The ignition was off and key removed and the headlight switch was turned off as well and it still does this...
It burned out my bulb on that side. I swapped one of my old bulbs in. Still flickers.
I unhooked the bulb on that side and ordered a used, good condition ballast. Swapped the new ballast in tonight and found no change. The bulb continues to flicker in the same fashion.
I wanted to see if the issue was isolated to the headlight unit itself or elsewhere in the car, so I removed my passenger headlight, swapped both headlights entirely by flipping them upside down (to match the plug) and plugged them both in. It continues to be the driver's side that has the issue. Likewise, the swapped driver's side headlight unit (to the passenger side) had no issue. So that means the issue is elsewhere in the car/wiring, but isolated to only the driver's side.
What could be causing this?
Headlight Switch?
Wiring?
Central Electric Control Module, aka "Onboard Supply Control Unit"?
Discovered that here when finding out that headlight relays can be responsible for flickering, then.... found out HERE that the B6 doesn't have any headlight relays. They have a Central Electric Control Module instead.
