Results 1 to 14 of 14
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    Need advice on removing tire dressing buildup from wheels
    What's a good product that I can use to remove the gunk/residue buildup of tire dressing that accumulates on the wheel, and at the same time, won't damage or remove any protective finish? It's a greasy buildup that I end up just kind of pushing around with the towel. Car washing soap and elbow grease doesn't cut it. The dressing is something called Black Magic Tire Wet gel. I have a 2014 S4 with Black Optic so I have the five spoke titanium wheels.
    Thank you.
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    I've had that shit on my wheels too get some Sonax wheel cleaner to remove and then get a sponge applicator to apply a less greasy Tyre shine.
    Veteran Member Three Rings MarcWinkman's Avatar
    Jun 21 2013
    DE
    I use Adam's All Purpose Cleaner for my tires, but any APC will work just as well (Wolf's Chemicals, P21S, Chemical Guys, etc.). Spray it on, agitate it with a stiff bristled tire brush and rinse.
    2013 S4 - Phantom Black Pearl - S-Tronic - AWE Tuning S-Flo Intake - AWE Tuning Exhaust with 90mm tips - H&R OE Sports - H&R 24mm rear sway - Deval/Eurogear USA Carbon Fiber Rear Diffuser - Deval/Eurogear USA Carbon Fiber Front Lip - Black Optic Grille - ECS Slotted Rotors and Hawk HPS pads - BBS CI-R with Vredestein Ultrac Vorti (Summer) - Factory 19" Peelers with Michelin Pilot Sport Alpin 4 (winter)
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    APC + brush, as stated above
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    Quote Originally Posted by helix139 View Post
    +1.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Senior Member Two Rings buzztt's Avatar
    Jun 10 2010
    Boston. MA
    And try a different tire dressing, and apply with a sponge rather than spray, sponge solves your problem
    2012 A6 ibis, heavily modded 2001 996tt, 2007 997 vert, 2008 ML550
    Jan 11 2014
    North Carolina
    Thank you for the responses. I actually do use a small applicator sponge/pad that came with the product so the residue isn't like slung onto the wheels in globs. Question about the APC.....is something like Formula 409 an APC or is it something specific for wheels that I have to get at get at Autozone or online?
    Apr 21 2010
    Florida
    Quote Originally Posted by SForePlayin' View Post
    You need a specific automotive APC. Adam's, Meguiar's, etc.
    Established Member Three Rings roger v's Avatar
    Oct 24 2013
    Simple green. Tuf shine tire cleaner would be your best bet though.
    2014 S4 | AWE | Deval | Forgestar | GMG | H&R | P3 | Roc Euro | SPC | StopTech | Toyo | 3M
    Veteran Member Four Rings QUA77RO's Avatar
    Jul 05 2011
    a few other cars and a hungry Akita
    just North of the Golden Gate
    bleche wite, tire cleaner, gets everything off
    keep a hose handy to rinse everything off and keep it off the wheels and paint. if it does get on the wheels or paint no big deal if you rinse it off right away.
    "Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
    "Make the suspension adjustable and they will adjust it wrong — look what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver." - Colin Chapman, Founder of Lotus
    It is amazing how many drivers, even at the Formula One level, think that the brakes are for slowing the car down. -Mario Andretti
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    Love bleach white , that brings the tires back to new . Let them dry real good and see if you need to do a 2nd application then a nice coating of tire shine . Have been using auto finesse satin tire shine . Makes them look new and not very shiny
    Jan 04 2013
    Croghan NY
    bleche white is good, but whatever you end up using, the most important product is grease. elbow grease and your product of choice and a brush. turns brown tires black again. then quit letting people put $hit on your tires, use something decent like Adams SVRT (waterproof and doesn't sling)
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 23 2004
    are you trying to remove old dressing from your tires or stuff that has splattered on your wheels?
    got any photos of the issue?
    Jan 11 2014
    North Carolina
    Trying to remove the stuff that splatters and builds up on the wheels. Is there something to just spray on, let sit and rinse off?
