Hi Guys,
I am in the middle of a pretty large build and wanted to post what I plan on doing and the steps it takes to get there, along with the results. This is mainly about the engine build but I have some other goodies going on the car (RS4 Cluster, ECS Stage 4 BBK Fronts, ECS Stage 3 BBK on the rears (designing and making my own brackets) and some other custom parts) and I will post them once they are installed.
I am working with Redline Speed Worx to do an awesome build and here is what I am doing. My ultimate goal is 600 AWHP and I think with this setup I can get there.
Engine and Exhaust:
Integrated Engineering Custom 2.0 Stoker Short Block (IE Race 1000 model)
Integrated Engineering AEB Stage 1 Head
Integrated Engineering Street Cams
Integrated Engineering Manifold w/ Hemi 80mm Throttle Body
Integrated Engineering Oil Pump Kit
Integrated Engineering Billet Timing Belt Gear
Integrated Engineering Catch Can
Integrated Engineering Stage 3.5 Timing Belt Kit
Integrated Engineering Billet Pulleys
Integrated Engineering FSI Coil Adapters
Full-Race Twinscroll Tubular Manifold
Borg Warner EFR 7670 .92AR IWG
Full-Race Billet Wastgate Actuator
RSW Custom FMIC (PT Core)
RSW Custom Down Pipe
Tial 50mm QR BOV (Recirc)
Accusump 2QT Accumulator
Accusump Turbo Cooler
ARP Everything
RSW Custom Turbo Lines
PreciseD Custom 3" exhaust with 3" boost dump valve
OEM R8 Coil Packs
Transmission :
RSW Custom 8 Puck Southbend Stage 3 Clutch w/ Flywheel
JHM 4:1 Center Diff
JHM Trio Shifter
034 Track Mount
Fuel and Tune:
Integrated Engineering Fuel Rail
034 "044" Surge Tank
Custom Return Fueling
"040" In Tank Pump
1200cc Bosch Injectors (UM Spec'd)
Custom United Motorsports Tune
UM 4" Pro-MAF
Snow Performance Stage 2 Meth Kit w/ 2.5 Gallon Tank
Braking and Suspension :
ECS Stage 4 BBK w/ 2 Piece Rotors (Front)
ECS Stage 3 BBK w/ 2 Piece Rotors (Rear)
KW V1 or V2 Coil Overs (Still Deciding)
H&R Sway Bar (Front)
034 Sway Bar (Rear)
034 Adjustable Upper Control Arm Kit
Interior Mods
OEM RS4 Gauge Cluster
Symphony II+
Euro RS3 wheel with Single Stage Airbag
ECS Boost Gauge
Euro RS4 Seats
If you have not checked out Redline Speed Worx they are doing some pretty crazy stuff and have one of the fastest TTRS's around.
Thanks to ECS, Full-Race, United Motorsports and Integrated Engineering for all of the help and great products you have supplied me with.
