Results 1 to 7 of 7
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    ST's vs KW V1's - What's the deal?
    Ok, i want to know once and for all… WHAT IS THE DIFFERENCE?!
    Everyone says it's just that KW V1's are stainless (corrosion resistant) and the ST's are not. Otherwise they are the same.
    But I'm not buying it!
    Looking at retail prices, there is like a $900-$1000 difference with KW's being almost twice the price of ST's.
    And then there was another thread here recently with people complaining about the ST's only being able to be adjusted to a certain height before needing spacers to go higher.
    So what's the deal?
    Does anybody REALLY know????
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    KW V1's are stainless and are a true strut, meaning the oil and piston assembly is built into the strut housing, where as the ST's are galvanized and use a strut insert that threads into the strut housing (much cheaper). For a DD in a mild-winter area, there is not a big difference but the build quality/serviceability of the V1's are a little better.
    Jan 13 2006
    Houston
    Quote Originally Posted by o1turbo30v View Post
    As, see… i knew it was more than just galvanized vs stainless.
    What about that height adjustability issue? Anyone know how the v1's compare? I didn't have that issue with my last set but just curious.
    Does that strut difference you mention have an affect on ride quality?
    Feb 19 2014
    RVA
    I just put a set of ST's in last week and like them so far. A few off sounds the first few days and on the first hard corners but none since, assume the springs were just settling. Its a little floaty on some of the bridge joints that elevate and drop very quickly (not a bump) but still way better than stock. Def not uncomfortable on rough roads. Def got what i was looking for in the ST's.
    Ride is great for a DD in an area with lots of potholes and road joints.
    Chances of me keeping a car more than 3 years is slim to none, so don't really care about warranty.
    Oct 02 2006
    Wadsworth,OH
    This not true. ST's are an exact replica of a KW V1, the only difference being that KW V1's are constructed from stainless steel. Believe it or not build materials can have huge differences in price.
    KW V1's
    http://kw-suspension.com/us/kw_damper_basics.php
    ST's
    http://www.stsuspensions.com/technology
    ST's are made from galvanized steel which is lower quality but still offers some corrosion resistance, not to mention they have a 5 year warranty.
    Jason
    Feb 06 2012
    Allentown, PA
    Jason
    Direct quote from Phil Castro at KW North America after my ST's had to be rebuilt after 5,000 miles for terrible squeaking under 15mph, "Unfortunately our ST coilovers are inserts , not wet filled like our KW brand"
    Oct 02 2006
    Wadsworth,OH
    When I asked about this I could not get any calcification, below was the response I was given when I e-mailed them about the differences.
    "Hello Jason,
    Thank you for contacting KW Automotive, the difference between ST and the V1 is that the ST line has a galvanized housing and a limited 5 year warranty while our KW line has a stainless steel inox coated housing and a limited lifetime warranty.
    If you have anymore questions please let me know.
    Chad Gordon
    Technical Advisor"
    Jason
