I can't get rid of P1136 & P1138 - Here is a list of stuff I replaced/checked. The thing I notice in my logs is that usually on a cold start, the car will add 10-14% fuel in both banks but once it warms up fully it only adds 3-4% and it's also negative at times.
BLOCK 107 BASIC SETTING (System Not Ok)
Any idea what causes this to fail? Whenever I test, it always goes to 25% fuel and fails. The strange thing is that I unplugged the MAF and it passed.
-New O2's
-New Coolant Temp Sensor
-New MAF & swapped known good MAF
-New Fuel Filter
-New PCV Valve
-Checked for vacuum leaks
-Swapped good Evap Valve
-Plugged off Secondary Air Injection vacuum lines to eliminate the possibility of leaking SAI pump
UNPLUGGED MAF
17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
Possible Solutions
Check Mass Air Flow (MAF) Sensor
Check Fuel Pressure Regulator
Check Fuel Pump
Check Intake/Exhaust System for Leaks
Check Secondary Air Injection for Leaks
Check Vacuum Lines for Leaks
Special Notes
Fuel Trim Info
When this fault is stored and external vacuum leaks are not found, less obvious problems may be present:
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Check Brake Booster and Hoses
Check Electric Vacuum Pump ( If Applicable )
Check Crankcase Ventilation System for faulty components. When the PCV or Crankcase Ventilation System is faulty, vacuum is typically present under the oil cap and misfire faults are common.
