Results 1 to 13 of 13
    Apr 25 2014
    Vancouver, BC
    1997 Audi A4 2.8 Quattro upgrades?
    Hey guys knew to the forum so no hate :p
    From what ive read, I assume there not much to do to my car (1997 a4 2.8Q) I'm mainly looking for sound, and a little bit of preformance. I've orded my cold air intake that should be coming in monday. But im interested in getting a muffler, Anyone have an reccomendation on one thats not gonna rip a hole in my wallet?
    Also looking for a firewall grommet to wire my sub! Pics would help but none the else it'd be a huge help!
    Thanks guys hope to hear from you soon!
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    I would say talk to a exhaust shop for a cat back should not be that much 400 or something .
    For the sub look up Boost gauge DIY they will show the best way to run lines into the cabin of the car. It is easily done without drilling anything
    SOLD the GOINHAM A4 ---> GT2860 Project
    Senior Member Two Rings Mirza.Ramovic's Avatar
    Nov 07 2012
    Bellevue, WA
    To the OP, being that your car is a 97, probably means you have the 12V version.
    To be honest with you, there isn't much you can do.
    My car is a 96 2.8 and all I did was redid all of my vacuum hoses, got new spark plug wires, 2.5" custom exhaust & a 034 snub mount with cage.
    The 2.8's are more of the "show car". You can lower it, get some nice rims/upgrade the brakes, etc etc and have a pretty sick looking ride.
    These 2.8 engines are pretty reliable with proper maintenance and can last you a long time.
    If you had the 30V 2.8 engine, you can add a chip and go more into tuning it...
    Here's a video of the exhaust on my car. Pretty loud lol, but I like it.
    1996 Laser Red Audi A4 V6 2.8 FWD
    Mods
    Clear Corner D.I.Y
    Custom 2.5" Exhaust
    034 Motorsports Snub Mount With 034 Motorsports Snub Cage
    Custom Made Alternator Air Duct
    Gutted/Stripped Trunk
    Bahn Brenner 8mm High Performance Spark Plug Wires
    HPS 3.5mm Red Vacuum Hose Replacement
    BREMI Ignition Coil Pack
    Apr 25 2014
    Vancouver, BC
    Just wondering, Would that muffler fit on my car, If it would what did you pay for it?
    Dec 12 2013
    1997 Porsche Boxster, 2005 Chrysler 300C
    Bow, NH
    I also have a 97 and i went to a custom exhaust shop and had them do a muffler delete for $100. They gave me a nice fat tip and put in a piece of pipe where the muffler was. I still have two cats and a resonator. I think it sounds really nice, not too loud. The sound tapers out at 3500 rpms and sounds the best. The shop is called Lou's Custom Exhaust. Ive even had people tell me it sounds like a truck, its loud.
    Nov 07 2012
    Bellevue, WA
    Quote Originally Posted by Shanerob View Post
    Muffler will fit. I payed all together about 400 bucks. 280 dollars to have the exhaust welded, and about 120 for the Y-Pipe/Resonator
    Mods
    Clear Corner D.I.Y
    Custom 2.5" Exhaust
    Apr 25 2014
    Vancouver, BC
    Ordered a magflow exhaust dual tip. Guy said it will be louder then the straight pipe with a sick backfire sound. Plus with the cold air intake it should be loud as fuck, Pictures to come for monday (When they put the muffler on) Thanks for all the help!
    Nov 07 2012
    Bellevue, WA
    Nice! You'll enjoy the new sound
    Mods
    Clear Corner D.I.Y
    Custom 2.5" Exhaust
    Jul 11 2014
    Gold Coast, QLD, Australia
    Hi guys, is it possible to fit a turbo on this car ? I have a 97 A4 2.6 V6 . Also I see a lot of 12v , 30v related to this car what does it represent and how to I find out which one I have.
    A métier questions I know any help would be greatly appreciated, thanks;)
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by Dboy80 View Post
    A métier questions I know any help would be greatly appreciated, thanks;) Sent from my iPhone using Tapatalk
    I contemplated this as well. Still thinking about it when I have to get a rebuild done.
    For starters you'd have to upgrade the pistons (10:1 compression isn't ideal for boosting), valves, some head work since there is a GIGANTIC manufacturing flaw in how these IM were made. Be sure to gasket match it to the heads. Turbo's alone (quality) would cost upwards of +$1000. You'd then need custom exhaust manifolds to feed the turbo(s). I'd personally do the single turbo with pistons, valves, stock manifolds with custom piping to a single turbo (GT28R), tap the main bearings for 4 bolts, and then worry about standalone for the engine tuning since our ECU's can't be flashed (costly). Replace the stock exhaust with a single pipe HFC to the stock resonator and muffler delete. Stage 2 southbend clutch kit for added assurance of not blowing your clutch.
    A MINIMUM estimate of $5000 to turbo your 12v. I'd prob buy an S4 for that, but I would miss being unique.
    EDIT: I forgot about injectors. You need injectors. 430cc should do. Someone can confirm/deny this for me
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    Northern Virginia
    Check out Motodyne, they're one of the only sites that offers performance parts specifically for the 2.8. I'm in the same boat as you, except I'm more into performance.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Dec 10 2013
    Alternatively get a PES G2 and then fabricate an adapter plate to match the 12v
    Jul 11 2014
    Thanks very much guys
