Results 1 to 18 of 18
    Nov 02 2012
    MN
    Can you take the instrument glass apart?
    My car has what looks like sugar granuals behind the instrument glass, in front of the instruments, is there an easy way I can take the glass off to vacuum this crap out, as it's really bugging me
    Senior Member Three Rings MNB5Tuner's Avatar
    Sep 02 2009
    Colorado Springs
    Yes you can. Remove the two gauge cluster bolts, pull it out, and IIRC its just a series of clips that hold the clear lens onto the actual cluster
    2007 A4 Avant S-Line 2.0TQM APR Stage 2
    Senior Member Three Rings Jey4's Avatar
    Apr 02 2013
    West Haverstraw/NY
    I feel your pain bro. I have the same issue and plan on taking it apart once the weather gets right.
    -Jey
    Nov 02 2012
    MN
    is there a DIY for removal, i havent looked at it in detail but i cant remember seeing any fixings. I am sure they are all clips, i just dont want to break any and then have a clean cluster with an even more anoying rattle!!
    Apr 02 2013
    West Haverstraw/NY
    http://www.audiworld.com/tech/int64.shtml
    Here is a DIY I found from another forum.
    Sent from my SGH-I337 using Tapatalk
    -Jey
    Nov 02 2012
    MN
    Awesome, Thanks Jey
    Veteran Member Three Rings Kingzilla17's Avatar
    May 05 2011
    Arlington, Texas
    I need to do the same thing.
    Account Terminated Four Rings
    Apr 18 2013
    Right
    I had to take my steering wheel off because the cluster is too thick even when I tilt the wheel all the way down.
    Feb 25 2011
    Seacoast NH
    Wow. This seems like a pain in the dick. I need to do it, but not sure I'll risk it.
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by mccorkled View Post
    Did you telescope it out as far as it would go too? That's odd.
    Apr 18 2013
    Right
    I didn't know you could pull the steering wheel out. How?
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Just disengage the lever you use to tilt the steering wheel and pull the wheel toward you.
    Apr 18 2013
    Right
    Interesting. I'll test it tomorrow because I have to pull my cluster out to replace the speaker. Thanks.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    I've removed my cluster like 10 times, it can easily be done with the steering wheel in place. I've never once had to remove the SW to get the cluster out. Just dip the steering wheel down and out as far as possible.
    Aug 29 2010
    St. Louis, Missouri
    Marked
    Apr 18 2013
    Right
    Ok I got mine out again. I was not aware that the steering wheel came towards the seat. Thanks.
    Veteran Member Three Rings midnight407's Avatar
    Oct 21 2011
    Brilliant Black B7, '06 STi borrowed/stolen from the roommate
    Northcenter/Ravenswood Chicago
    where did you source the speaker? A friend of a friend with a B7 came to me asking for advice, I told her she can ship her cluster to an online repair company for the $99 repair service or just live without warning chimes for free haha
    midnight407
    Chicago, IL
    Feb 26 2008
    To anyone that has polished the clear lense on the cluster what did you use?
