Results 1 to 31 of 31
    Established Member Three Rings roger v's Avatar
    Oct 24 2013
    IAT and P3 Gauge
    Does anyone else with the P3 gauge not get a reading for their IAT? Mine reads as zero. Figured I'd see if anyone else had this issue and give support a call on Monday.
    2014 S4 | AWE | Deval | Forgestar | GMG | H&R | P3 | Roc Euro | SPC | StopTech | Toyo | 3M
    Senior Member Four Rings Skywagon's Avatar
    Dec 19 2013
    North Carolina
    Have a P3, but don't know what IAT is? Indicated Air Temp? Or OAT, outside air temp? If it's OAT mine is working.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Make sure it's configured for the 3.0 so it's looking for the correct sensors. I think it defaults to tsi and should be set to 3.0t or Car.3 depending on your software version.
    http://www.p3cars.com/vag-install
    Veteran Member Four Rings Jones2012s4's Avatar
    Nov 09 2011
    Michigan
    It reads a useless air temp.
    It should read the charged air temperature sensor. I am not sure what sensor it actually reads.
    2012 S4 - DSG B8 - [email protected]
    Feb 25 2013
    MI
    Hmm I also read 0, will need to look into this, thanks for the thread OP.
    Nov 09 2011
    Michigan
    If you check the air temp of your center DIS the P3 usually reads equal to, or a couple degrees lower than that.
    Dec 19 2013
    North Carolina
    Quote Originally Posted by Jones2012s4 View Post
    That is a wonderful idea. However, obviously it would require installation of a sensor at the appropriate place. I wonder what the temperature limits are of the gauge?
    Oct 24 2013
    Quote Originally Posted by jl87 View Post
    This. Once I dug through the settings I switched it over to 3.0T and got a reading. It's annoying because their instructions do not reflect the new software Car 1, Car2....etc. However...
    it looks like it just reads ambient air temperature which really does nothing for me. Also, why doesn't this thing read oil temp?
    Quote Originally Posted by Skywagon View Post
    It can read any 5v source, so theoretically you could add a temperature/pressure sensor anywhere and it would read it in addition to the OBD2 readings it takes.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Just gonna leave this here... lowest one since installing yesterday on 93 oct
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    There is no specific temperature limit of the gauge, however it has a digital resolution of 0-9999 (which you could choose *F or *C. The analog input for the P3 is 0-5V.
    I believe that with the P3 VIDI, the air temperature that is shown, is the outside ambient air temperature (feel free to correct me if I am wrong).
    The 3.0T has two air charge temperature sensors and they are located on the intake manifold runner flaps below the supercharger. A air charge temperature sensor is typically a thermocoupler and varies resistance based upon the temperature.
    If you want to use the analog input on the VIDI, I feel this is the best product to use:
    http://www.plxdevices.com/product_info.php?id=SEMOSMAIT
    There could also be the possibility that we could ask P3 cars to modify the software on the VIDI and request the values from the 3.0T charge temperature sensors.
    Dec 19 2013
    North Carolina
    Quote Originally Posted by 500HPS5 View Post
    The air temp being read is in fact outside air temp, at least on my P3. Please forgive my ignorance, what is VIDI. I'll e-mail P3 tomorrow and ask them what they think. I'd suspect the easiest would be a digital read out on the P3 with the appropriate sensor, which you may have correctly mentioned. I sure don't know!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    VIDI is the name of the P3 product. Vent Integraded Digital Interface.
    What I have presented to you is correct, it is the most affordable solution (sans P3 adjusting their software for the VIDI) to acquiring a reading using a intake air charge temperature sensor.
    All of this can be accomplished with a VCDS though. Observing the manifold air intake temps is not something that needs to take place on a regular basis. You do not really have control over the temps, you just need to rely on the coolant system to perform as it was designed. The OEM setup was designed to support about 350# of torque on a regular basis in most environments, APRs CPS can support well over 450# of torque.
    Apr 20 2012
    Honolulu, HI
    In theory, since the P3 uses the OBD2 port to pull the info, it should have access to anything you can log using VAG-COM. Charge air temp, oil temp, trans temp, actual boost should all be readable.
    What would be great is if GIAC or APR would write code to use the DIS to display these things. Like the STE PPD (http://getste.com/).
    Dec 19 2013
    North Carolina
    I sent a message to Tim at P3, cut and paste 500HP's idea. Asked Tim for his opion.
    Dec 19 2013
    North Carolina
    I read my instructions for my P3 gauge yesterday. Allegedly the temperature that is being read is the supercharger inlet temp that is being read by the ECU?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    AKA ambient air temp
    Dec 19 2013
    North Carolina
    Understand, curious as to exactly where the sensor is located. I've received nothing back from P3.
    Nov 09 2011
    Michigan
    I have contacted P3 asking them to put in an update to read charged air temp.
    Nov 09 2011
    Michigan
    It is sensor G42 in this picture. Upstream of the charger. It is useless for what we are concerned with.
    We would be much better off having the reading from G72 or G430 shown here.
    Oct 24 2013
    I wouldn't imagine this would be a difficult update would it? Oil temperature would be nice too so you don't have to have the laptimer up.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You do realize with the P3 you can only look at one variable at a time, and to be perfectly blunt, you have zero control of the output regardless.
    IAT would be fun to look at, although it really serves no purpose other than giving you "peace of mind". The only real variable the P3 offers that you as a driver have actual input with is the 0-60 timer.
    Feb 25 2013
    MI
    Quote Originally Posted by roger v View Post
    Agreed, I thought the P3 came with oil temps. Half of the measurements are pretty useless, I don't care about EGT or speed.
    Jeff has his meth setup pre-blower, so I'm sure he's very interested in that measurement, since he can change the spray parameters to adjust cooling.
    Other angle: wouldn't it be nice to know how your intercooler is doing? Might tell you whether you are heat soaked? One issue I'm curious about is whether I need a CPS while running an APR stg 2 93 map at the track with 93 pump gas. I'm sure it would be smart to get the CPS, but is it needed to be safe and not pull timing etc.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You only need to look at this once, after that you can make a decision. VCDS data logging would be a more useful tool. Once APR releases mobile for Simos, ECU explorer would be an option.
    Senior Member Two Rings hayasa's Avatar
    Aug 25 2008
    Someone know if this entire PDF is posted somewhere? Would be helpful.
    2018 Audi ??? (TBD)
    1990 Audi Coupe Quattro rallycross car - SOLD
    2008 Audi S4 - SOLD
    I like my women like I like my roads: curvy and well lit.
    Nov 09 2011
    Michigan
    Received a response from P3Cars. They are passing my request to their techs.
    Hopefully they can make this change.
    Oil temp would be good to.
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Quote Originally Posted by hayasa View Post
    Here ya go:
    http://www.s4-mtm.com/images/925803_3.0V6TFSIengine.pdf
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Oct 24 2013
    This is great news.
    Jul 10 2013
    Boston
    Are you able to update existing P3 gauges with these changes, if it ever happens? Seems like they have been talking about oil temp for some time now...
    Senior Member Two Rings Ketzer7's Avatar
    Jan 07 2014
    '18 VW Tiguan
    southern NH
    I've looking into getting one of these, and also curious how they handle software updates for the unit. There seems to be scarce info on their site about this and wondering how it would even work? I saw some mention about swapping out a chip in the unit to facilitate an upgrade.. Anyone have an idea about this?
    Senior Member Two Rings pickle.rs's Avatar
    Jul 18 2018
    IG @pickle.rs
    Anyone ever hear from P3? Seems crazy it doesn’t show oil temp.
    2014 Audi RS5 | Capristo exhaust. 034 inserts. RMR Trans Cooler. JHM Stg 2 ECU+TCU. Bilstein B16 iRC, SPC control arms, CR-15, Alu Kreuz, GMG sways, JHM Lightweight Crank Pulley, Girodisc rotors and Magic pads, 034 motor mounts. P3 Gauge. ECS Stainless Steel brake lines. TAWChicago paddle shifters. Apple CarPlay.
    Also: 1990 MK2 VW GTI; 2015 Audi Q5 TDI
    Jul 21 2004
    South Florida
    Quote Originally Posted by toasteronfire View Post
    This thread is 5 years old. The gauge has shown iat for years now
    2018 Audi S5
    Gone-
