So I got a few error codes which i then scanned. The issues are shown below.
Is the P0139 Oxygen sensor related to the carbon buildup issue? I know some of you had the work done under warranty even with a tune. You guys know what the other two issues are about? I'm taking my car in later this week for the 25k work so i'll be bringing it up but would like to have some more knowledge before I take it in. Thanks.
Address 01: Engine (J623-CCBA) Labels: 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 X08 0003
Revision: --X08---
Coding: 0104000A240F0128
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 32600065658FEE8E527-8067
1 Fault Found:
6485 - Oxygen (Lambda) Sensor B1 S2
P0139 00 [104] - Response too Slow
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 40115 km
Date: 2014.03.20
Time: 18:35:33
Readiness: 0000 0000
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
Component: BCM2 2.0 H05 0435
Revision: 00002001
Coding: 0D0100
Shop #: WSC 06325 000 00000
VCID: 77F6F171C66DCBA6A59-8022
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 232
Mileage: 36895 km
Time Indication: 0
Date: 2013.12.27
Time: 10:06:31
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E1161504C7
Coding: 00C303
VCID: 830E15A102B51706091-80D6
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 154
Reset counter: 35
Mileage: 34881 km
Time Indication: 0
Date: 2013.11.17
Time: 16:04:41
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.20 V
Count: 6
