Results 1 to 7 of 7
    Senior Member Two Rings macwithdacheese's Avatar
    Aug 31 2012
    Unitronic software question
    Hi,
    I would like to know if i can use 380CC Injectors for the K04-015 Unitronic tune or absolutly need 386CC injectors.Because it is not a big difference.
    If i really need 386 injectors,do you know any one that would trade them with mine(Mine are brand new)
    This is last thing i need to do to finish my build I will update pictures soon @ :
    http://www.audizine.com/forum/showth...K04-build-PICS
    2003 A4 1.8T Quattro USP Stage 3 - Never forgotten
    Acura TL Type-S - RIP
    A4 Avant 2.8 1998 to 1.8T EFR- RA-4 (Project)
    A6 S-Line 4.2 2007 - Daily
    Passat 1.8T Wagon 2003 Stg.1 - Daily
    Check Out retro.haus on IG/Retro-haus on FB
    Oct 10 2012
    chicago il
    Tune calls for 386cc, then you need 386cc.
    From what I understand you CAN NOT use 380cc injectors for a tune that calls for 386cc. It just wont work. Sell yours, buy 386's.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    It would be fine, but do the injectors have the same electrical connector, and are they the right height? Chances are no.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Stage 2 Banner Advertiser Four Rings John@Unitronic's Avatar
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by macwithdacheese View Post
    Hi,
    Our Stage 2+ Software requires OEM TT225 386cc injectors. Using alternative injectors other than the TT225 386cc injectors will result in undesirable results and is not recommended. In addition, please ensure that you're using an OEM TT225 MAF housing, retaining the stock sensor in the TT housing, as that is an additional requirement for our 2+ calibration. Feel free to let me know if you have any other questions!
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Quote Originally Posted by John@Unitronic View Post
    386/380=1.5% Don't kid yourself to get injectors with that kind of tolerance. You would have to flow test a whole bunch of 380 or 386 injectors to find 4 that even fall with +5/-5 cc around your desired 380cc.
    From what I understand about tuning: might be more important to get the correct TYPE of injector, since electrical and mechanical (spray pattern, etc.) conditions are different from one brand/type to another. So if the tune calls for OEM TT225 injectors (unitronics: inject the correct Bosch part number here), it is not so much the 380cc that are the issue, but the correct brand/type (hence: part number).
    Correct me if I am wrong.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by vtraudt View Post
    It is very important to use the exact injector that we require, if you're looking for the best results and support from Unitronic. As you mentioned, it's more than just the flow rate of the injector. Don't forget that the Bosch 380cc injectors and the OEM TT225 386cc injectors don't share the same latency times and spray pattern, which have a big effect on compatibility with the software calibration. Our Stage 2+ software calibration requires OEM TT225 386cc injectors.
