Page 1 of 3 123 LastLast
Results 1 to 40 of 99
    Mar 28 2009
    Minneapolis, MN
    Custom fit sunshades - Anyone have these?
    Recently had a kid and the suction cup rollup sunshade is not cutting it. Yes, I already have 40% 3M Crystalline tint on my windows and that cuts down on heat, but direct sunlight is still something I'd like to alleviate. Long history of melanoma in my wife's family, so the more direct sunlight I can reduce, the better. Yes, I should have gotten a car with sunshades built in, but I didn't, so no need to suggest that.
    A friend of mine found a company in the UK that sells custom fit sunshades, and they have a set for the B8 sedan & Avant: http://www.uvcarshades.co.uk/shades-...4779_2772.html
    I like that these are custom fit to the specific car and seem to be easily removable. I'd order these, but shipping to the US is almost as much as the shades themselves, and the total is over $180 USD. Anyone know of a US distributor for these, or any other similar options?
    Here is a PDF with the specific pieces for the B8 sedan: http://www.privacy-shades.co.uk/cars.../AU-A4-4-B.pdf
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    im my mind serves me correct, these were discussed at length in the a4 forums. may want to try there
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by jlaudio View Post
    Thanks, I'll have a look around.
    Edit: Found a thread where these are discussed: http://www.audizine.com/forum/showthread.php/559800
    And another: http://www.audizine.com/forum/showthread.php/439993
    Mar 28 2009
    Minneapolis, MN
    $180 is starting to look like a pretty good deal. If nothing in the US shows up, I'll probably order a set of these.
    Feb 12 2013
    Boston, MA
    If I was in your situation 180 seems like a deal, I would get them asap.
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by IanCH View Post
    Just did. $192.39 shipped.
    Jan 07 2011
    2013 C300 4Matic
    cousin had these on his a4. great for its purposes
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Three Rings $nooze's Avatar
    Jan 02 2012
    Looks like they could block out wondering eyes as well during some action to go time
    '11 B8 S4 6mt
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by $nooze View Post
    Move along, baby #2 in the works.
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    I have the factory sunshades which are very convenient.
    However, for maximum blockage (as you require), I think the ones you have ordered are better as they will cover ALL the glass (including the little window behind the rear doors). Nice find.
    May 13 2011
    2015 BMW F30
    Looks top notch Congrats on the new baby.
    | Autospeed | JHM | Pure MS
    Mar 28 2009
    Minneapolis, MN
    Found a review for these shades over on MBWorld, in case anyone else is considering them: http://mbworld.org/forums/5279561-po...tml?styleid=19
    Got them this morning via FedExUK! It's exactly 72 hours since I got off the phone with the folks at vanstyle.co.uk--just like BMW1203 had mentioned. And I'm located in the midwest near Chicago.
    The construction is really sturdy and solid. The shade fabric is thick just like MB's oem rear shade; unlike those thin, near-transparent material from generic sunshades you find at Wally world. The frames are thick and sturdy. Yes, they also come with a zippered black bag with handle for storage. I believe all are manufactured in the UK.
    The fit is really good, just like the pix posted by BMW1203, and definitely looks better than the oem pull up side shades. I put on the clips into the intended cleft and they are secure, allowing me to open and close the windows and doors without any shade movement. Just remember those clips go between the the rubber sealing strip or velvety rubber sealing strip and the plastic body panel; not between the glass and the body panel (also stated on vanstyle's website in response to one user's comment about wobbling sunshade)
    I have the rear power sun shade. However, I figure I would put the rear window shades on (might as well use them since I paid for them). The fit is good. But it's so tight it's difficult to have them exactly edge to edge at the center. If you push too hard, the shade fabric gets distorted and you will see shadow on the fabric. So I took out the "aligning" clip in the middle and just left them overlap because the end result is not very noticeable. Even with the overlap, it wouldn't interefere with the power rear shade. Now I have the choice of making the rear window even darker with the push of the rear power sun shade.
    Overall, I'm very satisfied with the result. The appearance is really no different from dark tinting. Moreover, I can open my window and have the "tint" at the same time. Now I'm looking for similar material shades for the front side windows. I think I might get a set of c-class one and use the rear ones for the front side windows. I'm sure the fit will only be approximate and leave large gaps, but it will be better than nothing. As for the extra two rear panels, I will just attach them to my 20 year old car's hatch back window.
    I'll post up pics when they arrive.
    Jan 02 2012
    Lol! Can't wait to see pics of the shades tho quiet interested. Lots of nosey ppl in Toronto that will just stare into your car
    '11 B8 S4 6mt
    Oct 22 2009
    Massachusetts
    I am curious to see pics as well.
    '13 Monsoon, P+, 6spd MT, NAV, Sport Diff, 19" Peelers
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by fonseca_q5 View Post
    I'll post up when they arrive. Right now I'm trying to get payment figured out because the seller charged me VAT, which shouldn't have applied to my purchase. That's about $55 USD I should get back.
    Veteran Member Four Rings mithril's Avatar
    Jul 23 2010
    Port Moody, BC
    Thinking of ordering a set for my S6 instead of cutting up door cards to swap in the OEM roller blinds. I'll be interested to see what your opinion on the overall fit is.
    Current: 2012 Q7 Prestige 3.0T
    Former: 2008 FSI V8 Touareg, Galpagos Grey Metallic on Sienna interior… self-immolated due to low pressure fuel leak on exhaust manifold
    Former: 2002 S6, Silver on Silver Pearl w/ Alcantara insert.... stolen, used in a targeted gang murder and given a Viking funeral
    Former: 2000 A6 4.2L... killed by a distracted driver
    Mar 28 2009
    Minneapolis, MN
    They just arrived this morning. I also ordered a set for my buddy's Mercedes so we could both save on shipping costs. I'll install tonight and post pics.
    Dec 23 2013
    Nice find, interested to see the photos.
    Jan 27 2013
    Baltimore, Maryland
    I cannot wait as well. I plan to order if the review is positive.
    Mar 23 2014
    Ohio
    Damn son, I just paid nearly twice that for the kit from windesa.com The only thing mine has thats different is that it comes with the smaller triangular rear quarter shades and also a large shade for the rear window. I wish I would have seen this before I placed the order.
    2010 S4 Prestige Quartz Gray, S-Tronic, Sport Diff, Nav, B & O, Updated Shift Knob
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by BlackHawk23 View Post
    This kit has those pieces as well. I'll be installing them shortly once the kid goes to sleep.
    Mar 23 2014
    Ohio
    doh
    Mar 28 2009
    Minneapolis, MN
    Just installed the shades. I'll try to get better photos tomorrow in the sunlight.
    All six pieces come in this bag:
    These are the 12 clips hold the shades in place. Six long ones, six short ones:
    Here are the two rear windows and the small triangle window pieces. Yes, that is fresh snow in the background. It's still coming down.
    You snap four clips onto each side window shade, and then slide them into the channels in the doors. I couldn't get the first one in, until I realized that there is actually a left and a right side, and I had the wrong one. Once I swapped for the opposite shade, it went right in.
    I used a little plastic spudger to gently spread the rubber gaskets apart so I could insert the clips on the side windows:
    The triangle pieces just press in, no clips on these:
    Two clips along the top of each of the big back pieces, and they slide in as well. This photo was taken before I adjusted them a bit, but I did manage to get rid of the wrinkles. I'm not sure if I'll keep the back shades in much, but I wanted to see how they went in.
    I'm very pleased with these. They seem very sturdy and well-built. The mesh is about the same opacity as the rollup shade that I was using, so it should block about the same amount of light. I'll check it out in the daylight tomorrow, and I'll find out if the baby likes them or not. I couldn't tell for sure in the dark, but I don't *think* the clips are actually touching the glass, so they shouldn't scratch the tint. I don't plan on rolling the windows up or down very much with these in place anyway, but it looks like the window travel is not impeded.
    Mar 28 2009
    Minneapolis, MN
    Total cost for me was about $160. The seller originally charged me VAT, which he shouldn't have because they were being exported, so he refunded a portion of the price.
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    I currently use one of those cheap rollup sunshades in my SUV for my baby. When you get a chance to view these in the sunlight, let me know if you think this is noticeably darker than the cheapo rollup sunshades and if its worth the money to spend on them.
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Jul 23 2010
    Port Moody, BC
    What did he charge for shipping? The B8 price is the same as the C5 and the number I'm getting from the website is about $30 higher. Looks great through!
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by mithril View Post
    You can figure out shipping if you start an order and put a set in your cart. They charged a little but more since we were shipping two sets, but it was still cheaper than shipping them individually.
    Feb 12 2013
    Boston, MA
    They look really nice, interested to see how the car looks from the outside with these on. What is your pre-existing tint level?
    Dec 23 2013
    OP can you take some pics from the outside during the daytime? Interested to see what it looks like w/ the tint
    Does the rear shade w/ just tint make night driving difficult?
    Mar 28 2009
    Minneapolis, MN
    I'll take some pics today if I get a chance. I have 40% Crystalline tint.
    Veteran Member Four Rings Just A B8's Avatar
    Sep 29 2012
    is Messy!
    Northern NJ
    We need to get these on Massdrop. =)
    B8 A4 | PRESTIGE | S-LINE | SPORTS PACKAGE
    034 | AIRLIFT | AFE | APIKOL | APR | AVANT GARDE | AWE | BILSTEIN | DEFI | DEVAL | EUROCODE | HOEN | ROC-EURO | SPC | VIAIR | XPEL | YAKIMA
    Mar 28 2009
    Minneapolis, MN
    Inside, comparing front and rear on the passenger side:
    Looking back from the driver's seat:
    The baby taxi:
    I've never been a fan of darker tint on the rear windows, so I'm glad that I can take these off easily when I want to. Overall, I'm very happy with the shades.
    Dec 23 2013
    Thanks for the photos. Looks really good. Have you driven with them on at night yet? Wondering what visibility is like. THanks!
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by ahc View Post
    Not yet. I'll find out tonight.
    Jul 23 2010
    Port Moody, BC
    I didn't clue in that the price with and without VAT was exactly the same which explains the difference... gotta love lack of coffee and sleep I'll be ordering my shades today or this weekend. My old 4.2L A6 had the built in shades, but my S6 does not. These shades are still a better option than finding a set of used rear cards and swapping them as they also give the rear quarter glass covers. Didn't really matter with the tiny triangles in the C5 sedan but it's a different matter with the Avant. Thanks for your feedback!
    Jan 03 2011
    If not too much trouble, can you put your rollup shade on your front window and take a picture. Curious to see if these custom ones are similar to the rollup.... Your front windows have the same 40% tint as the rears i assume?
    Old cars:
    Feb 18 2014
    St. Paul, MN
    OP thanks for finding these shades. I had the rear window shade a Passat I just sold and wanted to get something similar for the S4 but didn't want to go up to the prestige level to get the factory ones. Pictures were great and I will likely order a set very soon.
    Yeah that snow was a little kick in the face on Thursday/Friday.
    2014 S4, Black, Black/Magma, 6MT, sports diff, carbon fiber trim, B & O, 19" peelers, Xpel
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by skiracerblah View Post
    Yes, 40% tint all around. I actually broke the rollup shade when I pulled the suction cup off the window, so I threw it away. I compared it to the shades before I installed them, and the mesh is very similar. The custom shade mesh might be a bit more dense than the rollup shade, but YMMV depending on what you currently have.
    I did end up taking the shade out of the rear window. Visibility was reduced but it wasn't terrible. I didn't get a chance to drive at night with the rear shades in. My wife rode in the backseat tonight with the baby, and she said that nighttime visibility out of the shades was reduced, but that's to be expected. I'm also not noticing any issues when checking my blindspot over my left shoulder while driving.
    Overall, still very pleased after a few days. I wish they made a set of these for my wife's Jeep, because I'd definitely buy another set.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    How does this play into tint laws? I mean, could you run the maximum legal tint and then throw these on and still be legal?
    Looks great man, thanks for the info
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by Usa View Post
    That I can't answer, and a lot of it depends on where you live. In Minnesota, a sedan can't have anything darker than 50% on any window. On an SUV, you can't go darker than 50% on the front windows, but you can go as dark as you want on anything behind the B-pillar. You can get a tint exemption from an eye doctor if you can find one that will give you one, but I haven't bothered to do that. Technically, I would think that these shades would fall under the same rules as a stick-on sunshade or cars that have sunshades built-in from the factory, but that's an assumption.
    My tint is illegal even without the shades, so if I get stopped for what looks like super dark tint on the rear windows, I'll just pull out the letter I keep in my glovebox from the Mayo Clinic that advises that any car that my wife or daughter are in often should have dark tint.
