I should just make a simple how to for the Franken Turbo Manifold. Its really not too hard if you have the right nuts and tools.
Its still a pain but it is FAR more manageable if you use these nuts and not the stock ones. "8mm Copper Plated Steel Lock Nut, M10 Wrench Head"
http://store.034motorsport.com/produ...ench-head.html
They are 10mm heads which gives you way more room to move around. I used those in addition to the thick stock manifold washers.
I then bought a 10mm clawfoot wrench set from harbor freight. You them take that and grind down the edges to get rid of the excess metal... the round part. Make it into a sharp triangle on both sides. It will give you more room to wrench.
You then buy a wobble 3/8th extension which will give you more room. I don't mean the type with joints. I mean the type that wobbles on the head. I prefer the craftsman ones to the harbor freight ones but you can buy harbor freight if you need to.
http://www.searsoutlet.com/4pc-Wobbl...92&mode=seeAll
I also ground down the heads of my exhaust studs a little. Made it a little more easier. You have to take measurements of both the manifold and the nut height. Cheater way to get the height right of that is to put on the corners fully tightened down and then measure that point and shave down the other studs to that point. This makes it easier to do the center top ones.
Then put them all one and go in a circle tightening them down partially as you go in the circle till they all cinch at one time. Prevents being stuck without the ability to get to nuts.
Hope that helps.
