I got my car flashed yesterday Apr Stg1. It took about 30 minutes to do the flash with no problems. They installed stock/93/race/vallet. Changing maps with a cruise control is lot easier than i thought.
In stock map car really feels stock may be a bit more stronger but i cant tell for sure.
93 octane map the car feels similar to stock in daily driving situations. The biggest difference is the when you give WOT the car pulls all the way to redline hard. It gained a lot on the top end. Before, i felt like i had to upshift after 6000 rpm because the car was not pulling anymore. Now i dont have that problem. 100 mph comes very quick and easy. Even in comfort mode the car feels lot faster and crisp than the comfort mode in stock map. Of course dyno will show the ultimate gains, but my guesstimate is i gained about 10 percent awhp from my stock configuration which will put me around 333 awhp.
I dont have unleaded gas now so i did not use that map.
My question is since i am not using the race map, when i use the race map does the ecu still need to adapt to that particular map? In other words, is it map specific adaptation?
Also my roc euro intake should arrive soon. Once i install does the ecu need to reset? Should i disconnect the battery so that ecu adapts to the new intake better?
