Originally Posted by
VancouverS4
Just throwing it out there but with everyone wanting to go stage 2+ and the constant craving for POWER (read like Clarkson) at what point does all the money spent stop making sense and if it is an option when will someone swap in a S6/S7 motor. Same transmission I believe, different ECU though.
I'm sure it would be an epic journey to make it work but is it even a possibility?
Probably not feasible without near-factory level tuning help. The biggest obstacle in the CANBUS integration of all the required powertrain electronics with everything else in the car. It's like an ethernet network (which will itself supposedly replace shitty canbus soon in cars) where all the modules need to talk and cooperate and if they don't you lose your radio, your dashboard or the enchilada. Not pretty.
Probably feasible to bore/stroke the 3.0T out to 3.6-4.0L and throw a St3 SC on it when available, but with the torque it'd make you'd probably toast a DSG. 6MT with an uncomfortable clutch might work though. Prob $50k in mods, maybe more.
Like others said, I'd look at other platforms like the S6/S7, M5 or E63S (now AWD!). Or just buy a GT500 and with some moderate bolt-ons run 9s for 1/2 the price and keep the S4 St2 for saner travel.
