My belief as to why Koni's are either loved or hated has to do with their valving. Peeps like myself that are used to digressive valving from manufacturers like Ohlins and Bilstein, hate the linear valving of the Konis. This is because Konis tend to be comfortable on low speeds, but dampen terrible at high speeds. This was my experience when going from Konis to Ohlins.
Couple of good reads:
From the Saab forums - But the reason I'm thinking of switching is that I'm pretty certain the Konis have a linear compression rate. Meaning that the faster you try to compress the shock, the stiffer it becomes. On an x/y graph with x being the speed of the shock movement and y being the resistance provided by the shock, you pretty much get a straight line at about a 45 degree angle up and to the right. The problem is that to get enough compression damping for good handling at slow shock speeds (the kind involved in turning and stopping), you have to live with too much damping on very quick shock movements, like potholes and expansion joints. As I understand it, one of the bilsteins big selling points is that they have a digressive compression rate. So on an x/y graph, the line initially goes up at an angle but then levels off towards horizontal. There is a bleed off valve in the Bilsteins so that you get about the same compression damping force on very fast shock movements as you do on slower movements. So in theory you get the best of both worlds - good stiffness on slow movements (handling) but not excessive stiffness on the fast movements (potholes).
From the Bimmer forums - Bilsteins are notorious for their sharp turn-in characteristics (acheived by digressive valving, but I digress), but that sharp turn-in comes at the price of transmitting small bumps right into chassis and steering. Large bumps they deal with just fine (again, due to the digressive valving), but some people don't like the overall "roughness" of them, and it depends A LOT on what kind of roads you normally drive on. (my experience has been that Bilsteins hate washboard roads) If you want to add some precision to an otherwise stock suspension, and can tolerate a little more ride harshness, go with Bilsteins.
Konis are really good shocks, too. And with their adjustability, YOU get to decide just how harsh you want them to be. Even at full soft, they're going to offer way better control than generic stock shocks. Full still is usually enough to shake your fillings loose. But, again... you get to decide where on that curve you want to be.
To get just a little deeper, Koni Sport shocks allow you to adjust the shock REBOUND damping, and NOT the COMPRESSION damping. Koni's don't have the sharp low-speed compression damping of a Bilstein. (low-speed referring to shock shaft speed, as in what the shock sees with steering inputs) So, in general, a Bilstein will resist body roll when you initiate a turn by resisting compression of the suspension on the outside tires, whereas a Koni on full stiff might be having the same sort of effect (controlling body roll) by resisting the EXTENSION of the inside suspension.
