Here is what I have going- The car has the factory rnse and the technology package, I have a 4th gen ipod classic and a 1st gen touch, I have purchased the dension gateway pro gwp1ac1, the enfig ipo5dc9 cable, a spare aux cable, and the dension ext1cp2 connector port kit. The ipod cable is in the first port on the left, the connector port is plugged into the next port and top usb port. I have tried unplugging everything and plugging everything back in several times, as well as the reset button, and nothing seems to make a difference. I'm also not totally clear on what the bypass switch does? It doesn't seem to change anything either. Typically the blue light is solid on the port connector.
Here are the issues I am having, the first is that I am frequently unable to switch between sources, sometimes when I plug in my ipod it comes up as ipod UI, and sometimes it comes up as ipod GW, and I have no idea what makes the difference, I can't see any correlation in the order I hook up the ipod and what is displayed. I am not able to switch between the two when it's plugged in, and even when it does come up as ipod gw, it rarely displays track titles in the cluster, most of the time it just says ipod gw in the display. While this is taking place and it is reading ipod gw in the cluster, sometimes I am able to change tracks with the left scroll wheel, and sometimes I am not. I have paired my phone with it, my phone seems to see it and connect just fine, but I cannot get the phone menu to come up in the center display. In fact the menu button doesn't seem to do anything consistently, sometimes tapping the menu button will bring up the source menu, then tapping it again will change tracks (without scrolling, just 1 tap equals different song
Is there something that needs coded in vag com? I have a hex can cable if I need to change something, the paper that came with it says you may need to code the phone and media settings from model year 2011 on, I have an 06 and can't see anything obvious to change.
I will get some pictures, and hopefully a video up asap, until then any one have any words of wisdom?
