Originally Posted by
melomandn
but no one ever preaches to people who take out their cats adding more air pollution...
Well, some of us would, but why bother? This is one of the reasons I run a HFC and not a test pipe. Also, performance differences are negligible and it doesn't smell like shit now.
GrapeBandit
no pace car, but my oil consumption hasnt changed, plus ic I rev the shit out of it wil cardboard under the dump, you see nothing
I'm no master of PCV systems, but if you have removed the source of vacuum to the PCV system then the vapor is only getting pushed out while under boost, which you won't see any of while sitting still.
hence dumping pcv or running an OCC
The reason I mentioned that at all was because you said "if you want to save money on oil, just reroute the PCV directly into oil fill cap."
the little oil that does mange to escape, is negligible
I noticed you didn't reply to my point about dumping oil and road safety for others on the road, is that negligible?
GrapeBandit
so let me get this clear. you guys are
green peace when I say dump to ground, but you guys have no problem burning it out the exhaust.
so in other words you are saying, please dont dump your pollution on the ground, dump them in the air.
If I had to choose between you dumping your oil on the roads or having it burned off, yes, I would choose having it burned off. In fact, that is
exactly what the stock system does, albeit within the combustion chamber instead of the exhaust system.
The fact of the matter is that owning and driving any vehicle introduces more pollutants and poses more externalities on society than not owning a car would. That is exacerbated when trying to increase the performance of the vehicle. There are certain aspects of pollution that are unavoidable and others that can be avoided, I try to avoid them whenever I can.
melomandn
Same point I was making earlier, its impossible to have a performance oriented car and be a tree hugger.
Not impossible, but there is some "bargaining" taking place for sure. I care about the environment, I also like working on my car. Unfortunately performance electric vehicles powered by renewable energy sources are way beyond my price range/non existent, so I make due with what I can for now. As I said earlier, there are forms of pollution that are unavoidable, choosing to dump your PCV to the ground is definitely avoidable.
GrapeBandit
I dont measure it, and im sure nobody else running a ground dump does either. my oil consumption is the same, and I dont leave any stains on the ground
Keep rationalizing it. Also, replying within the quote as you did before makes it really difficult to quote you back, just FYI.
