VCDS-Lite Version: Release 1.2
Saturday, 26 April 2014, 12:51:23:25923
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8E0 909 518 AK
Component: 1.8L R4/5VT G02 0003
Coding: 0016711
Shop #: WSC 88641
VCID: 79850BA470C1
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04275
Shop #: WSC 06435
VCID: 263F10D8D1FF
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
VCID: 63B949CCE24D
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
49-10 - No Communications - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 F
Component: int. Lastmodul KAN 0517
Coding: 01014
Shop #: WSC 00000
VCID: 351DC7941C59
4 Faults Found:
02104 - Light Detection Sensor (G399)
29-10 - Short to Ground - Intermittent
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.LBL
Controller: 8E0 035 593 D
Component: SDAR SIRIUS 0060
Coding: 0000000
Shop #: WSC 00000
VCID: 2A27E4E8C5E7
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
Shop #: WSC 63351
VCID: 3FF1A5BC2E65
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Controller: 8E0 953 549 R
Component: Lenksáulenmodul 1002
Coding: 05041
Shop #: WSC 12345
VCID: 42F7AC485D97
5 Faults Found:
01301 - Control Module for Voice Recognition (J507)
01304 - Radio
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 981 G
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01201
Shop #: WSC 05111
VCID: 3115F384E831
WAULC68EX4A230830 AUZ6Z0D0057947
3 Faults Found:
Address 37: Navigation Labels: None
Controller: 8E0 035 192 D
Component: RNS-E US3 H70 0270
Coding: 0309635
Shop #: WSC 00000
VCID: 253D17D4ACF9
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1512
Coding: 11880
Shop #: WSC 128887
VCID: 72973C882DB7
9 Faults Found:
00532 - Supply Voltage B+
37-00 - Faulty
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
37-10 - Faulty - Intermittent
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J398)
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00040
Shop #: WSC 63351
VCID: 047B6A500703
1 Fault Found:
01533 - Terminal 56 (High Beams)
36-10 - Open Circuit - Intermittent
Address 56: Radio Labels: None
Coding: 0309635
Shop #: WSC 00000
VCID: 253D17D4ACF9
1 Fault Found:
Address 77: Telephone Labels: None
Controller: 8P1 862 335 A
Component: FSE_256x BT H44 0660
Coding: 0011822
Shop #: WSC 00000
VCID: 351DC7941C59
End --------------------------------------------------------------------------------------------------
I reset codes a few times, steering angle sensors is a function of a battery reset. A few modules call out the ccm and the ccm calls out the doors. I did not touch the rear doors...which is leading me back to the ccm. Which brings me to my next question...where is it? I believe it's under the drivers seat...but want to make sure before I rip out the seat and carpet.
Thanks.
