Results 1 to 9 of 9
    Apr 11 2012
    Tire Size: 19 inch wheels x 10 inch wide
    What tire size do you guys recommend for this setup?
    I don't want a stretched tire.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Depends on how low you are and the wheel offset. You will have to stretch regardless. 255 is the widest most of us run and that will be very stretched on a 10" wide wheel, 265-275 would be better but greatly increases the risk of rubbing.
    Apr 11 2012
    Quote Originally Posted by o1turbo30v View Post
    These are the wheels: http://avantgardewheels.com/m310.php
    Would 245/40/19 work?
    Feb 06 2012
    Allentown, PA
    This is a very helpful site, http://www.willtheyfit.com/.
    Dec 01 2011
    245 will be stretched on a 10". 255 will be a very minor stretch but will look good and fitted, not too stretched. i'd recommend the 255 as with 265 and up you'll prob start rubbing if too low.
    IG @theshawon
    Mar 04 2010
    Vancouver
    like others have stated already, it depends on offset and how low you are..
    245s will be a safe choice but it is definitely a stretch
    Modifications: Parents ran out of money so they bought me tires that were way too small for my wheels.
    PART-OUT THREAD: CLICK HERE
    http://instagram.com/crisostomoz : most up to date upgrades to the car, as well as random things.
    Apr 11 2012
    Sorry the wheel is actually 9.5" wide.
    Does 255/35/19 or 255/40/19 work?
    What about 265?
    Established Member Two Rings shyammaharaj's Avatar
    Sep 20 2014
    2005 Ford Courier
    Auckland, New Zealand
    Did you manage to get the wheels on?
    |Life is better when you drive a nice car|
    Nov 03 2007
    A6(C7.5), Q7(4M), Q5, A5(B8.5), Escalade(MY08/MY15), H2, 360
    I put on 265 30 19 yesterday then turned around returned those and bought 275 30 19 today on my 19x10 only for the rear. i run a 40 offset. I have stock sport suspension and not rubbing, i will install my ST hopefully this weekend.
