Originally Posted by
MESSY1
What are ur thoughts on the install then? I like the adjustability aspect of the ride on the fly and lowering capabilities although I only want a 1/2" lower stance than stock. Will they warranty the product if installed on a RS5? Guess I have to make the call myself. Is it worth it?
US Spec vs Euro Spec suspensions on the RS5 have some differences. Someone else can correct me, but I believe the Euro Spec has a dynamic suspension and different standards for the front/rear suspension regarding collision. But, per Greg Fowler at Eurocode Tuning, the suspension does work. May want to ping him. Here's the link to the thread on the DDC suspension.
http://www.a5oc.com/forums/rs5-gener...coilovers.html
And this...
http://www.a5oc.com/forums/rs5-gener...lover-kit.html
Per the "on the fly" adjustability, I've seen a couple of those kits on BMW's and they're a nightmare. It's quite an extensive install and you better have someone that knows what they're doing. If they pull out the instructions for anything other than to look at the wiring diagram, stop and don't let them pass go. If you're going to track it, then you're probably better off going with one of the highspeed custom kits one of the posters discussed. None of those have adjustability via an app, probably for a good reason.
Ultimately, it's your car and money. There are plenty on here that are running standard coilover setups by H&R, KW and are happy with it. For me, I don't track it, so the uplift on a higher priced coilover kit wasn't worth it. I wanted to fill out the wheel gap and improve the handling, marginally vs Ohlins or Bilstein.
