Results 1 to 15 of 15
    Mar 22 2013
    mk1 jetta coupe, c4 lt1 vette
    mattapan ma
    18x8 18x9 staggered wheel tire size, anyone help?
    anybody assist in what tire size i should run to keep the same rolling diameter? wheel size is 18x8 and 18x9, not looking to stretch and i have a nice set of 235/40's so if i could use 2 of those on the rear i'm thinking maybe 225/40 up front?
    searched and found a few calculators and didn't see one that accounts for rim width and found a few threads with much more hardcore stagger setups than mine.
    Senior Member Two Rings Crusty128's Avatar
    Nov 09 2011
    Montreal
    As weird as it appears, width does't have any impact on rolling diameter. Even stretched like hell, wheel keep the same height.
    Just go with the same tires specs both front and rear please.
    Bagged S4 B6 Avant 6-spd
    Mar 22 2013
    mattapan ma
    hey thanks, i just found this on tireracks site
    "The width of the rim will influence the width of the tire. A tire mounted on a narrow rim would be "narrower" than if the same size tire was mounted on a wide rim. NOTE: Because the overall diameter of a steel-belted radial is essentially determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width."
    in my brain it made sense that stretching the tire wider would lower its od, but i guess im wrong. looks like i wont need any new tires
    Mar 22 2013
    mattapan ma
    the more i think about it, the more sense it makes.
    Quote Originally Posted by Crusty128 View Post
    I'm but positive this is true. I've heard both sides of this argument a dozen times.
    2008 B7 2.0T Quattro 6MT
    Sold:
    2013 VW CC R-Line
    2005 B6 1.8T Quattro 6MT
    RIP:
    2002 B6 1.8T - April 2019
    2004 B6 3.0 - August 2018
    Veteran Member Three Rings J.the W.'s Avatar
    Aug 30 2007
    2014 CP M5, 2006 Pathfinder LE
    Az.
    You'll be fine with a 225 front 235 rear. That's what I'm running stretched on a 9.5" front and a 10" rear.
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    Question is why would you run a staggered set up on this under steering relatively low powered car? If you want to run a staggered set-up buy a Different car....form follows function.
    Cheers,
    Jim
    Veteran Member Three Rings MidwestB6's Avatar
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    225/40r18 = circumference of 78.8 inches
    235/40r18 = circumference of 79.8 inches
    Please get the same tires on all four wheels, not doing this will destroy your center diff. If you want it to look wider in the back, get wheels with a lower offset.
    2004 Light Silver 6MT S4
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by MidwestB6 View Post
    Correct, you do not want to run different sizes from and rear. It puts extra strain on the center differential.
    I suggest running 18x8 all the way around (the stock size) and using a 235/40R18 or 245/40R18 tire. Don't try and cram huge wheels with skinny tires on there. It's unsafe and looks ridiculous.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Mar 22 2013
    mattapan ma
    its been established higher up in this thread that wheel width does not change outer diameter of the tire, so as long as all 4 tires are the same size staggered rim width will not harm the center differential and looks way better than square set up to me. i dont really think 18x9 with 235/40 really fits into the huge wheel with skinny tire category.
    Apr 24 2009
    Frisco, TX
    I have to disagree. 235 tire on a 9" wheel is too small. 9" wheels typically run a 255 tire for a squared-off sidewall, or maybe a 245 at the smallest. Your rotation options are also limited by going staggered. I don't really see the point of running a wider wheel on the back with the same size tire as up front. But hey, it's your car and your wallet.
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    245 on a 9" wheel is a "squared sidewall. 255 will sit wider than the wheel itself and will only serve as a bit of a "curb guard".
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    Did a bit of searching, here's a C5 with 18x8.5 fronts and 18x9 rears. http://img26.imageshack.us/img26/8759/mg2550.jpg
    Same car with 18x8.5 fronts and 18x10 rears. http://img705.imageshack.us/img705/2717/imag0356i.jpg
    Or maybe more relevant... check out the B6's in posts #163 and #164... http://www.audizine.com/forum/showth...=1#post8162434
    So what you want to do can totally be done. A lot of us are going to disagree, but who gives a damn what we think?
    Jan 03 2014
    Minneapolis
    18 x 9 with 225/40 ZR18 BFG Sport Comp 2's
    I ordered 255's and Discount Tire messed up and put on 225's...
    Jan 03 2014
    Minneapolis
    255's on now.. and am rubbing in front... may drop to 245's
