Results 1 to 19 of 19
    Senior Member Three Rings Levski's Avatar
    Jan 22 2014
    Dublin, OH
    2008 Symphony II, Bluetooth streaming through iPod dock in glove box?
    I have looked around for a Bluetooth adapter that I can plug into my iPod dock in the glove box so I can stream music from my phone.
    I tried this one (which doesn't work) : http://www.amazon.com/Bluetooth-Rece...mpow+bluetooth
    I Googled but everything is from at least 3 years ago. Was wondering if something new has come out that you guys might know about that would work. Seems that more people were having issues with the 2008 model than others. I have the Symphony II, and from what I read is not A2DP compatible.
    08 Audi A4 Quattro TIP / S-Line / Ocean Blue / Bi-Xenons / APR Stage 2+ / JHM HPFP + FMIC / ECS Snub / RS4 RSB / P3Cars / APR CAI / LED DRL, License, Interior / RS4 Covers / R8 Coil Packs / Spulen TIP / 034 HFC / tt DP / Magnaflow / Cupra R / 034 mounts / Thor Skid / H&R / Hawk HPS / Goodridge / Stoptech / DV+
    May 20 2010
    I would think Enfig would have something you could use. I got an iPod adapter from them years ago and works great with the steering wheel controls (song names only show up on center of cluster rather than the Symphony II+). I believe they have Bluetooth as well, and it's all plug-and-play.
    Jan 22 2014
    Dublin, OH
    VisseO WMA1000 seems to be the only thing that might work.
    Nov 03 2012
    CA
    Look into Dension units. They work great. They replace the glove box adapter and plug inline with the stereo harness.
    Veteran Member Three Rings Acme's Avatar
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    Dension units are a very good option but it cost a lot more than a simple BT adapter. But it also does a lot more... I love mine, and yes it's plug'n play. It's a nice upgrade if you don't plan on upgrading the head unit.
    2013 Daytona Gray A4 Premium S-Line Quattro 6MT - NAV - bi-xenon - adaptive dampers - Alcantara - Eron's rear view cam
    SOLD! 2008 A4 2.0T Quattro 6MT Unitronic stage 2
    Junior Member One Ring
    Jan 08 2013
    1995 Toyota Tacoma
    Houston, TX
    Quote Originally Posted by Levski View Post
    The problem you are facing is that the factory iPod dock does not provide power (i.e. it does not charge the iPod). Any streaming adapter will need power to operate. The only option, aside from replacing the head unit, is something like the Denison products or wiring up an aux input. I am in the same boat as you but haven't yet bought an integration kit because I am considering the aftermarket unit fly300kts bought. - http://www.audizine.com/forum/showth...t-Nav-installs
    Nov 13 2011
    b7 s4 avant
    Quote Originally Posted by bcbickers View Post
    That's not true. My iPod Dock on my 08 charges my iPod
    I drive a truck now.
    Jan 22 2014
    Dublin, OH
    Mine charges also
    Sent from my SM-N900T using Tapatalk
    May 20 2010
    Dension--that's what I meant, not Enfig. I have a Dension which does iPod through a direct connect, but not Bluetooth, but I know there is a Dension unit that does it.
    Jan 22 2014
    Dublin, OH
    I have to look, thank you
    Jan 08 2013
    1995 Toyota Tacoma
    Houston, TX
    Mine charges also
    Weird. My dock doesn't charge my iPod touch (8gb) or my wife's iPhone 4. Something is amiss with my baby...
    Nov 13 2011
    b7 s4 avant
    Ah man that blows. I haven't taken my ipod out in like a year! It might be dependent on the generation though. Maybe check that first
    Sent from my SM-N900V using Tapatalk
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Mine charges my 2nd gen ipod nano 2008 A4.
    Veteran Member Two Rings dackler's Avatar
    Jan 31 2005
    Cortland NY
    Yep, Dension. I had a 4th gen Touch that charged as well.
    BT phone calls, steering wheel controls worked.
    Selling it in the classifieds now since I've switched head units.
    Jan 22 2014
    Dublin, OH
    I ordered the Visseo, if that doesn't work I will look at the Denison.
    Using a 2nd gen ipod, not sure why yours is not charging.
    Jan 22 2014
    Dublin, OH
    Just received the VisseO WMA1000 and it works very well. It allows my Samsung phone paired both as a phone and to stream music. So far quality of music is good and no skipping from signal lose. A little expansive but I don't want to upgrade my headunit.
    May 09 2014
    01 Dodge Dakota
    Toledo/Ohio
    I used the WMA100o on my '08 TT, and it works pretty good.
    Junior Member One Ring JayDee03's Avatar
    Aug 03 2014
    1969 VW Bug convertible
    Denver
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    Quote Originally Posted by JayDee03 View Post
    can you explain your approach to get this thread out AND giving a 'out of stock' link?
