Results 1 to 11 of 11
    Active Member One Ring AuG3's Avatar
    Apr 19 2014
    Audi a6 c6 2.4
    Lithuania
    c6 tail lights replacement: EURO to USA.
    Hello dear colligues,
    I have euro-edition a6 c6 sedan and yesterday I have broken my highline tail light. Before this accident, the light was just easily cracked (factory waster). So, I tried to glue some protection (stripe), but it got worse. Here is pic: https://imagizer.imageshack.us/v2/64...0/836/pvlj.jpg . So, I found one USA tail light, but this raised me a question. Question will be: does USA led taillight replacement will be without any problems to euro car? I mean electricity problems with turn signals. USA c6's tail lights blings differently compared to euro. Is there any place for orange bulb light? Or it is the same light like euro?
    Thank you.
    Veteran Member Three Rings broker23's Avatar
    Nov 03 2013
    2014 Shelby GT500
    Chicago
    I have a 2010 A6 and if your tail light housing is anything like mine you only need the lens cover
    Sent from my SPH-D710 using Tapatalk
    Heres a link this will should help you understand why you only need the lens
    http://www.youtube.com/watch?v=C8ppQmEYd-o
    2018 Audi S7 Prestige Loaded
    EPL Stage 1
    21x10.5 Vossen HF-1
    Factory Bang & Olufsen
    2010 Audi A6 3.0t Prestige SportPackage
    G.I.A.C Stage 1
    Stasis Exhaust
    JL 12W7 JL 600/1. SOLD
    Apr 19 2014
    Audi a6 c6 2.4
    Lithuania
    Thank you for the advice. I found out that there are two types of USA taillights. First type is, that stop and corner light is same and the second one is, that corner signal is under white glass.
    It is possible to remake to euro tail light, but is it worth? Maybe replacing the glass, but there is no guarantee for tightness.
    Nov 03 2013
    2014 Shelby GT500
    Chicago
    They will not leak they are designed this way
    EPL Stage 1
    21x10.5 Vossen HF-1
    G.I.A.C Stage 1
    Stasis Exhaust
    Nov 01 2012
    1993 Mazda Rx-7
    San Antonio, Texas
    I may have a set coming available for sale
    Apr 19 2014
    Audi a6 c6 2.4
    Lithuania
    Thank you, but I found euro edition new ones with no waster. Probabaly cracked c6's light is one of this model bugs.
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by AuG3 View Post
    The taillights are the same between the US and Euro cars. The only difference is coding the lights through VAGCOM. I recoded my taillights to ROW (Rest of the World) so that I can use an orange bulb as a turn signal and keep the brake lights constant when braking and turning.
    '09 C6.5 A6
    Apr 19 2014
    Audi a6 c6 2.4
    Lithuania
    Yes, I agree about coding, but this is the second type tail lights. First one has turn signal which is below trasnparent glass. So, there is nothing to do with coding. Cracked 4f's lights is often waster.
    Jul 17 2011
    Sin City, USA
    I beg to differ. I recoded my taillights so that the bulb behind the clear lens (was red now Amber) is used as a turn signal and not a hazard flasher (only when rear fogs are on). Here is a pic/diagram of the light...
    And a video of it after the recoding and changing one of the bulbs to Amber...
    http://i1113.photobucket.com/albums/.../VIDEO0002.mp4
    '09 C6.5 A6
    Apr 19 2014
    Audi a6 c6 2.4
    Lithuania
    Thank you for detailed description :) I just bought new ones (Euro).
    Apr 19 2014
    Audi a6 c6 2.4
    Lithuania
    Hello,
    Ok, have another problem. My right tail light four brake led's burned out. Is it possible to replace several leds or I need to replace all?
