Results 1 to 28 of 28
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Bird droppings causing paint damage in record time!
    The other day my car got some bird droppings while I was at work. As soon as I got home I cleaned it off with soapy water and a wash mitt and the darned poop left a mark on my paint! What are these birds eating these days? My old B7 could defend against such poop better than my B8!
    Anybody here get this and if so, did you have any success getting rid of it?
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Yes buy goo gone an microfiber an do circular motions it will go away an then wash that area an call it a day :)
    Aug 10 2011
    North Whittier
    Cool, let me try that right now. I got some goo gone handy, not to be confused with goof off, which is almost as deadly to your paint as these bird dumps.
    Dec 01 2011
    Quote Originally Posted by doowopaudi View Post
    what really!? i thought they were the same thing? i've used both on little spots before with no issues, or at least i hope i didnt mess it up, does it thin out the clearcoat or something?
    IG @theshawon
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Quote Originally Posted by dalmation53 View Post
    Ahhhh, if you love your paint no circular motions! You're buffing poo into your paint. Soak with water (lay a damp paper towel over if you need to) to re-hydrate it, after a minute or so, either with the paper towel on the poo or with a new sheet, lift the poo off with a pinching motion. Repeat until done. Then get out the quick detailer and MF cloth...give the whole area a spritz then buff off.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Aug 10 2011
    North Whittier
    Quote Originally Posted by Liquid Smoke View Post
    I once used goof off to debadge my b8 and it ate right through the paint. Goo gone is natural and safe while goof off is made with harsh chemicals.
    Aug 19 2013
    Miami
    Yeah I do not use goof off it will mess up the clear coat us Goo Gone it is safe for your paint.
    Established Member Two Rings Hagasan41's Avatar
    Sep 16 2013
    Orlando
    Looks like it etched into your paint. If the suggestions above have little to no effect use a mild polish and then re-wax the area with a good wax or sealant to protect it. And yes I hate birds!
    And yes, Goo Gone is very different than Goof Off. Goo Gone is citrus based and Goof Off is not. It's made of xylene and tolulol which are 2 very strong chemicals and petroleum based. Not good for use on paint as the chemicals are found in paint thinners.
    Nov 15 2010
    ripon
    It's not what the birds are eating, its the quality of paint that has changed. In order to save the planet all new cars are painted with water based paint as the solvents in paint from years ago is causing our planet to slowly die.
    The fact that China and India are pumping thousands of tonnes of god knows what into our rivers and skies is not important...................
    Dec 08 2012
    Moldova
    Zafi yea, you are right the water based pain quality is quite bad, but regarding India and China... you know... if your neighbor is an asshole that really doesnt make the case for you to be one ;-) No offense.
    Audi A4 B8, 2.0 TDI. Retrofits: Bi-xenon. Front parking sensors with graphics. OEM Bluetooth. Servotronic - 1N3. Footwell lights. Color DIS. AMI. Audi Drive Select. EGR off. DPF off. 207BHP CAHA remap. Keyless Entry/Go. Lane change assist. B&O. Aux Heater.
    Aug 11 2012
    Beaufort, SC
    Didn't realize bird droppings could do such a horrific thing to our paint. I'll have to be careful cleaning up a mess a kind bird left me as well
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    Once you've etched the paint, you need a mild abrasive (as suggested above). I wouldn't jump to polishes. I've had this etching many times.....I've used McGuires Ultimate Compound with great results. I'd give that a shot.....since it;s available at pretty much any PepBoys or Autozone....
    Of course, the best prevention is a good sealant and a coat of wax on top.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Mar 26 2012
    Charlotte, NC
    I agree Water Base Paint is not as good as Oil or Lead based paint but it should not be this pathetic.
    Let me explain, in 2010 Lexus/Toyota started using Water Based Paint for every single model. My mom has a 2013 Toyota, trust me the paint is light years ahead of my Audi.... It's also the same color, when I compare the paint side by side, I would think my car was a KIA and the Toyota was the Audi. Then I step back and look with a surprise...
    Zero Chips, Zero Scratches, 500x more durable, etc etc. I have tried to polish a small scratch on my Audi using Meguiar Ultimate Polish and it messed up my paint... I did the same thing on the Toyota and it loved every bit of it.
    Please, don't try blaming water based paint. Germans need to learn how to APPLY water based paint before they use it.
    Aug 10 2011
    North Whittier
    Quote Originally Posted by Crucible35 View Post
    Quote Originally Posted by SDF1 View Post
    So in other words, Meguair's Ultimate Compound works on our Audis, but Meguair's Ultimate Polish doesn't.
    Veteran Member Four Rings QUA77RO's Avatar
    Jul 05 2011
    a few other cars and a hungry Akita
    just North of the Golden Gate
    Most likely it has nothing to do with what the birds are eating. It's typically water birds that have the nastiest droppings...seagulls are the worst offenders.
    Nor do I think it has anything to do with Audi's or "German" paint in general. It has more, in my experience to do with where you live.... I've had the same issues with Japanese as well as German car finishes in SoCal. Did you experience a very hot day the day that this happened? The longer bird deposits or any other dropping sits on your paint, especially on a hot day, it causes the water content to evaporate quickly. This has the effect of continually increasing the acidity (rather quickly) and it etches the clear coat. Left on, it will continue to keep going right through the clearcoat entirely leaving no choice but a repaint. In all the places, that I've lived in the world, Southern California was one of the worst for me with regards to this problem. It has not just intense heat but an extremely large population of seabirds that run deep into the interior on a daily basis to the landfills. In the evening, they make their way back to the coast. While maintaining a good wax coat or an appropriate paint sealant will help slow the process, the best bet is to try to get covered parking during the day (yeah, I know, not always possible) and carry a microfiber cloth and a good quick wax/detail spray in the car so that you can saturate them and then gently wipe/lift off these droppings ASAP.
    Best of luck
    "Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
    "Make the suspension adjustable and they will adjust it wrong — look what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver." - Colin Chapman, Founder of Lotus
    It is amazing how many drivers, even at the Formula One level, think that the brakes are for slowing the car down. -Mario Andretti
    Aug 10 2011
    North Whittier
    Quote Originally Posted by QUA77RO View Post
    Best of luck
    Good words. Yeah, I live in So Cal and it did happen to be a hot day. As for what the birds were eating, I was just trying to be funny.
    Mar 26 2012
    Charlotte, NC
    I did not apply the polish properly, I did circular motions that was very obvious in the sun light. Made the paint dull. With water and a buffer I was able to get it back to a gloss finish.
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    I had this exact problem a while back, i put the thread in the detailing section...see link below:
    http://www.audizine.com/forum/showth...aka-holograms)
    I researched a ton about bird droppings on paint and i found out quite a bit of information. Bird droppings actually have a seasonal change in intensity. In the spring Birds eat a lot of berries, these berries have a higher acid content which translates into a higher acidity in their droppings. This can have harmful effects on the clearcoat. To echo Qua77ro, the longer the droppings sit on your paint in direct sunlight, the harder it will be to remove the damage.
    I know some will disagree with my Megs DA polisher, but it works great. I tried goof off and it didn't do anything, the hologram was still there. I had to use a 2 step compound to polish to get the hologram off the clearcoat.
    M
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Active Member Two Rings lukej2429's Avatar
    Dec 26 2013
    2011 Q5 2.0T P+
    Duluth, Minnesota, USA
    Remove the bird dropping and then address the clear coat damage. Use Meg M205 first, if that doesn't work then try M105, if still nothing light wet sanding with 2500-3500 grit. Make sure to use a Dual Action Polisher.
    This link from AMMONYC will help you as well.
    http://www.youtube.com/watch?v=fgHd1twCHYM
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    ive got 3 bird shit spots on my hood. i swear this makes me wanna take out my KSG and shoot these crows/pigeons like skeets.
    lesson learned i guess.. dont let poop sit on the paint for days!
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    This happens to me even after sealant/wax. Doesn't matter if it's 1 day or 12 days on there. I've started carrying a water bottle in the car to soften the poo and wiping with a microfiber. Normally need to hit it with a compound every 4-6 months
    Oct 09 2008
    I've noticed it depends on the birds and how quickly it'll etch the paint. At my home, bird poops washed away easily and doesnt leave a trace. At my campus in downtown Seattle it etches almost immediately. It's to the point that where I wash the car the second I get home.
    The Awesome™
    Dec 01 2011
    ah the pleasures of not worrying about your paint.
    but actually my roof is still the factory paint, and i've got some etchings on there too, i've gotten tired of being anal about it at this point.
    IG @theshawon
    Apr 29 2017
    I Actually had GREAT success removing these with Mothers 1, 2, 3 step system. Came out great. I also bought Chemical Guys clay bar and did a bit of claying for some of the tricker parts. Does a really good job. FYI the carnauba wax that Mothers makes is great because in future instances the bird droppings won't stick to the paint as much [when it happens to me just water gets them right off].
    Jul 08 2015
    Quote Originally Posted by JoesB8A4 View Post
    clayed the watermarked spot..
    used turtles wax jet black kit.. no luck.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    After you get it off, maybe put a layer of TopCoat F11 on your car to prevent it from happening again. This stuff sounds awesome. I'm getting some soon.
    http://www.audizine.com/forum/showth...46-TopCoat-F11
    I'm as cool as a cucumber in a bowl of hot sauce.
    Senior Member Three Rings Richieru456's Avatar
    Apr 30 2017
    New Haven, CT
    How often are you guys washing your cars?
    Sep 19 2012
    Capitol Area
    Quote Originally Posted by Richieru456 View Post
    Once a week given the grime and street parking.
    2018 A4 | Mythos | Prestige | S
