Results 1 to 16 of 16
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Spark plugs NGK V-Power
    part number is BKR6E Stock No. 6962
    OK so My friend is saying this plugs only last 10k miles after that they will cut hell loose an start failing. I tryed searching for an hour to see how long they last couldn't find any answer.those are the ones i have in my car now, but want more info on them, (sorry for grammar at work, time is limited LOL) thanks guys.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by dalmation53 View Post
    That is the wrong plug for your car.
    Aug 19 2013
    Miami
    Oh damn really? whats the correct one?
    Btw is a 2.0T
    Aug 31 2011
    Lathrop
    Btw is a 2.0T
    That plug is too hot for your car.
    Are you tuned or stock?
    Aug 19 2013
    Miami
    Quote Originally Posted by Jake@JHM View Post
    I am completely stock i just saw this.
    HOT - NGK #6 (OEM Range for 1.8/2.7 Engines) - Stock car with stock boost/timing, or mildly-tuned car in cold climates.
    Recommended Plugs in this Heat Range:
    - NGK BKR6E (Copper)
    - NGK BKR6EIX (Iridium Version of the same plug above)
    - Denso K20R (Copper)
    - Denso IK20 (Iridium Version of the same plug above)
    - NGK PFR6Q (OEM Platinum) - If you're planning to stick with stock boost
    COLD - NGK #7 (One Step Colder) - Cars with basic "chip/intake/exhaust" bolt-on upgrades (K03, K04, etc): Drop one range.
    NGK BKR7E (Copper)
    NGK BKR7EIX (Iridium Version of the same plug above)
    Denso K22R (Copper)
    Denso IK22 (Iridium Version of the same plug above)
    COLDER - NGK #8 (Two Steps Colder) - Cars with bigger turbos will benefit from these, whereas a regularly chipped car may foul these.
    Champion C63YC (Copper)
    NGK R5672A-8 (Copper, Non-Resistor plug)
    NGK BKR8EIX (Iridium)
    Denso IK24 (Iridium)
    Bosch FR5DTC (Copper)
    Bosch F5DPOR (Platinum/Side Fire)*
    Aug 31 2011
    Lathrop
    NGK BKR7E (Copper)
    Denso K22R (Copper)
    You have a 2.0T which is a higher compression engine than the 1.8T or 2.7T. Higher compression engines call for colder plugs so the information you posted is irrelevant. If you are stock you are going to want a Bosch 6 or an NGK 7.
    Aug 19 2013
    Miami
    thanks your very helpful so this are good to use? (NGK BKR7E (Copper)
    Aug 31 2011
    Lathrop
    For your car yeah
    This is a good cheap plug for stock too: http://jhmotorsports.com/shop/catalo...27t-p-687.html
    Aug 19 2013
    Miami
    For your car yeah
    put on the ones you told me what a difference thanks bro.
    Aug 31 2011
    Lathrop
    Yeah no problem!
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    I remember this from awhile ago! You pointed me in the right direction Jake when I was looking at coppers. Had NGK 6 range coppers after coming from a 1.8T; threw on some NGK 7 coppers and what a difference. The part # for anyone wondering (NGK BKR7E) is #4644. Picked up my second set yesterday after ~15k miles, couldn't be happier with them!
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Aug 31 2011
    Lathrop
    Quote Originally Posted by kaz02a4 View Post
    Yup! Tuned cars will actually want a step colder. NGK 7 is the stock heat range. If a tune is not too aggressive though it may not matter.
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    What would you consider too aggressive for the stock plug, as you put me in the good direction too since i taught NGK 7 were colder like on my 1.8t.
    If i have Unitronic 1+, K&N filter, HFC and OBX exhaust, would a NGK 8 give me a big difference?
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Aug 31 2011
    Lathrop
    I would go with a Bosch 5 for you. The heat ranges don't exactly line up perfectly between the two companies which is why spark plugs are are complete pain.
    Sent from my S5
    Aug 19 2013
    Miami
    X2 same situacion as you i just threw on the NGK's 7 and yes indeed what a difference in idle,performance,quicker acceleration,less turbo lag,and better start. is incredible what this little things can do.
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    So Jake what about ko4 on e85.... My current setup
    Sent from my Nexus 7 using Tapatalk
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
