    All great advice. It is a good idea to keep a log of your results. The perhaps every 6 months repeat the test and compare. If you see the new results dropping over time you would have a better idea of whats going on inside of your engine. Also it's really cheap to pickup a compression tester from Harbor Freight or Amazon and also take a baseline test. Then if you do begin to experience any unusual problems in the future you can at least compare the new results with your baseline.
    Good luck!
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by woolveren View Post
    Yes, sludge is avoided - but the key being regular oil changes with the correct oil. Most "normal non-enthusiast owners" don't even know they have a turbo, let alone that their engine is extremely demanding on it's motor oil. Said owners get their oil changed at the Jiffy Lube whenever the ~10k "Service Oil" message displays on the dash and call it good.
    Even if taken care of well, the screens do have a tendency to clog anyway. The low oil volume, superheating from the tiny turbo, and very small passages in the screen all work together to help it happen.
    Dec 30 2013
    Australia
    I'm on about 243k now I think and still going!
