Originally Posted by
MikTip
Any DTC codes with the miss fires?
This was a while back, I havent had a missfire in a while.
Address 01: Engine (8E0 909 559 E)
18:06:42
2 Misfire (total)
2 Misfire Counter Cylinder 1
0 Misfire Counter Cylinder 2
0 Misfire Counter Cylinder 3
0 Misfire Counter Cylinder 4
0 Misfire Counter Cylinder 5
0 Misfire Counter Cylinder 6
-1.6 % Lambda Control Bank 1 Sensor 1
-3.9 % Lambda Control Bank 2 Sensor 1
Tuesday,24,December,2013,15:05:58:11215
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Freeze Frame Data for address 10
PID02 DTC that caused freeze frame data storage: P0431
PID03 Fuel system 1/2 status: Closed loop, using O2 sensors
... Closed loop, using O2 sensors
PID04 Calculated load value: 46.7 %
PID05 Engine coolant temperature: 99 °C
PID06 Short Term Trim - Bank 1: 2.3 %
PID07 Long Term Trim - Bank 1: 4.7 %
PID08 Short Term Trim - Bank 2: 2.3 %
PID09 Long Term Trim - Bank 2: 0.8 %
PID12 Engine RPM: 2560 /min
PID13 Vehicle speed: 98 km/h
Monday,24,February,2014,18:24:44:11215
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
PID04 Calculated load value: 23.9 %
PID05 Engine coolant temperature: 98 °C
PID06 Short Term Trim - Bank 1: 0.8 %
PID07 Long Term Trim - Bank 1: 3.9 %
PID08 Short Term Trim - Bank 2: -0.8 %
Monday,24,February,2014,18:26:17:11215
