Results 1 to 39 of 39
    Dec 26 2013
    Montreal
    Moro blue is an horrible color
    Hello everyone.
    I've done my home made USP front, but now I've come to the painting. I've got no idea how to paint this thing + grills. Seems like you can't give any contrast to the car because it's so similar to black. I've been looking on the internet and haven't found anything that satisfies me. I also thought about adding a front lip, but why? You won't even see the difference because black on moro blue is like black on black. Thoughts?
    I'm kinda sad I've got such a boring color!
    EDIT, what I thought is maybe paint the center grill grey as the front center grill?
    Veteran Member Four Rings daihashi's Avatar
    Apr 03 2010
    houston, tx
    Quote Originally Posted by gr4v1ty View Post
    Hello everyone.
    I've done my home made USP front, but now I've come to the painting. I've got no idea how to pain this thing + grills. Seems like you can't give any contrast to the car because it's so similar to black. I've been looking on the internet and haven't found anything that satisfies me. I also thought about adding a front lip, but why? You won't even see the difference because black on moro blue is like black on black. Thoughts?
    Who says you have to do black? Why not some like charcoal, anthracite, or gunmetal grey?
    Sent from my SGH-T999 using Tapatalk
    Dec 26 2013
    Montreal
    Mostly because it wouldn't match the rest of the car? Here are some pics before the USP front conversion.
    EDIT : I really need to change to those summer tire ASAP
    Apr 03 2010
    houston, tx
    EDIT : I reallt need to change to those summer tire ASAP
    You missed the point, change all the black grills and trim pieces to grey; easily done these days with plastidip. Your other option is to change the color of the paint, or just deal with the black blending in with the moro blue.
    Veteran Member Three Rings jalcom1's Avatar
    Feb 23 2009
    '01 S4, '69 Camaro SS
    IL
    The contrast doesn't need to 'pop'. It's not a Honda ;)
    Work out a full concept instead of adding color ad hoc. A little photoshop experimenting will go a long way
    - Jason
    Dec 26 2013
    Montreal
    I've been trying to look throughout the web to see what others have done but there isn't much to see. Most people have other colors!
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Quote Originally Posted by jalcom1 View Post
    congratulations, you have one of the most irrelevant and meaningless posts on AZ
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    You sure that isn't Ming blue?
    Sent from my SCH-I645
    Daniel J
    @gtg_drives
    Dec 26 2013
    Montreal
    Ming wasn't available on '05 models!
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Did not know that, thanks. I thought moro was a tad lighter while my 02 ming blue has a black/purple look to it.
    Daniel J
    @gtg_drives
    Feb 23 2009
    IL
    Quote Originally Posted by GrapeBandit View Post
    And your sage wisdom added what to this thread? Apparently you lack the maturity and intelligence to identify constructive criticism. Please refrain from being an asshat in the future.
    - Jason
    Dec 13 2010
    FL
    This is all my sage wisdom can add to this thread! Sorry, i will refrain from being an asshat in the future.
    well said sir!
    Dec 26 2013
    Montreal
    Sun only will make you see the difference between these 2 colors! Oh and saw a moro blue with grey and it's awful.
    Please stay on topic
    Dec 13 2010
    FL
    you can contrast, but it would have to be a light color. its not going to happen with black, thats for sure
    I say forget trying to contrast the body. paint match all the lowers and contrast it with wheel color
    Feb 23 2009
    IL
    My car, OP. Moro blue isn't that bad ;)
    - Jason
    Dec 26 2013
    Montreal
    The color is fine, but you can't play with it much...
    Can I see a pic from the front?
    Veteran Member Four Rings singleframe's Avatar
    Apr 24 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    oooh das nice! blue ain't so bad after all!!
    OP -- get some aftermarket wheels. it'll change the whole look.
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Veteran Member Four Rings JUSADUB's Avatar
    Mar 10 2009
    Gig Harbor, Wa
    Sounds like you need to find someone who knows how to paint. Moro blue is a nice blue.
    BrownBag on vwvortex
    USP CLUB MEMBER #142
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Feb 12 2008
    Michigan
    Flat black will have contrast and be noticeable, it was on my brilliant black car. You could also carbon fiber vinyl wrap te grills and lip,
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    More engine bay pics
    Ed
    why say lot word when few word do trick.
    Sep 10 2011
    None
    Moro Blue is a fantastic color. OP, don't be an idiot.
    Jan 24 2008
    Pennsylvania
    I may be a little biased, but I like it. It shows differently in different light. Low light it looks dark blue, bright light it looks almost purplish, and at night can look black.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Apr 23 2012
    statesboro ga
    have I missed the reason you wont paint it to match the car? you already have painted lowers. just painting the USP flat black or any other color would look like crap imo, or painting all lowers to match the usp flat black or whatever color would be downgrading imo. seems like the only option is to color match it.
    Feb 12 2008
    Michigan
    Jusadub, how you get your high beam yellow? Is it a yellow ecode bulb reflecting? Looks cool
    Sep 10 2011
    None
    This pic describes my sentiments for this thread. Lol
    Quote Originally Posted by Fast4esT View Post
    They're Depo ecode repros. He took them apart and painted the reflector.
    Quote Originally Posted by Turbavanttro View Post
    Very nice avant, sir. Bravo!
    Mar 10 2009
    Gig Harbor, Wa
    Quote Originally Posted by CrazyCal View Post
    What Cal said. Also I do have a yellow city and high beam bulbs.
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Aug 27 2013
    Philly
    Quote Originally Posted by JUSADUB View Post
    I think I may do this with my 3.0. I have yellow fogs which I love but having yellow high beam reflectors would be cool. How is the visibility when using the Highbeams?
    Jan 24 2008
    Pennsylvania
    Thanks! I feel like it's my second child
    Dec 19 2007
    York, PA
    those rs4 reps are horrid...
    Dec 26 2013
    Montreal
    I think I'll paint it the same colour then. I'm sorry if I offuscated some persons but I prefer other colours then moro blue. That's why!
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    Your attention to detail is so masterful.
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    Quote Originally Posted by n7plus1 View Post
    Feb 23 2009
    IL
    Thanks. They're for sale. I'll use your comment as marketing.
    18" rs4 reps. n7plus1 thinks they're horrid. Best offer
    - Jason
    Dec 19 2007
    York, PA
    lol, im blunt...sorry. i dont know why anyone would buy any other rs4 rep other than VMR's...its the only one with the proper concavity.
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    Joooe Mamma!
    Established Member Two Rings Ghostrider's Avatar
    Jan 31 2007
    86 Alfa GTV6, 91 Toyota HDJ80 Land Cruiser, 2005 Miata, 2020 Miata, and Lexus GX 460
    Charlotte, NC
    What's your point in this meaningless drivel??
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    I only wish my car was Moro Blue
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
    Feb 23 2009
    IL
    Meh, no harm. I bought these off the AZ classifieds a few years back. They look like Hartman's but I honestly don't know the manufacturer. Just bought a set of Enkei RPF1's last weekend.
    - Jason
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    Quote Originally Posted by Ghostrider View Post
    ^this x1000
