Results 1 to 40 of 71
    May 13 2008
    MQBs
    San Francisco
    Wheel / Tire Setup and Offset Guide
    The guys in the B7 RS4 section just started this thread, and since there's always a bit of a looming cloud over what can actually fit.. I think it would be good for us too. Please post a pic if possible!
    TONS MORE INFO HERE FROM THE B7A4 GUYS
    Brand/Name:
    Size:
    Weight:
    Offset:
    Spacer(s):
    Camber:
    Tires:
    Suspension:
    Spring Rates:
    Ride height:
    Fender mods:
    Rubbing:
    Brake Spec:
    Other:
    Brand/Name: Ground Force GF06 FOR SALE
    Weight: Approx 27lbs each
    Offset: ET32
    Spacer(s): N/A
    Camber: OEM Specs, 034 Upper Control Arms
    Tires: Michelin Pilot SuperSport 255/35/19
    Suspension: KONI's | H&R springs
    Spring Rates: N/A
    Ride height: Will Measure
    Fender mods: Rolled/Pulled Fronts - Pulled Rears
    Rubbing: Fully loaded on VERY severe bumps, I hear a slight split second brushing sound
    Brake Spec: OEM Calipers / JHM LW Rotors
    Other:
    Brand/Name: Fifteen52
    Weight: 21lbs
    Offset: ET32
    Spacer(s): N/A
    Camber: -1.8 F OEM Rear
    Tires: Bridgestone Potenza RE-11
    Suspension: SAME
    Spring Rates:
    Ride height:
    Fender mods: Rolled Front - Pulled Rears
    Rubbing: Zero
    Brake Spec: OEM with JHM LW Rotors
    Other:
    Past: B7 S4 Avant | Glacier White 8V S3 Build ig: @harithalbadri
    Veteran Member Three Rings auxnbus's Avatar
    Feb 13 2010
    '15 BMW i3 REx, '11 Toyota Prius
    Carmel, IN
    Nice - saving spot and will update post once my new wheels arrive/get mounted. Pics w/ spacers to come.
    Brand/Name: Stock Avus
    Offset: +45
    Spacer(s): 10mm F&R
    Camber: Pending Alignment
    Tires: Michelin Pilot SuperSport 235/35/18
    Suspension: KW V3
    Spring Rates: Whatever comes w/ KW V3
    Ride height: F24.75, R25.25
    Fender mods: None
    Rubbing: None
    Brake Spec: Front- Stoptech ST-60 355mm. Rear- Stock
    Before Spacers/BBK
    ________________________________________________
    Brand/Name: Avant Garde M580
    Offset: +35
    Spacer(s): None
    Tires: Michelin Pilot SuperSport 245/35/19
    Suspension: KW V3
    Ride height: TBD
    Fender mods: Top Screw removed
    Rubbing: None
    2015 BMW i3 REx
    2005 Audi S4 Cab - Gone but not forgotten
    This will probably get stickied since this subforum doesn't have a wheel fitment thread. Stole this formatting from the wheel thread in the B6 A4 subforum. I'm aware that I'm posting my A4 in the S4 section, but wheel fitment will be the same, with subtle differences in suspension.
    Setup #1:
    Brand/Name: VMR 708 (because RS4 reps aren't completely played out)
    Offset: +35
    Spacer(s): Spacers are overrated; buy the correct offsets.
    Camber: Something like -1.5 degrees front/rear
    Tires: Michelin Pilot Sports, 235/40
    Suspension: H&R Sport Springs | Stock struts - upgrading to coilovers shortly.
    Spring Rates: I couldn't think of anything clever to write here
    Ride height: Haven't measured it, but its somewhere around 25" - gonna get moar low shortly
    Fender mods: None - will likely pull fender liner or top screw
    Rubbing: Almost never
    Brake Spec: Stock
    Setup #2 (not finished)
    Brand/Name: Privat Akzent (BBS LM reps)
    Offset: +32/+30
    Tires: None yet - looking at getting 235/35 all around
    Spring Rates: I still couldn't think of anything clever to write here
    Brake Spec: Stock
    Don't look at my orange stockers, or the widowmaker.
    2008 B7 2.0T Quattro 6MT
    Sold:
    2013 VW CC R-Line
    2005 B6 1.8T Quattro 6MT
    RIP:
    2002 B6 1.8T - April 2019
    2004 B6 3.0 - August 2018
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    Can we add FTG measurements as well? May help out with fitment as well
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by jmcS4 View Post
    Good idea, done.
    Dec 07 2009
    East Coast
    Great thread
    I like the format too, but let's add a few more things per A4 Quattro suggestion.
    Brand/Name: Mirro-111
    Offset: +40
    Spacer(s): none
    Camber: stock
    Tires: 245/35/19 Goodyear Eagle GT
    Suspension: Stock B6 S4
    Spring Rates: Stock B6 S4
    Ride height: Front 26 1/8, Rear even 26". Same height as on stock Avus.
    Fender mods: Front half rolled, rear stock
    Rubbing: None
    Brake Spec: Stock Calipers & rotor size
    Forget the B8, keep the V8!
    This is the formatting I stole from the wheel fitment thread in the B6 A4 subforum.
    Brand/Name:
    Size:
    Offset:
    Spacer(s):
    Camber:
    Tires:
    Suspension:
    Spring Rates:
    Ride height:
    Fender mods:
    Rubbing:
    Brake Spec:
    Sold:
    2013 VW CC R-Line
    RIP:
    Dec 07 2009
    East Coast
    Quote Originally Posted by A4 Quattro View Post
    Brand/Name:
    Size:
    Offset:
    Spacer(s):
    Camber:
    Tires:
    Suspension:
    Spring Rates:
    Ride height:
    Fender mods:
    Rubbing:
    Brake Spec:
    This is actually near perfect!
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Brand/Name: Ronal 5-Spoke (OEM S-Line Wheels)
    Offset: 43
    Spacer(s): 13f, 17r
    Camber: stock
    Tires: 235/40/18 Continental ExtremeContact DWS (winter)
    Suspension: Stock
    Spring Rates: Stock
    Ride height: LIFTED AR MODE
    Fender mods: None
    Rubbing: None
    Brand/Name: Ronal Avus (OEM wheels)
    Offset: 45
    Spacer(s): 13f, 17r
    Camber: 034 Density Line Adjustable Upper CAs
    Tires: 235/40/18 Hankook Venus V12 (summer)
    Suspension: Koni Yellow with H/R Sports Springs
    Spring Rates: +3? from softest
    Ride height: Have no idea but I have that reverse rake effect
    Fender mods: None
    Rubbing: None
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    B7
    Brand/Name: Forgestar CF05
    Weight:23 lbs
    Offset: unknown but around Et 30-35 I believe
    Spacer(s): 3mm in the back (jhm rotor bolts interfered with the wheel)
    Camber: NA
    Tires: Michelin PSS 235/40/18
    Suspension: KW V3
    Spring Rates: NA
    Ride height: 24.5
    Fender mods: Rolled
    Rubbing: None
    Brake Spec: OEM
    Brand/Name: BBS RS-GT
    Weight:21 lbs
    Offset: Et 32
    Spacer(s): None
    Camber: NA
    Suspension: KW V3
    Spring Rates: NA
    Ride height: 25.25
    Fender mods: Rolled
    Rubbing: None
    Brake Spec: OEM
    Veteran Member Four Rings Hyde's Avatar
    Sep 05 2008
    Northwest Florida
    Brand/Name: OEM Audi S5 Speedline Tri-5 Spokes/aka Potato Peelers
    Offset: et33
    Weight: 28 lbs
    Spacer(s): None
    Hubrings: Yes (OD/ID 66.6mm/57.1mm)
    Camber: Front -1.7°; Rear -1.3°
    Tires: Continental ExtremeContact DW 235/35-19
    Suspension: Bilstein PSS9
    Spring Rates: Front 575 lbs with 145 lbs helper spring; Rear 575 lbs
    Ride height (FTG): 24⅝"
    Fender mods: None
    Rubbing: None
    Brake Spec: Stock
    These are old photos, but they most closely represent the look of my car now. I actually want to raise her just a few millimeters, and go to 245/35 tires. I have just enough room.
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by Hyde View Post
    What's with all the reserving? Haha ...
    Reserved.
    Not sure how many pictures it will let me post of different set up lol
    Brand/Name: OEM 15 spoke anniversary wheels
    Weight: NA
    Offset: ET43
    Spacer(s): F:12 R:15
    Camber: NA
    Suspension: KW V3
    Spring Rates: NA
    Ride height: 25.25
    Fender mods: Rolled
    Rubbing: None
    Brake Spec: OEM
    Brand/Name: oz ultraleggera
    Weight: NA
    Offset: ET 45
    Spacer(s): None
    Camber: NA
    Tires: Michelin PA3 245/40/18
    Suspension: KW V3
    Spring Rates: NA
    Ride height: 25.25
    Fender mods: Rolled
    Rubbing: None
    Brake Spec: OEM
    Jul 28 2007
    V8's
    In an Audi
    Lets add wheel weights if possible too, tires can be found pretty easily online.
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by 65vetteC6 View Post
    Lets add weights if possible too
    of wheels? or of the piggy itself?
    if wheels: HAF! (Heavy as fuck!)
    if car: FHAP! (Fucking heavy ass pig!)
    2015 B8 SQ5
    Click Here
    Past
    Jul 28 2007
    V8's
    In an Audi
    Lol, fixed for you
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Brand/Name: MRR Catalina's
    Offset: ET 25
    Spacer(s): 5mm Rear only
    Camber: Stock
    Tires: General G-Max 245/35 ZR 19 (Tread 9" Width)
    Suspension: Stock w/B5 perches
    Spring Rates: Stock
    Ride height: n/a
    Fender mods: Factory rolled
    Rubbing: Very mild on hard bumps while turning
    Brake Spec: Stock
    BEFORE B5 perches (Never Rubbed)
    If you look closely ^.^ you can see a tiny bit of stretch with this wheel/tire setup
    AFTER b5 perches
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    No Pictures but here are my set-ups:
    Brand/Name: Team Dynamics Race 1.2
    Offset: 35
    Spacer(s): None
    Camber: Stock
    Tires: 235/40/18 Nitto NT05's
    Suspension: Stock
    Spring Rates: Stock
    Ride height: Stock
    Fender mods: Removed front fender liner Screw
    Rubbing: None
    Brake Spec:Stock
    Brand/Name: Audi B5 S4 Avus
    Offset: 45
    Spacer(s): None
    Camber: Stock
    Tires: 215/50/17 Dunlop M3's
    Suspension: Stock
    Spring Rates: Stock
    Ride height: Stock
    Fender mods: Removed front fender liner screw
    Rubbing: None
    Brake Spec: Stock
    Cheers,
    Jim
    May 13 2008
    MQBs
    San Francisco
    Added weight
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by TarlCabot View Post
    Offset:ET 25
    Tarl - Lookin' good, that's a fairly meaty and aggressive setup. MRR is who makes my wheels, and i gotta say.. I'm really happy with their styling and quality so far.
    Feb 13 2010
    Carmel, IN
    Quote Originally Posted by Kookie View Post
    No kidding... ET25 is RS4 territory! Surprised there isn't more 'poke', especially with a 9.5" wheel. Looks good though!
    2015 BMW i3 REx
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Thanks Guys ;)
    Ill add weight and height when i get a chance...
    got to get my engine back in there first
    Veteran Member Three Rings Quadfreak's Avatar
    May 01 2012
    WA
    Brand/Name: Rotiform MIA
    Weight: 25lbs
    Offset: 35
    Spacer(s): 10mm in rear
    Camber: Small amount in rear
    Tires: 235/35 General UHP
    Suspension: Vogtland GT
    Spring Rates: N/A
    Ride height: 25" GTF
    Fender mods: None
    Rubbing: None
    Brake Spec: Stock
    Only pic of front fitment (ET35)
    Pic of rear (final ET25)
    Brilliant Black B6 S4 - JHM Tune | JHM LWFW & Stage 4 Clutch | JHM 6-Rib Kit | JHM IM Spacers | Milltek CB & DPs | JHM Trio & Delrin Knob | Vogtland GT Coilovers | Rotiform MIA | 034 Snub Mount&Bracket | 034 Motor and Tranny Mounts | 034 Rear Sway Bar | 034 Front & Rear Endlinks | Stern Adjustable Control Arms | Apikol Diff. Mount | CF Relak Side Skirts | Maxton Front Lip | 3k HID Fog Lights | Full LED Depo Taillights | Full Sound System
    May 26 2013
    Northwest PA
    Brand/Name: VMR 708
    Offset: +35
    Spacer(s): None
    Camber: Stock
    Tires: Yokohama YK580
    Suspension: Stock
    Spring Rates: Stock
    Ride height: Stock
    Fender mods: None
    Rubbing: Never
    Brake Spec: Stock
    2012 S4 GIAC Stage II | AWE Touring | Prestige | Monsoon Gray | Black Leather | Carbon Atlas Inlays | Advance Key | 6MT | B&O | Sports Diff | MMI+Nav |
    Sep 09 2011
    2011 Chevy Duramax, 1999 Mazda Miata
    Chardon, OH
    Brand/Name: Hartman Peelers
    Offset: +25
    Spacer(s): None
    Camber: -2 front -1.7 rear
    Tires: 225/35-19 KUMHO SPT
    Suspension: FK Highsport
    FTG: 24"
    Fender mods: none
    Rubbing: Yes over large bumps
    Brake Spec: stock
    RIP 2004 S4 built by Gellner Engineering Racing Engines
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by Quadfreak View Post
    Also, I would like to suggest moving the blank template to the OP just to make it easier to find
    Added
    Post pics!
    Veteran Member Four Rings ABT B7's Avatar
    Jan 27 2007
    MB C350 4M
    Alberta
    OP can you post more pictures of your car from the side?
    Mods: 15% Tint 19" Avant Garde M621 Antique Matte Bronze LED License Plate Lights + City Lights+ Interior Neuspeed Catback Oettinger Roof Spoiler Painted Reflectors + Rear Valance 5000K HID Fog 6700K D1S JHM SS TTRS Steering Wheel Apikol rear diff mount JHM Intake Spacers JOM LED Tail Lights AWE Down Pipe PSS 235/35/19, JHM LW Rotors Akebono Euro Pads StopTech SS Lines JHM Tuned Full Oettinger Kit KW V3
    Future: JHM Pulley+ IM+ Stg1 S/C
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by ABT B7 View Post
    I will add more this weekend, I'll be Santa Barbara for a wedding. Plenty of photo ops
    Jan 27 2007
    MB C350 4M
    Alberta
    Looking forward to it
    Feb 26 2014
    IL
    Car looks great!!
    Feb 26 2014
    IL
    How's the wheels holding up? Want to get some! Ride ok on the 19" or dramatically different than 18"? Bumps, harshness, popping tires rash etc? Love the 111's :)
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by clottes1 View Post
    19's Ride GREAT with the appropriate tire. I run a 255 on 9.5" wheels and there's a slight stretch, but rides quite smooth.
    May 13 2008
    MQBs
    San Francisco
    More to come this weekend!
    Keep the setups coming guys
    Sep 05 2008
    Northwest Florida
    Yeah, I can't wait. I really like what I see so far!
    May 13 2008
    MQBs
    San Francisco
    Edit: Added to original post to keep the thread clean.
    Picking up at 034 today.
    Man, that silver window trim has gotta go..
    May 01 2012
    WA
    Also, and I dont meant to be that guy...but if we want this thread to work we need to eliminate the chit chat and make it a sticky. That is the reason the B6 A4 wheel thread works because they keep the thread clean, and it is just pages of wheel set-ups. If you really want to ask questions then start a new thread otherwise all this info is just going to get lost cause I can just see this thread getting full of "Looks great" and "will this fit" type of posts.
    Just my .02
    /rant
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Brand/Name: XXR 531
    Weight: 21lbs
    Offset: 35
    Spacer(s):NONE
    Camber: UNK
    Tires: 235/40/18 BullShiz off brand tires the dealer that sold the car to me put on.
    Suspension: FK HighSport
    Spring Rates: 559lb-F/571lb-R
    Ride height: low enough!
    Fender mods:NONE
    Rubbing: some in the rear if taking a hard turn or big dip in the road
    Brake Spec:OEM
    Other: Had the center cap stickers made for like $8 from some company. They're the "3D" clear rubber coated type.
    Sep 05 2008
    Northwest Florida
    Just my .02
    /rant
    You're right, though. I wouldn't mind if a mod came in here and deleted a bunch of the chatty-cathy posts—mine included.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Yes, this is a cool thread...we tried to do this a while back, but I guess not enough people knew about it...and it was in the gallery, and it was separated by model and wheel size...
    19" B7 S4/RS4 Wheels
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Feb 13 2010
    Carmel, IN
    Bump... starting to see a lot of 'will they fit' threads again.
    Sticky, please?
    2015 BMW i3 REx
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Quote Originally Posted by auxnbus View Post
    Sticky, please?
    I see u updated your post. Lookin good! Also very helpful as you are one of the few posters running a cab in here.
