Results 1 to 40 of 56
    Registered Member One Ring Mr. Smiley's Avatar
    Jul 29 2013
    This is the only car I have ever owned
    Atlanta
    FMIC kits for the B5 Platform
    Most intercooler kits I have seen state that the kits can be installed on both the B5 A4 and B5 Passat 1.8t. I am wondering specifically if the CTS Turbo FMIC for the B5 A4 will fit onto a B5 Passat. I contacted CTS Turbo and they said that they cannot guarantee fitment because they have not tested the kit on a Passat. I am not too worried about the intercooler core fitting inside of the Passat bumper. I am more worried about pipping issues. Are there any reasons why the pipping in this kit would not work on a B5 Passat?
    Thank you very much!
    Apr 01 2011
    B5 on jack stands
    charlotte
    It would fit..
    Apr 01 2011
    B5 on jack stands
    charlotte
    Not trying to knock the sale but unless you do not plan on running 450hp
    EBay has intercoolers that are half that and can handle
    300hp
    Senior Member Two Rings JaysA4's Avatar
    Feb 17 2013
    2000 Passat 1.8t FWD 1998 2.8qm 1999 1.8qmt
    Champaign IL
    Quote Originally Posted by demonmk2 View Post
    300hp
    Word. Itll fit.
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    or buy ebay piping and the tr18 intercooler from treadstone
    Senior Member Two Rings kraylon's Avatar
    Apr 11 2007
    Denver
    Quote Originally Posted by ray4624 View Post
    This is what I was going to do until I found a custom intercooler and piping in the classifieds
    01 Audi A4 Quattro, Franken Turbo, Motoza Tuned, Abd intake, Bilsten sports, H&R springs, Neuspeed front, rear sway bars and exhaust, Atp test pipe, JHM linkage, complete rs4 body kit, 18" Falkens, Nitto invo tires, Forge 007 DV and Unos Mbc, 034 street motor & trans mounts.
    Nov 27 2010
    mass
    I'll eventually sell my racetec setup and do that
    Feb 14 2013
    Pearl City, HI
    Installed the tr18t from treadstone pretty much bolt on with the cxracing fmic pipe kit minor modifications made to bracket and turbo outlet coupler that goes to fmic
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    eBay core FTW
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    $950 should be enough to scare you away. fmic kits are a total rip off. can make your own for less than half, even someone with minimal skills
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Apr 01 2011
    B5 on jack stands
    charlotte
    Don't know who makes it there is the same kit parts/size wise on eBay
    For half that of CTS.
    Make your own for around 150-200 bucks.
    Veteran Member Three Rings teleTay's Avatar
    Jul 19 2010
    2000 A4 Avant, 2004 S4 Avant
    SLC UT
    i know its already a cheap ebay brand
    but i can get a small discount on the cxracing kit
    Apr 08 2013
    Northern California
    Hey I was under the impression that eBay fmic's were not very effective. I could be totally wrong. I've been saving up for apikol smic but $200 sounds like a deal to me.
    ~2001 a4 1.8tqm~ Giac-X chip, Apr exhaust, Koni Yellows/Eibach Springs, 17in Br05 BremmerKraft Rims, Pheonix Gold Amp, Alpine deck, 2 12in Boston G1 Subs.
    Sep 09 2012
    Austin, TX
    Depends on which ebay core you go with and what kind of power you are planning on making. A CXRacing core should be good for stock turbos and K04s/hybrids.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    CXRacing FMIC with the 2.5 in piping is the only Ebay core worth installing.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Nov 27 2010
    mass
    Quote Originally Posted by BaronB5 View Post
    If you never plan on going bigger then ft then the Apikol smic is ideal. Doug at ft actually suggests an upgraded smic over an fmic.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Too bad they cost $200+ more... I was hoping to go SMIC over FMIC and avoid all the cutting/aggravation/non-OEM piping/non-stealth look but alas CX Racing piping won me over (already had a CX Racing core, paid $240 for piping). Even used upgraded SMICs go for $500+.
    2001 Corvette (C5) Z06
    Nov 27 2010
    mass
    Yea obviously the FMIC seems to be cheaper. There used to be a godspeed SMIC but there wasnt enough interest to keep it around.
    Jun 08 2011
    Stillwater, MN
    I'm finally looking to upgrade my stock intercooler with a FMIC. I don't plan on going bigger than my K04, thus feel a "decent" Ebay kit is my route. I keep reading how 2.5" piping/core will create turbo lag and power loss, however I can't find anything on Ebay (complete kits or piping kits/cores) that are under 2.5" for some reason. I did find ONE core that's 2.25", but could very well be a complete POS?
    http://www.ebay.com/itm/231006140145...84.m1423.l2649
    If I were to purchase this core that's 2.25", am I able to use piping that's 2.5"? Isn't that what the couplers are for? I'm 150% Newbie on this topic, so please forgive me. Another thing I've noticed is that in order to get a complete kit from Ebay that included "mounting hardware" the cost is at least $80-$100 more. Is that necessary? If not, what mounting hardware do I need if purchasing somewhere else? And where to purchase it? The more help the better as you could imagine.
    Thanks in advance!
    2001 A4 1.8T Quattro Manual Brilliant Black-Motoza e85 K04 Tune on 550cc Bosch Injectors and 4BAR w/ Borg Warner K04-15 running 21PSI-FastWayRacer Ebay FMIC w/ 2.5 Piping-OEM N75-Axiom Performance 255LPH FP-3" Eurocode Tuning Test Pipe-2.5" XS-Power Exhaust-UPGR8 TIP-710N-Single Mass Valeo Clutch-Green Coolant Temp Sensor-Standard OEM Plugs-Standard-OEM MAF-Rare 17" Alloy Wheels From Romania
    Jan 16 2006
    LA CA
    Just buy this one, its the best ebay FMIC. http://www.ebay.com/itm/94-01-Audi-A...2198f6&vxp=mtr
    Nov 27 2010
    mass
    If you really want 2" I'll sell you my racetec. Otherwise that eBay one is you're best bet as stated
    Jun 08 2011
    Stillwater, MN
    Thanks for the offer Ray, but I'm assuming the racetec will be far more expensive. If I change my mind however, I'll definitely let you know.
    Jun 08 2011
    Stillwater, MN
    Quote Originally Posted by nynoah View Post
    That's one in particular I have saved on my Ebay page.
    Here's a few other listings I've been monitoring as well....I believe all of them come with full 2 yr warranties as well, especially the 1st one I pasted below seeing as it doesn't state that in the listing, the seller did state that in an email I sent via Ebay so it's "on record."
    http://www.ebay.com/itm/171012398917...84.m1423.l2649
    http://www.ebay.com/itm/300636053034...84.m1423.l2649
    http://www.ebay.com/itm/181143757671...84.m1423.l2649
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=201068308169
    http://www.ebay.com/itm/400662679277...84.m1423.l2649
    What I don't understand is how the mounting hardware kits cost $75-$100 more? Aren't we just able to buy the mounting brackets elsewhere for FAR cheaper than that? Seems like an AWFUL LOT of money for 4 mounting brackets doesn't it?
    Jun 08 2011
    Stillwater, MN
    Actually, what about it is the best? The size surely doesn't seem like it would fit the best, that's for sure. 7 inches? I've seen 5" & 6" kits on Ebay too, but 7" seems like it would just be a bigger pain in the ass to fit. I'm looking to install a kit that would require "the least" amount of chopping, this a 5" or 6" kit would strike my interest more. 1-2" can go a along way with a DIY job.....been there done that, heck even 0.5" difference has caused hell for me before....
    Jun 08 2011
    Stillwater, MN
    I'm trying to find a mounting bracket kit for less than $75 since that's the cheapest I can find on Ebay. For those of you that purchased the piping kits and/or cores separate from each other on ebay, or even them together but not including a mounting kit, what have you guys used to mount it? Some of you have provided links for cores and piping kits, but you had to mount it somehow right? lol......
    I found this mounting hardware kit on Ebay, however there's other listings that just include the one larger mounting bar. Can I get away with just purchasing the one larger bar? Or, do I need this entire kit with the smaller pieces too?
    http://www.ebay.com/itm/390422662587...witem=&vxp=mtr >>>>Entire Kit
    http://www.ebay.com/itm/like/181319913059?lpid=82 >>>>Just Larger Bar
    Apr 01 2011
    B5 on jack stands
    charlotte
    That gsp one would do just fine.
    As far as brackets go just go to home depot
    And buy a strip of aluminum. ( $3 )
    That's what I did, works fine.
    Apr 01 2011
    B5 on jack stands
    charlotte
    And even if you go bigger as far as turbos
    You don't necessarily need bigger charge pipes.
    Feb 06 2013
    WV
    If I was going to go SMIC with a K04 or even a FT or a hybrid I would use 1st gen DSM side mount. They have been used at over 300AWHP on their cars without issue so I a sure it would do the trick.
    http://www.ebay.com/itm/1G-DSM-ECLIP...tr#ht_27wt_908
    I used one an 1986 Toyota MR2 that I turbo'd and never had an issue. On an MR2 its mounted behind the cabin so there is considerably less air flow. I made 226rwhp with it and 2nd gen Eclipse T25. It should work just fine on our A4's. Maybe mod the inlet and outlet.
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Dec 13 2010
    FL
    QUOTE=zandrew;9662325]If I was going to go SMIC with a K04 or even a FT or a hybrid I would use 1st gen DSM side mount. They have been used at over 300AWHP on their cars without issue so I a sure it would do the trick.
    I used one an 1986 Toyota MR2 that I turbo'd and never had an issue. On an MR2 its mounted behind the cabin so there is considerably less air flow. I made 226rwhp with it and 2nd gen Eclipse T25. It should work just fine on our A4's. Maybe mod the inlet and outlet.[/QUOTE]it may not fit in the stock location, depending on the dimensions. also, you would have to cut off the inlet & outlet and weld them on in the right direction
    Feb 14 2013
    Pearl City, HI
    Tr18t with cx racing pipe kit cost me about $500, only thing is had to cut bumper support a little and modify the bracket that comes with the pipe kit and walla reasonabley priced fmic with quality core
    Jun 08 2011
    Stillwater, MN
    Quote Originally Posted by jmcwayne808 View Post
    Ouch, $500 is far too much to spend on a decent FMIC with my setup.
    Jun 08 2011
    Stillwater, MN
    In buying a piece of aluminum, can you elaborate a bit more? What exactly did you do to modify the store bought stuff to make it work?
    Sep 10 2013
    Wow. I got a cheap eBay core, strip of metal from Home Depot to make my bracket, and I'm working on piping now.
    Apr 01 2011
    B5 on jack stands
    charlotte
    Quote Originally Posted by pichno View Post
    My cross bar mount i made basically like the on sold on eBay.
    And two brackets shaped like an L to mount the intercooler to the crossbar.
    Jun 08 2011
    Stillwater, MN
    Honestly, that doesn't help me much. Of course you're making them to resemble ones purchased, but "how?" What tools did you use to cut, fit, measure, etc etc? What steps did you take? I'm not looking for a complete DIY or anything, but if what you did works and is a cheap alternative, I'd bet others would also appreciate the logistics as well.
    Orange County, CA
    I'm running a Racetec FMIC with my Frankenturbo F21 w/ 440cc injectors also w/ GIAC.
    B5 Parts For Sale
    Sep 10 2013
    I'll be mounting mine today. From a quick glance, here's what you'll need:
    -A long piece of aluminum or steel strip, the length of the radiator, with holes drilled (or you can drill yourself)
    -Two or three more shorter pieces of aluminum or steel to make the L brackets.
    Now, the length of the L brackets will vary based on your core. But I'll use a tape measure to figure that out. For cutting, I have an air tank and a cutoff tool, but you could also use a small handheld saw.
    I'll give some more specifics when I get done this morning.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Does anyone run a phenolic spacer between their fmic and condenser?
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    Quote Originally Posted by Avant Nate View Post
    I don't, wouldn't be a bad idea but I would have to cut more of my bumper since my core is 2.5". I have about 1/8th gap between the fmic and condenser. I also don't have a mounting bracket, the combination of my piping and how close my fmic is to my bumper I've never seen the need for a bracket.
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    If you did this, then you would block airflow through the condenser and radiator where the spacer would be located, wouldn't you?
    From my perspective it seems better to have slightly warmer air flowing through that area of the condenser/radiator than no air at all.
