Originally Posted by
mcanedo92588
Sounds logical, how time consuming is the process of changing the valve stems? I usually get work done from my mechanic friend for about $25-30 an hour depending on the job and wondering how long it might take to figure out when I can schedule it. Also, I would need 30 of these correct?
Replacing the valve stem seal without removing the cylinder heads, is not difficult for someone with mechanical experience. Its a lot less work and expense than removing the heads.
The procedure is comprised of the following basic steps.
Position crankshaft at number 1 cylinder bottom dead center piston intake stoke.
Remove camshafts from the heads.
Remove the valve lifters/cam followers from the head.
Install a air pressure hose adapter into the spark plug hole, then apply compressed air pressure to the cylinder. Use a pressure regulator set to about 100 psig to maintain air pressure in the cylinder. The piston must be at the bottom dead center of the intake stroke, with all the valves closed.
Remove valve springs.
Remove old valve stem seals,
Install new valve stem seals on valve guides,
Replace valve springs.
Remove air pressure from cylinder move adapter to next cylinder in firing order.
Perform the above steps to the other cylinders after rotating the crankshaft to position each cylinder at BDC intake stroke, in firing order sequence, before applying compressed air pressure to the cylinder. After the seals on all the valve guides have been replaced, reinstall the cam shafts.
Reinstall valve covers and spark plugs/coil packs..
It would take me about 4 to 5 hours working steadily for me to do this on a six cylinder engine, care must be used to prevent errors with air pressure and removing the valve springs.
Once, I dropped a valve into the cylinder after removing the spring, due to lost air pressure in the cylinder. At first I was really angry because I thought the head would need to be removed to retrieve the dropped valve. Instead, after cooling down, I used a powerful little magnet placed in the end of a length of small tubing that would fit into the valve guide. With the tubing pushed down into the cylinder through the valve guide, I caught the end on the dropped valve stem and by slowly pulling the tubing back out of the valve guide, pulled the end of the dropped valve stem back up into the valve guide. Then with the valve back on the seat, reapplied air pressure and reinstalled the valve springs.
Parts needed for a 3.0l V6 are a set of 30 valve stem seals, and a new valve cover gasket set. If needed replace the timing belt and water pump at the same time to save labor costs.
