The standard design spec on those electrochromic mirrors, for reflectivity, is to operate between 70% refelctiveity (they can't achieve higher than that) and as low as 10% reflectivity (when there is max glare from headlight in rear).
Typically it's designed for non-privacy glass setup i.e. it uses rearward and forward facing photo sensors, comparing the difference on light input on two sensors and through an algorithm changes dimming level of mirror cell. IF you have dark tint on rear glass then (although not supposed to have significant effect), it can effect performance of dimming. Alternatively IF you have added any Drive Recorder, Antenna device or other in the area of Inner Mirror, which interferes with line of sight of forward facing light (photo) sensor, then that also will effect performance / speed and or amount of change of dimming.
It would be extremely unusual that there would be variation in build of Electrochromic Mirrors, which would perform differently than spec and intention - from a design / manufacture standpoint. There would be 'end of line' assembly test equipment that checks performance before packaging and shipping to vehicle manufacturer. Whether there might be external factors impacting the light photo sensors is another question. Alternatively, it could be that certain owners expectation of dimming speed has higher expectations than others ……which is very possible?:-( [If situation needed to change from max 70% reflectivity to say min 10% reflectivity then you should observe that change in couple / few seconds. IF car is already in light environment where, 'say', Mirror is at 50% reflectivity state and suddenly it needs to change to 30% reflectivity state, then the impact to Drivers sensing of dimming action won't be so drastic / so noticeable ].
Not sure that helps in any way to explain what you observe?
To some other members comment, maybe standard Prism Mirror with Day/Night toggle is all that is needed. Certainly there are many that think so:-)
Originally Posted by
Cooper993
Compared to my B5 S4 and other vehicles I have, the auto dimming rearview mirror in the B8 S4 sucks.
It takes a long time to dim, and it doesn't dim that much. It won't dim at all during dusk/twilight and only when it's total dark
Is it just me or are they all like that?
