Results 1 to 15 of 15
    Jul 23 2013
    1989 Saab 900 SPG, 1988 Saab 900 Turbo Conv
    Philadelphia area
    Question Changing fuel filter - required to bleed the system
    Of course I don't have the VAG 1318 fuel pressure gauge with shut-off valve VAG 1318/21 and catch resevoir VAS 5226 - Bentley says to bleed the fuel system after changing the fuel filter. Does this mean I can't change my own fuel filter any more?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by Grusvag View Post
    I've replace mine three times and never used a VAG tool to bleed the fuel system. Replace the filter. Turn the key on, wait a couple of seconds, turn the key off. Repeat three or four times. Depress the shrader valve on the back of the fuel rail to "burp" the air out. Car should start and run normally. Or just replace the filter and crank it for a few extra seconds as you bleed the air through the injectors.
    Dec 25 2004
    Earth
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Im doing my fuel filter and pump this weekend.
    She has been whining fro a few months now, and I have been waiting for it to warm up a bit to do it.
    Looks pretty straight forward.
    Senior Member Two Rings SoCal Driver's Avatar
    Nov 28 2012
    2016 VW Tiguan S 4motion
    Oxnard, CA
    did mine a few months back. I replaced the filter but didn't bleed the system, it took about a minute of cranking to finally fire up.
    Current: 2015 Audi S4 P+ | Ibis White | Sports Diff | B&O | Carbon Inlays
    Past: 2008 A4 2.0T Quattro 6-Speed | 2004 A4 1.8T Quattro 6-Speed USP in Arctic White
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    I miss being returnless fuel. Since going with a B5 rail and using my evap line as a fuel return, I need to pull the fuel pump fuse to depressurize the system or I get fuel everywhere
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Jun 26 2013
    You'll get a check engine light if you don't burp the air. The system will say that it is too lean. You can delete the code using Vagcom or a generic OBD reader.
    Just so you don't freak out!
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    All I've ever done is cycle the ignition a few times before I start it to prime the pump. Then let it idle for a couple minutes. I've never gotten a cel.
    Sent from my HTC6500LVW using Tapatalk
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Active Member Two Rings Sideburns's Avatar
    Apr 29 2012
    Western Maryland
    Quote Originally Posted by deadend9009 View Post
    You MAY get a check engine light if you don't burp the air.
    I didn't do anything besides replace the filter, turn the key a few times without trying to start it (as OG described above), and then start it...I was scared of this job just because it's fuel related (and you WILL have some spill/drip), but just make sure you have goggles and several rags. I used a pie pan lined with rags to serve as a drip pan. Leave the caps on the other end of the replacement filter while you work on the first side. Be patient with the clips. No smoking!
    Jul 23 2013
    Philadelphia area
    CRAP! Sorry everyone, I posted in the wrong forum. I've got a B7, 2008 A4 2.0T. Much difference?!
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Shouldn't be any different.
    02 A4 Quattro 1.8T
    Senior Member Three Rings caldy315's Avatar
    Mar 18 2013
    WJ & WK2 Jeep Grand Cherokees
    Mpls, MN
    Quote Originally Posted by f1torrents View Post
    Do the filter first. Mine was whining and I replaced the filter first. It worked out just fine for me. Just a thought to save you a fuel pump and some $$
    Dec 28 2006
    Western Maryland
    If you do end up replacing the pump this may be worth a read: Clicky click
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    I didn't bleed mine and I just changed the filter on Sunday. Just primed the car a couple times then cranked it for a littke bit
    instagram: @low_n_slo
    https://forums.vwvortex.com/showthre...le/page2&amp=1
    79 VW Rabbit 🐇
    13 VW Golf R 🚗
    09 Triumph Daytona 675 🏍
    Jul 23 2013
    Philadelphia area
    Thanks gents. Much appreciated.
