Hey friends. My brothers b5.5 VW Passat which is a 2005 model year with a 1.8t AWM engine broke down on the freeway. We pulled it apart to find a siezed waterpump with a frayed timing belt. He turned the car off while it was running well and we believe the toe truck driver cranked it twice. We were able to order and install a metal impeller water pump, new tensioner which are installed and correctly tensioned. The belt is on, the marks line up to TDC after 2 full rotates which is one compression cycle.
The issue and question I have is about turning the engine over by hand. We have a 19mm 12 point socket connected to a breaker bar but it doesn't turn over as easily as I think it should. It turns in a inconsistent manner. At points it take 5ft lbs of torque which is smooth and at one point I measured 25ft lbs was required to turn it over. Im worried that there are bent valves which could amplify in damage once we button in up and start it.
Is it typical that turning it over by hand isnt exactly butter smooth?
I realize we dont deal with AWMs too much in this forum but I also realize that the AWM isnt too different from our b6 1.8ts.
Thank you for any help/advice.
