Originally Posted by
audinaut
depending on vehicle and what I am working on, I'll use the rear diff or rear tow hook, basically something towards the center of the vehicle so both sides of the vehicle raise at the same rate. Pump or release the jack as needed to level the bubble in the torpedo level, then place another set of jack stands under rear of car. Use scrap wood with the rear jack stands if needed, but basically I will carry most of the weight with the floor jack, releasing it a tiny bit it puts some weight on the jack stands and they cannot be pushed or knocked out under any amount of force.
Isn't it bad to jack up via the rear diff or rear tow hook? I have bent the rear tow hook on another car that way, and I can't imagine the stress caused by jacking up by the rear diff is good. For me, jacking up my B6 is very easy. I have the RS4 jack pads, so I just use a hydraulic jack (with hockey puck jack pad) under subframe bushing mounting points. Then, with the car jacked up, I slide stands under the RS4 jack pads. The jack pads are also shaped to allow use of the factory trunk widow-maker.
seanf86
as others have said, it does not matter if the cars not perfectly level, as long as its close, the whole filling the trans thing is not a perfect science either, if you're a little over or a little under its not the end of the world, thats why you're supposed to check it every oil change.
Are you confusing this with a manual transmission? IIRC, manuals have a fill plug which is easily used to check level. You fill, and once it starts pouring out, you're done. That is not the case with the Tip, where there is a more complicated fill procedure. For example, with the TIP, if you open the fill plug when cold, a ton of fluid will drain out. If you have the transmission at 40degC and have shifted through the gears, it will not pour out as much, if at all.
diagnosticator
When refilling the trans, add fluid until dripping overflow occurs. Next, start the engine in Park, with the e-brake applied, and add fluid until dripping overflow begins again. Next, with the service brake applied, shift through the gears, P>N>D>N>P stopping in each gear for about 10 seconds, then return to Park. Check the fluid temp, with the fluid temp between 30 and 40 degrees C, add more fluid until dripping overflow occurs again, then reinstall the fill port plug. Next, turn the engine Off. Finally return the car to the ground and test drive. Done.
If the fluid temp exceeds 40 degrees C with the fill plug removed, reinstall the fill port plug then turn the engine Off. Wait for the fluid to cool down to 30 degrees C as shown in VCDS, or with an infrared temp gun pointing at the bottom of the trans pan. With the fluid temp =/>30<40 C, start the engine then remove the fill port plug. Add fluid until dripping overflow occurs then reinstall the fill port plug before turning the engine Off.
Does it matter at which temp. between 30 C and 40 C that I do my final fill? The manuals/instructions all seem to suggest topping it off to overflow as close to 40 C as possible, right after holding each gear for 10 seconds for the trans to suck up as much fluid as possible through the pick up tube.
As mentioned above in this post, I am considering replicating my cars forward rake during the fill procedure. Would you suggest doing this? This would allow me to put more fluid into the transmission - but probably not much. I am hoping this won't affect the transmission in a negative way.
