Everything was working fine.
Then I removed the cluster to clean it. I plugged it back in and went to start the car. The engine ran for about a second and then cut off (due to immobilizer I assume).
It now reads "SAFE" on the instrument cluster, where total mileage is normally shown.
The car is stock. Original cluster. Original keys.
No matter what I do, it stays in "SAFE" mode.
Things I've tried to no avail:
-disconnect battery for 10min, connect leads to drain residual power
-turn key to on position, with battery connected, for 10 seconds. Repeat 5 times
-check cluster connectors for bent prongs. All OK.
-made sure both cluster connectors are pushed in tight
-scan and clear DTCs
-checked 10amp fuse in drivers side fuse box, position 15
It doesn't look like I can connect to 25-Immobilizer via VCDS
Any ideas?
