Tripped this code the other day.. stone cold engine, hits 0 vacuum and car hits a wall. (accelerating in 1st.) 30 seconds later its fine.
well into the evening after 3 stops/restarts.. trips the ECS light, ABS and traction light on solid, no CEL
code pulled is the p1639 http://wiki.ross-tech.com/wiki/index...7/P1639/005689
Cleared and ran TBA.. did not return.. multiple TBA, stroking the TB postion up and down with the pedal... no code, nor any weirdness with block 60.
checked block 62.
3rd and 4rth values are supposed to be 2:1 ratio.
starting value:
14.7 7.3
ratio remains about right up to half throttle and starts to drift out of spec leading up to WOT
final numbers at WOT:
72.x 37.x
That being said the first and second values transposed themselves perfectly. So im not sure if the 2:1 ratio rule for #3 and #4 is a hard rule or just a guidline. Seeing as how the other two percentages were fine.
Ran the car next day and there were no issues. I suppose its possible that the TBA did the trick, but I have my doubts.
Suggestions or things to check would be appreciated.
