Results 1 to 22 of 22
    Dec 25 2004
    Earth
    J293 Cooling Fan Control Module
    Replaced my Rad Cooling fan control module...8E0959501D
    Now when I turn on the a/c the rad fans are running on high...
    Replaced the high-pressure switch...same
    Do the fans turn off above 2500 rpms?
    The old module was a "D" the new an "AG'...
    My system worked fine until new module...
    Anyone have simular issue?
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    When my green temp sensor failed it ran my fans full blast. Which then fried the fan control. Worked perfect after replacing both green sensor and fan control (the higher wattage one).
    Did you replace with the higher wattage module or the lower one?
    What was the reason to replace the module?
    Sent from my SCH-I645
    Daniel J
    @gtg_drives
    Aug 26 2005
    either the ECU is commanding the fan to run on high, or the wiring is connected so that a false command is being sent to the control module or the fan module is defective.
    Vorsprung durch Technik
    Dec 25 2004
    Earth
    It only runs on high with a/c on...
    The fan module is brand new...from Audi dealership....
    Guess I can try the green temp sensor....
    But it worked fine before fan module replaced....
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Quote Originally Posted by MikTip View Post
    Ah, I don't think it is the green one. I missed the only on with a/c on. When my temp sensor was bad it ran with a/c off also. Are both fans going nuts or just one?
    I just went to the store and right when I started the car up with the A/C ON the a/c fan immediately kicked on and ran until I reached the end of the street. (1/4 mile)
    Maybe it is just an ambient temperature setting and it is functioning normal.
    My fans also kick on for a second after shutdown. (Like some sort of test)
    Daniel J
    @gtg_drives
    Dec 25 2004
    Earth
    Im curious is the newer fan control module makes my fans do what they do and if get a signal to shut the fans off at a certain mph and or rpm?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Both of my fans turn on immediately when I engage the A/C. This occurs even on a cold start. The block does not have to be up to temperature.
    Dec 25 2004
    Earth
    Do you have the 8E0959501AG fan control module?
    My old 8E0959501D fan control module did not do that...
    I also bought a new high pressure sensor and replaced it but both fans come on and stay on while the a/c is on...
    Dec 28 2006
    Western Maryland
    I just checked and the part number isn't visible without removing a few components. I'll see if I can get to it after work tomorrow.
    Dec 25 2004
    Earth
    Thanks Old Guy!
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    I dug through my receipts and Audi didn't put the part # on the part invoice. Like old guy I can't see the # either.
    Daniel J
    @gtg_drives
    Dec 25 2004
    Earth
    Considering the issue didnt exist until I changed the fan control module....makes me think the new module was bad....
    Need a known good one to install and verify...
    Feb 17 2004
    Liberty Hill, TX
    Mike, what led you to replace the original (-D) module in the first place? Pretty sure my -D module has the fans running on high as soon as the A/C is switched on if at idle
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Dec 25 2004
    Earth
    Quote Originally Posted by Matt Devo View Post
    My large fan was getting worn and its plactic blades began to rub the surrounding housing and make odd noises...
    So I decided to replace both my 10+ year old fans.
    While splicing in the new wires one of the electrical terminals of my old J293 broke off, so I bought a new one.
    According to Audi..the "D" was no longer available and superceeded to the "AG"...
    Prior to me installing the AG, my D version never ran the fans when the a/c was first turned on and then kept them on all the time, like the AG is doing now. The D would cycle the fans dependant on the high pressure switch...on...off...
    This prompted me to replace the high pressure switch(thrust sensor) but it didnt fix it...
    So now when I turn on my a/c the fans are on high all the time the a/c is on and do not switch off unless I turn the a/c off.
    I'm going to break out the volt meter this after noon and further trouble shoot.
    Its just odd my system worked fine prior to new J239 and now has this issue after...which would make me believe the new fan control module is bad...no setting I have found via VCDS to change...
    I have another one coming in a couple days to help trouble shoot...as well as the accociated temp sensors.
    Hopefully the volt meter will help pin point the issue.
    Dec 28 2006
    Western Maryland
    Here ya go. Both of my fans come on when I turn on the A/C regardless of the block temperature.
    [IMG][/IMG]
    Dec 25 2004
    Earth
    Thanks OldGuy!
    Dec 25 2004
    Earth
    According to two different Audi techs the fans on with a/c on and they stay on is normal with the newest fan control module....
    Feb 17 2004
    Liberty Hill, TX
    Mike, I just replaced my old -D part with a new -AG part. My fans come on as soon as the A/C does, but not on high. My fan used to come on high w/AC on as soon as I pulled into my garage, or stopped moving after driving; now it doesn't with the -AG part. Engine also seems to come up to temp a lot quicker (~2 mins) as well.
    Dec 25 2004
    Earth
    Thanks Matt.
    I cannot find confirming info on the AG control module...but 2 separate Audi dealership mechanics I spoke with stated
    It makes the fans come on with the a/c and they stay on all the while the a/c is on.
    Me living where its over 100+ degrees....seems to help.
    I was just use to the fans being regulated by the a/c thrust sensor on my previous
    Fan control module...
    I actually bought another AG control module for testing and it did the same.
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    Howdy gents - when you did the 8E0959501D to 8E095950AG replacement, how did the wires line up? just color code them even though they are on different locations on the FCM?
    034 HFC, StopTech SS Lines, B7 Interior Upgrade, 034 Silicone Vacuum and PCV Lines
    Jan 25 2011
    Philly
    replying back to my own post - yes just line up the colors and you are good to go
    Jan 24 2010
    Paramus,NJ USA
    Running both fans on high with A/C on is normal operation.
    Ziddy Autowerks
