Hi all
I only joined Audizine recently but I really need some pointers. PLease! I've an 03 A4 (B6) 1.9 tdi.
In a nutshell. My instrument cluster somehow suffered electrical damage. Earlier this year I sent it to 2 of the 'best' cluster repair centres in the UK without any luck. I wasn't given much to go on except told it was beyond repair, and that they couldn't pull info off the processor or something to that effect. all along I've wanted to change my cluster for a matching cluster. Garages won't touch the job, in fact all but 1 VW/Audi garage, and he only said he'd fit Brand new. If he or the nearest Audi dealerships do it, it's too much ££ for me. I've got a matching donor cluster on the way via ebay, as I type, and the seller has given me the SKC code for this which will save me some hassle.
I bought a USB OBDII 409.1 Cable VAG-COM 409 cable from ebay. Works with the VCDS Vag com 409 it came with on a CD. I've also downloaded Vag K commander, vag tacho. I've only partially had some connection with Vag Commander 1.4. and no luck with vag tacho. Vag commander goes as far as allows me to select the cluster tab, but It doesn't retrieve any data, for any module in fact.
I'm assuming my cable may be set up slightly wrong? but I don't even know if it is hex can compatible or whatever?
Any ideas? Any pointers? Should Vag commander be able to get the SKC off the ECU do you think?
this is the cable I bought.
http://www.ebay.co.uk/itm/3509823321...84.m1439.l2649
I've got the SKC from the guy sending me th donor cluster. All I need Vag Commander to do is get the SKC for my cluster OR failing that hopefully get it off my ECU (if my cluster's memory, or chip is too damaged). Then swap clusters by Adaptation.
