Results 1 to 33 of 33
    Nov 12 2012
    2005 Malibu boat
    Portland/Or
    When ride quality is a priority, who makes the best coilover for our cars?
    I will be shopping for coilovers soon and I am really not interested in a harsh ride. I don't need/want to lower the car much and ride quality is a priority.
    -OR-
    Could should I just buy OEM sport suspension? How much lower does the car sit with this?
    Veteran Member Three Rings OB1's Avatar
    Jun 25 2010
    Baltimore
    Stick with your OEM suspension if your prioritize ride quality.
    '12 MG A4 Avant
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    I was so impressed with the KW V1's on my A3 (ride quality was better than the stock sport suspension) that I got them for my A4.
    Being installed this week.
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Senior Member Three Rings BaysideS4's Avatar
    Feb 25 2004
    Tampa
    Stasis but that is based on cross platform experience: B5 MTM, B6 Bilstein, B7 Stasis, B8 Bilstein.
    Problem is they have to be disassembled and serviced and you've seen recent posts. When the Ohlins were working they were great.
    2009 B8 A4 2.0TQ Premium Plus; 18" Sport Package; Meteor Grey; 125,000 miles / New OEM Piston Heads / Ecodes / Eurocode HFC / Revo / 15mm spacers / Bilstein B12 / Alu Kreuz / ÜSS Sway Bars / EC charge pipe and outlet adapter / 3.0TDI IC / RS5 pedals (hecho en China) / AWE exhaust / RIP: Rotamass pulley
    Previous:
    2007 RS4
    2005 S4
    2001 S4
    Active Member Two Rings Dbrewer's Avatar
    Mar 12 2014
    Madisonville Ky
    Quote Originally Posted by M1ke View Post
    -OR-
    I put on H&R OE sport springs. 1.2 in all around lowering. Not too much of a difference unless you're really on bumpy roads. I'm happy with the ride quality and I was really nervous about putting them on.
    Little bump>big wheel gap
    Dec 01 2011
    if you don't care to go too low then i would go with the OEM sports suspension, make sure it's the sport springs and also the sports shocks/struts. the OEM sports suspension is 0.8" lower than stock. that's the S4 height too and IMO looks pretty decent still, and you'll still get a nice comfortable ride, nothing can top the OEM comfort. and for comparison, the H&R OE springs which give the mildest drop of lowering springs go 1.2" lower, so it's a bit more but the OEM sports still looks decent.
    coilovers will be expensive but the cheapest is the solos and those are pretty cheap.
    if you have the OEM non-sports shocks i would not get lowering springs, after a year or so the ride will turn pretty harsh, i have the H&R OE level drop springs and it happened to me, so if you do get that be ready to change suspension again in a year or two.
    IG @theshawon
    Nov 12 2012
    2005 Malibu boat
    Portland/Or
    Right on liquid smoke I was using this same reasoning with my purchasing. So where are you guys getting your OEM sport suspensions? Used, New etc? New seems like it would be super expensive.
    Veteran Member Four Rings kwbdc's Avatar
    Mar 29 2012
    2006 Mazdaspeed6 RIP
    Seattle/WA/United States
    If cost is not prohibitive, Bilstein PSS10 coilovers are great IMHO. Ride quality is very comfortable if you dial up the dampening.
    2012 Audi A4 Premium +MT, Quattro, Xpel bra, SLine BBS CI-R 20x8.5 ET 32
    Mods: APR HFC/DP, APR K04, Bilstein PSS10 Coilovers, Okada Coilpacks, AWE Boost Gauge, Eurocode SSK, OSIR CF Spoiler, APR Carbonio Intake, AWE Exhaust, OSIR CF valence, ÜSS Adjustable Stabilizer set, Alu Kreuz, RS4 grille, Fluidampr,Apikol differential, folding mirrors,Brembo GT BBK, Deval CF splitter,ECS skid plate, RS4 rear brakes, Snow performance Stage3
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    KW Street Comfort Coilovers. Or any dampening adjustable coilover, that way you can set how soft or firm the dampening is.
    Jan 13 2006
    Houston
    I'll have a set for you this weekend with 10k miles on them.
    Nov 12 2012
    2005 Malibu boat
    Portland/Or
    ^^ PM Sent.
    Are there any inherent issues with running the KW's? knocking, thumping, bouncing etc?
    Jun 14 2005
    Anaheim, CA
    +1 for KWs. They're pretty solid and they're relatively comfortable. Just keep in mind that in most cases, it's not going to feel exactly like an OEM option would.
    Brandon @ VMR Wheels
    Veteran Member Four Rings hoppy6698's Avatar
    Sep 10 2009
    2015 BMW M235i
    Yorktown, VA
    I would recommend avoiding coil overs altogether. After 3 years on ST coils, I found them too harsh. While others may be softer, they get more expensive as you improve in ride quality. I would offer a different option: Bilstein B12 pro kit (see my review here: http://www.audizine.com/forum/showth...o-Kit-A-Review). They are FAR improved over both OEM ride and coils. They provide the drop I desired, while not going too low, and the ride is very compliant (read sporty, but not harsh and definitely not jarring).
    End ride height is about 25.5-26 inches from ground to top of the wheel arch.
    "A man who won´t die for something is not fit to live." - MLK Jr.
    Dec 01 2011
    yeah most coilovers will be harder than OEM because they're firmer and made for the track and performance. there are a few coilovers like H&R Street Comforts and Solo-werks, which have gotten great reviews and are cheap. for an OEM sports, cheapest is to get a low mileage set like dennisA4 just offered, otherwise new through the dealer would be a bit expensive. but yea if you can get that used set go for it.
    IG @theshawon
    Jan 13 2006
    Houston
    Just had my KW V1's installed today and just as with my previous Audi, they feel pretty much as good as the OEM sport! Almost imperceivable, yet I'm quite a bit lower.
    I wouldn't even say any of it feels worse, just "different".
    But if you swapped them out while i was sleeping without my knowledge, i doubt I would have noticed a diff.
    Senior Member Four Rings r6_11b8's Avatar
    Oct 03 2013
    los ángeles
    no matter what coilover you get or try they are all going to be harsh on rough surfaces...smooth roads is whole nother story...my solos feel almost as smooth as oem..biggest plus for me is it took away that bounciness oem suspension had...rough roads and pot holes suck but that will be with any coilover you get
    2011 A4 ice silver metallic
    MODS- 25% tint rear, 75% front, 19" Rotiform BLQ, Solo Werkes coilovers, Custom FXR projectors
    upcoming mods - 10 inch sub
    2009 Yamaha R6 - Shogun FS-Zero Gravity-Custom FE-Hot Bodies Flush Mounts-MotoDynamic Integrated Tail Light-Supersprox -1+2-Taylormade Full Exhaust-PCV-OURY Grips-Corbin Seat-Ebay Shorty Levers
    Jan 13 2006
    Houston
    Our surface roads get pretty rough.
    The V1's are VERY compliant.
    That's why I went with them again.
    Feb 19 2014
    RVA
    I put st's on last month, the ride is great for me. Not rough but not floaty, nice and firm. The car does sit low for me but, I have big tires that probably makes the car look lower than it really is. I'm ~26in to the center of the fender.
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by dennisA4 View Post
    +1, they are comfy. I do not see how anyone could feel they are harsh. I found them to be too soft for my liking.
    Established Member Two Rings notazombie's Avatar
    Jan 13 2014
    Bucks County, PA
    If you've got the money, it sounds like you want remotely adjustable suspension.
    http://www.carid.com/2010-audi-a4-su...-14868813.html
    A lot of higher-end European cars have this where you can retain the comfort of ride height and some sway-bounce to help deal with rough roads and with the press of a button stiffen the suspension and lower it a bit. This way you retain the best features of both types of suspension. Unfortunately, the things that make rides comfy are the things that make the car slower and less aggressive-looking.
    http://www.apikol.com/index.php/bils...-pss10-b8.html
    The Bilsteins are $2,200 and offer an OEMish solution. Installation will probably be another $1,000 or more and the electronic component means I'd want certified shop work, but if you want comfort and performance, it's what you want.
    2010 Audi A4 Quattro 2.0L Premium package
    Installed: Volant Cold Air Intake, Powerstop Slotted/Drilled Rotors with Akebono pads
    Wish List: 1. Stage 2 APR 2. Test pipe/HFC 3. Sway bars 4. R8-style lights 5. LED tails 6. Light tint on windows/tails
    Just for looks wish list: 1. Plasti-dipped wheels 2. RS4 Grille
    Jul 09 2012
    UK
    Interesting thread, how are the spring kits, with aftermarket shock absorbers, I remember the Koni FSD ones, but I'm not sure if they are available for the b8, the seemed to be a good compromise.
    Jul 25 2011
    go with air ride (accuair b8sportkit) set it at any height you want.
    Established Member Two Rings ChornsYYC's Avatar
    Jan 30 2013
    Houston, TX
    Quote Originally Posted by tinka View Post
    Currently I have H&R OE springs installed with Bilstein sport shocks. The ride is noticeably stiffer than OEM. However, the performance gains are significant and the drop is right where I want it considering the harsh winters we deal with where I live. I notice a lot of people simply swap in aftermarket springs without touching the shocks. This is a mistake in my experience. The OEM shocks will not last long on shorter aftermarket springs.
    Nov 12 2012
    2005 Malibu boat
    Portland/Or
    Glad to hear it dennis. Hear from you monday?
    Senior Member Two Rings kaklexicon's Avatar
    Nov 21 2005
    PA
    Has anyone gone with OEM sport springs with aftermarket shocks?
    2012 Audi A4 2.0T Quattro
    Apr 04 2011
    Jacksonville
    I love my Bilstien's ride. You can not set them super low and they will be nice and firm, but very nice riding. Think BMW M car, or similar. Mine is a DD.
    2011 Ibis White Ti, Premium +, APR Stage 2 ECU, APR Full Dual Exit Exhaust, Carbino, dyno corrected 248BHP-376 lb/ft, 40% 3M Crystalline "7 window" tint, 90% 3M Crystalline Windshield tint, 90% 3m Crystalline Sunroof tint, Curt 1.25" trailer hitch, stock Ti 19x8.5 et43 wheels (28lbs each), Wheel Spacers 5mm ft/10mm rr (effectively et38 ft/et 33 rear), Michelin Pilot SuperSport 255/35/19
    Established Member Two Rings hookahmaster's Avatar
    Jun 18 2013
    mk7.5 gti, 19' GLI, 12' veloster
    DFW Texas
    I'm running Vogtlands in they are pretty comfortable, but as everyone has been saying, if you want maximum ride quality and don't wanna go that low, stick with stock suspension, or go to the SPort OEM, or just do springs, but of the most part Audi's seem to ride pretty smooth with coil-overs..
    2013 B8.5 Audi a4 Quattro 6spd M/T. (totaled)
    mods-EC test pipe, AWE single exit exhaust, USP downpipe, Revo stage 2 flash, Vogtland coilovers, AG 590, stage 2 Southbend clutch, ECS flywheel, roof rack, k&n intake.
    current: 2019 VW GTI mk7.5
    downpipe, APR stage 2 tune 2/ pops and bangs, stage 3 southbend clutch and lightweight flywheel, APR turbo inlet pipe, ECS turbo muffler delete, ECS dogbone insert, afe enclosed cold air intake. (KW coils)
    Veteran Member Three Rings Limey's Avatar
    Nov 27 2010
    2004 srt4
    Edmonton,Alberta
    Bilstein PSS10's. Enough said
    Later Gents
    2009 A4/Brilliant Black/6MT//Usual Vag-Com mods//A5 5 spoke "y" rims with Michelin 255/35/19 super sports//bilstein pss10's//rs4 grill//rs4 grills//S-Line side blades//Ecode halogen to bi xenon conversion//LED bulb interior swap//AWE quad tip exhaust//Eurocode Short Throw Shifter/inlet pipe/sways/end links/alu kruz//S5 front brakes//APR carbonio intake//SPM Test & downpipe//APR stage 2 flash
    Feb 25 2004
    Tampa
    The Bilstein B12 works good for me. OEM sport is outrageously expensive. I was looking at replacing mine and the dealer quoted some ridiculous price. The Bilsteins were less than $1000 shipped.
    Previous:
    2007 RS4
    2005 S4
    2001 S4
    Nov 12 2012
    2005 Malibu boat
    Portland/Or
    I picked up the oem sport from Dennis. He will ship them Monday or Tuesday which is awesome but here's the rub: I am getting my hip replaced on Tuesday so can you imagine having that box sitting on the shop floor for at least 6 weeks all the while saying install me! Oh well I can't even drive for a few weeks.
    Established Member Two Rings MAG76's Avatar
    Mar 25 2014
    2013 Triumph Speed Triple
    Hi M1ke. Hope the surgery goes well. The car and parts will always be there, just heal up soon. Take care.
    Sep 10 2009
    2015 BMW M235i
    Yorktown, VA
    Quote Originally Posted by kaklexicon View Post
    I did this for a short while - like others have said, I don't recommend it. Once the stock shocks go, you will be paying all over again just to replace them. Suggest a kit designed for a lower stance, either shock/spring set or coil over kits. I have done ST coils, but wasn't a fan - they went real low, but they were too stiff, not very forgiving, and only felt good on a track or nice roads. I recently moved to the Bilstein/Eibach B12 pro kit (http://www.audizine.com/forum/showth...o-Kit-A-Review). Sits about the same height, but smoother ride.
    Like everyone has noted - almost no drop kit (coil or spring/shock) will be as soft as OEM kits. But most of us like the sportier feeling of our kits and the better appearances - so we are willing to tolerate the differences.
    Jan 13 2006
    Houston
    Quote Originally Posted by hoppy6698 View Post
    Yet another reason i don't believe the STs are the same as the KW V1's.
