Results 1 to 40 of 66
    Senior Member Two Rings MFT's Avatar
    Nov 05 2012
    Ontario, Canada
    Key Fob Battery warning? Take heed!
    So last night after a meeting, with the temperature dropping to freezing, I found myself in the unfortunate position of standing outside of my car with my fancy advance key locked inside the trunk.
    I usually keep the key in my coat so it is on me whenever I get into the car, but with the warmer weather I did not wear a coat yesterday and so absentmindedly put the key in my briefcase when I got to the meeting. Coming out of the meeting, I put my briefcase in the trunk (which unlocked for me since I had the key outside the car) and then closed the trunk, with the car promptly locking itself upon closing.
    Now, my understanding is that the advance key is not supposed to allow you to lock yourself out of the car/trunk, but I had been getting an intermittent key fob "low battery" warning recently, so I suspect that this played a role in leaving me stranded waiting for CAA to come break into my car.
    Lesson: If your key fob battery is low, don't procrastinate and replace it ASAP!
    Present: BMW X5 / Incoming: RS6 avant?
    Gone: Various VWs, Audis, BMWs, Porsches, one Mercedes (E63s wagon) and one Toyota (4Runner)
    Established Member Two Rings toerag's Avatar
    Apr 17 2013
    UK
    Monsoon - Magma - Black Edition - B8.5 S4 Avant
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    That sucks man! I've actually tried to close my key int he trunk and it just pops open. Definitely something to do with the battery.
    Oct 08 2012
    Vancouver
    I had a key low battery warning light randomly one night a few weeks ago and it came up again the next day after that. However, I didn't change the battery and just left it and more than a month later, the battery is still going strong.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    With Audi's half assed implimentation of the smart key I'm suprised you don't have the use the remote to lock the truck.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    I wish I had an advanced key :(.
    Jul 12 2012
    Quote Originally Posted by shadycrew31 View Post
    Believe me you're not missing much. Can't tell you how many times I have to use the actual key fob to unlock the car because its been sitting for a couple of days and apparently that part of the system gets powered down. Or the sensor needs to grab the handle or hold the button down for several seconds because it can't read the key. Or how you can't lock the car while its running unless you use the mechnical key. Its the single thing I hate the most about the car.
    Veteran Member Three Rings mecheng's Avatar
    May 29 2013
    2017 Q7
    Toronto, Canada
    Quote Originally Posted by blackfunk View Post
    Then yours is malfunctioning, because mine is an absolute cherry.
    2013 S4 | Brilliant Black | Premium | Magma/Black | Carbon Atlas | 19" Rotors | 6 Speed | ADS | Sport Diff | Side Assist
    Previous:
    1. '82 911SC [sold]
    2. '11 WRX [murdered]
    3. '11 S4 [sold]
    4. '14 Fiat 500c Abarth [sold]
    5. '17 Q7 [Family Hauler]
    Senior Member Three Rings ob_1jr's Avatar
    May 05 2012
    Clinton, UT
    I love my advanced key. It works great most of the time. Sometimes it takes a few seconds to unlock the door, but that is when I am not standing facing the car and the key is in the far pocket. I also see it not working as good if the car is dirty vs clean.
    2017 SQ5 Premium + | weathertech floor mats | 20% tint
    Sold:2012 S4 Premium + | 6MT | comfort key | supercharged badges | weathertech floor mats | 15% tint | Gunmetal VMR 710 18x9.5 w/ bridgestone potenza RE970AS from PYSpeed| Roc-Euro intake | Alu Kreuz | Eurocode Meisterwerk ASTS | 034Motorsport Transmission Mount Insert | Spulen Rear Differential Mount | ECS GEOMET Slotted and Drilled rotors | Hawk Ceramic pads
    Jul 12 2012
    Quote Originally Posted by mecheng View Post
    Remote battery, and car battery have both been changed. Fact is it doesn't always work. If the key is on the far side of my body and I'm holding my kid its most likely not going to work the first time out. A simple button would work. Lexus, BMW and Infiniti do it better. By miles.
    Established Member Two Rings fignewton's Avatar
    Dec 08 2012
    2005 Chevy Avalanche Z71
    Broad Run/VA/mid-Atlantic
    Quote Originally Posted by toerag View Post
    Toerag, that's from Fawlty Towers, right? That's one of the funniest things I've ever seen. Had tears running down my face, prob cause I used to have a 1961 Mini Cooper S.
    Fig
    Current- 2024 Daytona Grey Black Optics SQ5 Prestige, Sport pkg, sport exhaust, 21" wheels, 034 sway bars
    Previous- 2018 Daytona Grey Prestige, 21" wheels
    2014 S4 Monsoon Grey, Premium, Black Optics, sport diff, black napa, B&O, Nav, Alu Kreuz, Michelin AS3s, tint, Eurocode intake
    2010 S4 Ibis White
    2002 TT 225, Aviator Grey, lots of mods
    Veteran Member Four Rings RickFLS4's Avatar
    Sep 21 2012
    2012 Audi Q5
    Palm Beach County, FL
    I had an issue with my key fob / system powering down. I have had very rare occasions where the door needs a second or two after grabbing the handle to unlock though (had the same with my last Lexus also). I don't really have a need to lock the doors with the car running so I can't comment on that issue.
    2015 BMW M4
    Past: 2013 S4, 2011 A6 3.0T (accident victim), 2008 Lexus LS-460, 1998 Lexus GS-300, 1994 Lexus ES-300, various GM/Ford/Chrysler cars prior to 1994
    Veteran Member Four Rings Pilfer's Avatar
    Dec 13 2012
    To the Bay Area
    I love advanced key, I pretty much use the fob to open the car but lock it frequently by touching the sensor on the door handle and almost always use the start button.
    996
    Model Y
    Oct 02 2013
    Redstone, CO
    Agreed. Mine works perfectly. I also travel for a living and leave my car in the garage for days and I have no issues upon my return. My system works very well.
    2014 S4 Estoril Blue, Black Opt, 19" Rotor, Side Assist, Carbon Inlay, B&O Sound, MMI/NAV, Rear Camera, Advanced Key, Supercharged badges, H&R OE, Track+ Spacers, 10/15mm, otherwise stock.
    Nov 05 2012
    Ontario, Canada
    Quote Originally Posted by dygital View Post
    Mine had been giving a warning intermittently for about a month (some days a warning would pop up on the dash when trying to start the car and some days not). So it seems that it will still work but dies a slow death...and then leaves you stranded by locking you out of the car!
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    Why/when would you want/need to do this? I wish my Q had advanced key.
    Oct 20 2008
    How often are you guys replacing batteries? Both my keys had the low battery indicator within two years of ownership.
    I also noticed if i had my phone in the same pocket or nearby my key it doesnt really work properly all the time
    Sent from my SGH-I337M using Tapatalk
    "I know it won't create actual downforce at 125 MPH. I know it does make the S4 more stable." - westwest888
    "It doesn't say anywhere in the rule book that a dog can't drive autocross" - westwest888
    "It would be easier if we just accepted my OP as fact in the Audizine sticky wiki. " -westwest888
    Sep 21 2012
    2012 Audi Q5
    Quote Originally Posted by Akatsuki... View Post
    Coincidentally I replaced mine last week when it started to give warnings. I got the car in August 2012 so about 20 mos. I thought it was a kinda short life but not a big deal.
    2015 BMW M4
    Sep 21 2012
    2012 Audi Q5
    Quote Originally Posted by BigBluu View Post
    I once left my dog in a previous car with the a/c on when I ran into a store but then thought twice about ever doing it again when I realized (duh) someone could just break a window and take off with my car and my dog. No offense to OP, but even though the smart key shouldn't let you lock your key in the trunk I also avoid ever putting my key in the trunk out of habit since I started driving before smart keys.
    2015 BMW M4
    Veteran Member Four Rings 99ebpsi24's Avatar
    May 04 2008
    10 S4 prestige, 12 A4 S-Line, 00 Stg3+ S4, 74 VW Thing, 74 Z28 camaro (32k original miles) 74 Z28 Ca
    Cincinnati
    Can't tell you how many times I have to use the actual key fob to unlock the car because its been sitting for a couple of days and apparently that part of the system gets powered down. Its the single thing I hate the most about the car.
    Both my s4 and my a4 have the advance key and will "power down" as you describe. However this is only after sitting for a week or more. I rotate the cars often and if I leave them sit for a week or so I will have to use the key fob button to actually unlock the cars. Once I've started the car the door sensors work without hiccup though. I have to disagree though, the advance key is an absolute must.
    Current:
    19’ Ara Blue RS3 UniFlex stg1+, stg2 tcu, midpipes & IE intake
    21’ VW Atlas SEL Prem. R-Line
    15’ Sepang Blue S3 Prestige
    10’ S4 Prestige
    00’ S4 stg3+
    12’ A4 P+ S-Line
    08’ A4 P+
    Nov 20 2013
    Montreal Canada
    I love the advance key even more after driving a loaner Q5 that didn't have it. It is really a marvel. Sorry that happened to you OP.
    Veteran Member Four Rings Toecutter's Avatar
    Dec 31 2007
    Oregon
    I think yours is malfunctioning. What year is your car?
    Jul 12 2012
    Its a 2012 its not that its obiviously broken but twice a week at least it flat out wont find the key even after being driven in the morning or the day prior. As to why I'd want the car running I can think of a couple of reasons, but sometimes I run into a store and its cold/warm and the misses is in the back with the baby and she locks the doors I now have to take the keys out of my pocket to unlock the doors. In the morning its easier to bring the car around front an leave it running so I can load the baby, I now have to choose either leave the car running and unlocked and risk it not being there when I come back out - which is what I end up doing - or, lock it and put the baby down go around to the drivers side and unlock the door. With former BMW's\Lexus\Infiniti I could lock/open the doors with the car running and the key in my pocket. And most importantly I could NOT lock the keys in the car because the car was smart enough to know the key was in the car.
    Veteran Member Four Rings jauri's Avatar
    Sep 20 2012
    Sagaponack
    you moved to PA?
    "i [am] fluent in 14 different ebonic dialects." -over9000-
    "I'm Gnna fuck the shit out of dolphin." -aka5-
    Dec 31 2007
    Oregon
    Something here does not make sense.
    Sep 21 2012
    2012 Audi Q5
    Quote Originally Posted by Toecutter View Post
    Yes, not finding the key 2x per week doesn't sound right. Most of the rest sounds like complications due to specific circumstances or settings. For example, if the car is off and locked not sure why there would be a need to put the baby down to go around to the driver's door to unlock another door. I only have a briefcase to put in the backseat but just walk up to the car and open the locked back door by grabbing the door handle.
    2015 BMW M4
    Senior Member Three Rings MNB5Tuner's Avatar
    Sep 02 2009
    Colorado Springs
    For whatever it is worth, if you have advanced key you can start your vehicle then lock it while its running by a simple setting change in vag com (taking the key with you obviously). I did it for a buddy with a PTS Jetta
    2007 A4 Avant S-Line 2.0TQM APR Stage 2
    May 05 2012
    Clinton, UT
    You happen to remember the change? I just went through pretty much every setting on my car the other night and didnt see anything about advanced key other than being installed.
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    Advanced key is awesome! I recently learned you can also lock the car without using the buttons... I was under the impression it was only unlock with the touch sensors.. after an entire year of owning the car.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Jul 12 2012
    What doesn't make sense? My home is on the passenger side of a busy street so I'd rather not walk into the street with the car seat to unlock the door in addition the car seat is behind the passenger seat.
    Quote Originally Posted by RickFLS4 View Post
    I leave the car running, if I want to lock it then I need to upon my return put the car seat down and go back to the drivers side to manually unlock using the keys.
    Quote Originally Posted by MNB5Tuner View Post
    Please post it up. I started a thread awhile back asking about this and no one knew of any work around.
    In this case the smart key serves only two functions, unlocking/locking the car and starting/turning it off without removing the key from my person. If I'd never had other cars that went the extra mile by allowing me to lock the doors with the car running maybe I would like it but as I've stated even a lowly altima allows you to lock the doors while stepping out of the car while its running.
    Jul 12 2012
    Quote Originally Posted by raudiace4 View Post
    Please post up. Share the knowledge.
    Nov 06 2013
    With the key fob in your pocket you can walk up to your car and unlock, same thing when you get out. Key fob in pocket, close door and touch the door sensor it should lock the car. I always used to press lock on the key fob, no need to take it out of your pockets or jackets!
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Jul 12 2012
    ^ With the car running?
    Established Member Two Rings jpbadonk's Avatar
    Feb 07 2013
    2013 x5, 1972 911, 1981 911
    BMW? Not on the X5 ... drives my wife nuts. I thought it was an unnecessary option that I didn't want to pay for, but that's what was on the lot when I bought the S4. Now I love it. Works greeat for me. When going biking, I put the key in my hydration pack and have no issues locking/unlocking with the pack on my back.
    '13 s4 premium plus, monsoon grey, sport diff, 19", yadda yadda yadda
    ____________________________________________
    Sep 02 2009
    Colorado Springs
    Quote Originally Posted by ob_1jr View Post
    If I could get somebody to provide me with a B8/B8.5 I would be more than happy to take a screenshot step by step. Pretty sure it was under central electronics, either that or central convenience.
    When I was done, he could leave the key in his pocket, unlock the door with the handle, start up the car, then leave the car running and hit the lock button on his keyfob as he walked away. I don't know if the door handle locked the vehicle while running as well
    Jul 12 2012
    Quote Originally Posted by jpbadonk View Post
    Might be different on the 2013 -X6? Seems unlikely though. I can leave that running and lock/unlock the doors.
    Jul 12 2012
    This is making a VAG cable seem necessary now LOL.
    Nov 06 2013
    Haven't tried it with car running. Probably not. VAG com is necessary.
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Feb 07 2013
    With the X5, simply unlocking with the key in your pocket is a 50/50 on the first try. Probably 99/1 on the S4. Have not tried to lock it after it has been started. And I still haven't figured out the key-fob action for the rear hatch. BMW electronics are shameful for a $60K+ luxury vehicle.
    Nov 06 2013
    Wow.
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
